Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
  • michael dranfield
    • Jan 2016
    • 232
    • England
    #121
    Re: Bush (Vestel) led40127fhdcntd - turns off and on repeatedly
    Originally posted by tn245
    Remote control info seems to be in the file mb95_hwprofile.bin in CONF. You can extract files from CONF.BIN using the scripts downloaded from https://github.com/jrspruitt/ubi_reader
    I have had a look in MBoot bin a line at 0x000E0D78 that says TOSHIBA_NEC GET IR KEY, now I think the Toshiba uses the NEC IR protocol while most vestel sets use Phillips RC5 protocol but what I really need now is a Mboot bin file from a Toshiba set so I can do a file compare and hopefully see which address needs to be changed , however the comment from Gabiz_ro needs some further investigation as he suggests changing some code opens up the previously read only settings in the service menu which could be very useful.
    • tn245
      • Oct 2013
      • 530
      So I got back on this TV thanks to prompting from michael dranfield and gabiz_ro.
      Firstly I discovered the firmware dump script I posted is not very useful the way I had written it. I've rewritten it to dump the ubi volumes as ubifs images and attached it below. This also means the volumes in UBIA actually dump now without it hanging. These ubifs images are pretty easy to unpack, mess around with and repack to put back on the TV.
      I didn't yet resolve my main board that keeps corrupting but I managed to buy another main board that works by looking for one with all the same connectors. I had to substitute a panel file which I got from a firmware pack provided by michael dranfield.
      Now everything works great including internet access so thanks guys for getting me back on it! I am still curious why the old board keeps corrupting so will continue to play with that for a bit.
      • gabiz_ro
        • Mar 2011
        • 167
        • Romania
        #123
        Can you explain more about substituting panel file?
        Did you look at nand bad blocks before and after nand scrub?
        • tn245
          • Oct 2013
          • 530
          The software on the new board expected a different panel, meaning the image was inverted and slightly distorted. By replacing file VESTEL_D1_PLUS_PNL.BIN in the CON volume with the correct file taken from a different software and reuploading to the set I was able to get the panel driven correctly.
          Note that VESTEL_D1_PLUS_PNL.BIN seems to be used to generate another file panel.bin which is then used as the panel driver. If panel.bin is already present I found that deleting it and replacing VESTEL_D1_PLUS_PNL.BIN worked to replace the panel driver.
          I didn't do anything to do with bad blocks or nand scrub.
          • jczarniak
            • Oct 2015
            • 179
            I've got same television, where sound works fine, backlight is on but no picture.
            Any ideas what's wrong?
            Thank you.
            Regards.
            • vinceroger69
              • Mar 2012
              • 6714
              #126
              Thank you.
              Regards.
              my set was doing this and was a faulty eeprom chip i relaced it with a pre programmed one from ohms supplies and all is ok now it may not be the fault with your set but is a possiibilty.Have you checked basic voltages like what dc voltage do you get on each side of the tcon fuse etc if your not sure post good clear pictures of the boards you have in your tv and we can see if we can point it out for you.
              • jczarniak
                • Oct 2015
                • 179
                Thank you for support.
                I've checked voltage on each side of the tcon fuse and I get 13.0-13.1 Volt.
                I've checked also Voltages on power supply which looks alright.
                What else can I check?
                If main board is faulty can I buy any vestel 17mb95m for 40,42 or50"TV?
                Thank you for help.
                • vinceroger69
                  • Mar 2012
                  • 6714
                  #128
                  Thank you for help.
                  As reece has advised in another thread you need to match the main board with all the details from the board and any stickers on the board as there matched to the panel used in the tv so really try too get a exact match whats the exact problems your having with your tv? if its a eeprom issue you can sometimes buy pre programmed ones from the likes of ohms supplies etc just send them a email with the panel details (on white sticker on metal back of lcd screen usually) they maybe be able to help you if not just keep searching for a matching mainboard i guess it may take some time though.
                  • jczarniak
                    • Oct 2015
                    • 179
                    Thank you.
                    Will eeprom issue causing no picture on screen?
                    Sound works fine, backlight is on, just no picture.
                    What's about USB sticks which ohms supplies are selling?
                    Will this cure my problem?
                    • lsvserg83
                      • Mar 2016
                      • 3
                      • Ukraine
                      #130
                      Hello!
                      I have TV POLAROID 3-40 LED 14 with VESTEL 17MB95M
                      After connecting to ethernet and Runing NETFLIX it was crashed..
                      TV not power on. only the power LED flashing continuously. remote control not reaction, picture is black (only every 30 second period switch ON backlight for 5 second). sound is epsent.
                      I download firmwire from BADCAPS.net FAQ
                      1. usb_auto_update_A1.txt
                      2. mboot.bin
                      3. mb90_en.bin
                      Write to USB Flash FAT32
                      insert to Upper USB in TV
                      Press OK on remote control and switch ON TV
                      after this TV is black all time without backlight.
                      Can you help me to find firmwire for it ?
                      and how can i flash it ?
                      • lsvserg83
                        • Mar 2016
                        • 3
                        • Ukraine
                        #131
                        file:///D:/VESTEL%2017MB95M/photo/20160320_155547.jpg
                        file:///D:/VESTEL%2017MB95M/photo/20160320_155553.jpg
                        file:///D:/VESTEL%2017MB95M/photo/20160320_162942.jpg
                        file:///D:/VESTEL%2017MB95M/photo/20160320_163003.jpg
                        file:///D:/VESTEL%2017MB95M/photo/20160320_170825.jpg
                        • lsvserg83
                          • Mar 2016
                          • 3
                          • Ukraine
                          #132
                          add pictures
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #133
                            Are you sure it a firmware fault ? Have you checked your Psu voltages ? The firmware will normally never crash while the set is on.
                            • tn245
                              • Oct 2013
                              • 530
                              Pretty sure this is a software fault. These sets run Linux and could easily corrupt and crash while on and accessing interactive stuff like Netflix.
                              I've got some mb95 software but not one that will match your panel lsvserg83. Hopefully someone else on the forum can provide one that matches.
                              • tn245
                                • Oct 2013
                                • 530
                                A note for anyone with firmware faults on 17mb9x boards: Unless you are sure you have the right package that matches your set exactly (not the model number - it has to match the production code on the main board), DON'T reflash it yet!
                                The software is divided into various parts - the mboot on the SPI chip, and then several partitions on the NAND. If your software is corrupt chances are that only part of it is bad, and the important bits that are unique to your set (panel and other config info) are very likely recoverable. The mboot/SPI chip I think is rarely the problem so no need to reflash that. If you attempt a reflash you will wipe everything and have to hunt out new software.
                                • beni33
                                  • Jan 2016
                                  • TM
                                  #136
                                  Hello, I have TV Horizon with Vestel 17MB95M. After an firmware corruption I reflash the board via USB. All work ok except the tuner. My question is how can I change the tuner type from Si2156 to Si2157?
                                  I have orginal backup form spi.
                                  • joaopmantunes
                                    • Sep 2017
                                    • Portugal
                                    #137
                                    I changed the tuner type succesfully just by changing the line here from Si2156 to Si2157 (see image). Just above that you can see Rc5117. I guess this refers to the remote control. There are codes for many remote listed elsewhere in the file including some with brand names (most without):
                                    Panasonic-Rc4861
                                    Sharp-RC484x
                                    Technisat-Rc4850
                                    Technisat-Rc4852
                                    TOSHIBA-Rc3412
                                    TOSHIBA-Rc4826
                                    TOSHIBA-Rc4827_8
                                    I think you should be able to replace that with the code for your remote if you can figure out which one it is.
                                    Hello! Could not find it to edit the file. Need to change IC tuner reference from SI2153 to SI2175. In what line is it in? Can anyone provide an edited file or somehow help me?!
                                    Best regards
                                    • george777
                                      • Sep 2017
                                      • United Kingdom
                                      #138
                                      I got a the same problem with the same board: TV keeps rebooting every 30s, no picture.
                                      Here are the exacts specs: 17MB95M - 10090577 - 23195159
                                      Do you have any idea where I should look to find to right files to flash it?
                                      I already checked the PSU, it seems do be working fine.
                                      Thank you so much for your help
                                        This is definitely not true - the TVs can crash while running. I've had a Vestel set crash when the TV guide is accessed, for instance.
                                        • Greeiejim
                                          • Apr 2018
                                          • Northern Ireland
                                          #140
                                          I dont know if this issue has been resolved yet, I had exactly the same problem, it turned out to be the firmware was corrupt.
                                          Done a firmware flash update and resolved the problem right away.
                                          Regards
                                          Jim
                                          • FlailingEngineer
                                            Help with Bush Tv (Vestel 17mb95m Mainboard)
                                            by FlailingEngineer
                                            Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
                                            Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
                                            05-31-2023, 06:52 AM
                                          • Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
                                            by Stephen
                                            MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
                                            03-15-2024, 09:37 AM
                                          • www
                                            LG L192WS-BN backlight turns off after 1 second
                                            by www
                                            I am testing an old LG L192WS-BN monitor I have that gives an image, but has a backlight issue. When you turn it on the backlight turns on 1 second and it turns off, turns on again, 1 second and it turns off and stays off. Using a flashlight I can see there's still an image.
                                            I replaced a bulged cap on the main board, but made no difference. I also got another exact same model monitor that has a broken ccfl (the connector got ripped from the panel and the main screen connector is also broken so I can't use this panel to test), tried using the main board from this one, same issue....
                                            03-24-2024, 05:26 PM
                                          • Chrissygizmo
                                            Bush led40127fhdcntd possile firmware issue?
                                            by Chrissygizmo
                                            I've picked up a bush led40127fhdcntd & the standby led is constantly flashing .. It flashes around 10 seconds then the backlights come on with a blank screen, led continues to flash for about 20 - 30 seconds & then the backlights go off , this is a continuous cycle..
                                            I will upload photos of the mb ,...
                                            11-03-2021, 08:28 PM
                                          • zklgfs
                                            Anker SoundCore 2 Bluetooth Speaker Turns Off After a Few Seconds (Possibly Firmware Issue?)
                                            by zklgfs
                                            I have an Anker SoundCore 2 (A3105) that I saved from the trash (well, I guess there's a reason why it was supposed to go into the trash...). The problem is that it always turns off after a few seconds (sometimes it stays on a bit longer, between 30 and 60 seconds, but it still turns off). The power light turns on and the bluetooth light starts blinking, but both abruptly turn off again. The "turn off sound" is still played after the lights turn off. Sometimes, it also loops the on-off cycle several times without me pressing any buttons. If I connect an AUX cable, music...
                                            Today, 02:14 PM
