Polaroid TLX-04244B Power Supply/Inv board didn't fix?!
  • Truncatedhose
    • Oct 2014
    • 343
    I have a Polaroid here with exact same issue described in this thread: (Comes on with Polaroid logo on screen and then shuts down with a static noise heard from speakers momentarily)
    https://www.badcaps.net/forum/showthread.php?t=13335
    In that thread, replacing the PS/Inv silved the problem, but...
    The problem here is, replacing the PS/Inv board did not help; I have the same exact symptom. I don't think I got a bad board. I've check all the blue caps on the edge of the board near the outputs to the CCFLs. I can't figure this one out.
    Help would be greatly appreciated!
    Thanks!
    Here are some pictures. (The 1st PS/Inv picture is of the new one installed and the last one is of the original PS/Inv)
  • CapLeaker
    Leaking Member
    • 8176
    Re: Polaroid TLX-04244B Power Supply/Inv board didn't fix?!
    maybe the CCFL is bad?
    • Truncatedhose
      • Oct 2014
      • 343
      That's what I wonder, but there doesn't seem to be a dim area when the screen is on momentarily. Might be hard to tell, though. I have a CCFL tester which I tried, but all I can do is use it to run bank A or B since you can't access the individual wires going to each CCFL, but only the two plugs coming from the PS/Inv board. I'm not even sure the tester can be used to power a whole bank in that way? It seemed check good (in the green), but I didn't turn off the lights to see if it was actually lighting half the lamps...maybe I could check that?
      • CapLeaker
        Leaking Member
        • 8176
        Check the transformers of the inverter board with your Ohm meter. Should be like within a few percent of each other. Could be also bad cabling of the CCFL lamps, or bad caps. Problem is to correctly test the transformers you'd need a Transformer Ring tester and almost no one has access to such a rig.
          • 12201
          • U.S.
          I'd be tempted to recap the mainboard, maybe the 7 bigger ones, maybe all, could be a mainboard issue, maybe corrupt firmware, may be an eeprom issue.
          • Truncatedhose
            • Oct 2014
            • 343
            Hi there. I do have a ring tester, but this unit just has a single transformer, does it not? Or is it two built together?
            • Truncatedhose
              • Oct 2014
              • 343
              I could check those caps, but the main board is developing the BKON (back light on?) voltage to the power supply and it doesn't drop or anything when the TV goes blank. I would think this would be a good sign? If I recall it was around 2.5 or 3.5 volts.
              • CapLeaker
                Leaking Member
                • 8176
                O.k. shortcut. Unplug all the main board cables from the power supply. Take two 1k ohms resistors and put one between 5v STBY and PSon. Take the other resistor and jumper 5v to BLon (backlight). Plug the power supply in and all voltage rails should be up and the backlight should be on.
                • R_J
                  • 9540
                  I have had cracked ccfl's that would still come on and work, sometimes they would arc a bit before coming on but would come on, and sometimes they would only flicker and shut off. When I took the panel apart I could see that they were indeed broken. but as long as the glass was touching it would light.
                  • Truncatedhose
                    • Oct 2014
                    • 343
                    Thank you, I will try that tomorrow and let you know.
                    • Truncatedhose
                      • Oct 2014
                      • 343
                      Yeah, I'm worried that this could have poor connections/sockets for the CCFLs. I will hope to find something else before having to delve that deep.
                      • Truncatedhose
                        • Oct 2014
                        • 343
                        Okay, so I unplugged both the plugs coming from the Main Board; (the smaller plug I unplugged at the Main Board so I could use the plug holes to push in the resistors at the Power Supply side) and I tried it, but the TV will not power on/nothing happens. I sent a picture to show which pins I am shorting. One thing I noted is that that cable is not using all of it's wires even though the pins are there and labeled on the board. I do get the voltages there (before unplugging anything), but I don't know if it matters that there are no wires going to the Main Board there anyway? Also, am I using the correct pins? See the attached picture.
                        • Truncatedhose
                          • Oct 2014
                          • 343
                          Someone? Thanks!
                          • CapLeaker
                            Leaking Member
                            • 8176
                            what is the pin out on the other connector?
                            • Truncatedhose
                              • Oct 2014
                              • 343
                              That larger connector to the right? It doesn't have anything printed on or near it on the top side of the board, but here is a picture of it's markings on the bottom of the board:
                              • CapLeaker
                                Leaking Member
                                • 8176
                                jumper there the 5V to the STBY with the resistor, see if that turns it on.
                                • Truncatedhose
                                  • Oct 2014
                                  • 343
                                  Okay, should I leave the other resistor on the other plug where it is between the BKON and the 5V?
                                  • CapLeaker
                                    Leaking Member
                                    • 8176
                                    Well... the BLon is just for turning on the back light voltage. Concentrate on forcing on the PSU first. Once you got it on, jumper the backlight voltage on too.
                                    • Truncatedhose
                                      • Oct 2014
                                      • 343
                                      Well, I did that and still nothing. Just sits there dead. I think I might try replacing the Main Board. What do you think? I don't think the PSU is bad having already replaced it and gotten the same exact symptom. The noise from the speakers (like a fairly loud rush/crackle) when the TV shuts down makes me very suspicious of a failure on the Main Board (maybe in the audio circuit) and that's why it's shutting down? Also, I looked very carefully with the lights off from the back of the TV and it seems that all the CCFLS light up before it shuts down and that makes me more confident that it might not be anything to do with them either.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Could you take a good clear photo of the mainboard please, I have had a similar issue on a vestel set where the audio amp was bad, the tv started backlight came one then a crackle and it shutdown, I replaced the amp and it came back to life.
