Emerson lc320em8a inverter transformer
  • Herbssat
    • Sep 2011
    • 194
    Re: Emerson lc320em8a inverter transformer
    Changed all 6 inverter transformers and now the set works fine. Evidently the ring tester could not find the problem child transformer. Thanks for all the responses.
      What kind of ringer did you get? The transformers all show the same result?
      • Herbssat
        • Sep 2011
        • 194
        Hey Budm. I used the blue ring tester with the same result on each transformer.
        • Herbssat
          • Sep 2011
          • 194
          Here is a picture of the results.
          • CapLeaker
            Leaking Member
            • 8208
            Good to read that you are back up and running though and thanks for the feedback!
            • Herbssat
              • Sep 2011
              • 194
              #26
              The set has reverted back to its old ways according to the customer. I picked it up and have been watching it since 8 am this morning. It has not acted up yet. This is going to be a dog to trace. Definitely need more suggestions on this one. Thanks.
              • littlejohn
                Emerson clock radio transformer
                by littlejohn
                Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
                08-30-2023, 07:13 PM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • x_orange90_x
                by x_orange90_x
                01-29-2025, 09:24 PM
              • dennis_elx33
                3PHASE STEP-DOWN Transformer in Check
                by dennis_elx33
                Hello All,
                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                Problem statement: Power tripped Off
                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                Action Done:
                1) Replaced the faulty parts with good spare.
                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                12-02-2024, 06:52 AM
                ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                09-06-2024, 04:40 PM
