3PHASE STEP-DOWN Transformer in Check
This topic has been answered.
  • dennis_elx33
    • May 2019
    • 32
    • Malaysia
    Hello All,
    i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
    Problem statement: Power tripped Off
    Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
    Action Done:
    1) Replaced the faulty parts with good spare.
    2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will go to MCB and directly to Transformer.
    3) We ignore this low ohm reading and instead power up using the 208VAC 3phase input since we dont have any reference to compare with.
    4) performed power up testing but power supply tripped off. (inrush current shows 138A).
    Result: Failed. 1 IGBT and 1 Diode shorted this time at same location
    Earlier Question: is this a normal resistance reading for the transformer at L2 to L3 reading?
    Latest Update: Inductance readings..
    Questions:
    1) Do you think the inductance from pin 2 to pin 3 at primary side a normal reading?
    2) I am Off today so our team tried simulating by injecting voltage using a single phase instead of 3phase to each pair, do you think the result will be same with the 3phase voltage input? They said that the secondary voltages were good.
    Any other testing method that you could suggest in order to confirm the functionality? thank you so much!
    Note: We could not find any datasheet for this transformer.
  • Answer selected by dennis_elx33 at 12-17-2024, 08:23 AM.
    R_J
    • Jun 2012
    • 9628
    Like I said, I don't think the transformer is the problem, one of the lines from three-phase input should connect to primary 0, One of the other lines from the three-phase input should connect to one of the voltage taps, likely 240v the third line from the three-phase will not connect to this transformer, it operates off a single phase.
    These shorted components may have also blown a fuse on one of the lines that supplies the low voltage transformer primary
    • R_J
      • Jun 2012
      • 9628
      • dennis_elx33
        • May 2019
        • 32
        • Malaysia
        Thank you so much R_J, indeed the transformer is not the issue. But we have worse problem now as the IGBT and rectifier diodes keeps blowing when the setpoint of the HV output is around 52KV. Maximum voltage is supposed to be 80KV.
        I have here some sketched circuit diagram for you to refer to. Maybe someone can help us solve this problem. We have tried to replaced the affected parts including the PWM IC and OP-amps but still encountered the same burnt parts.
        Is there any chance that the big capacitors are the issue?
ID:	3530258Click image for larger version
        • learnmore
          Help choosing replacement transformer for Levoit 600S SMPS
          by learnmore
          Hello Community,
          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
          Peace
          LM...
          11-04-2025, 09:35 AM
        • ohren
          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
          by ohren
          Hello!
          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
          Measured voltages with no load:
          After rectifier diodes
          12V: 6.17 V
          5V: 5.67 V
          Secondary transformer pins AC measurement (really don't know if this says anything)
          12V: 2-2.5 V
          5V: 1.04 V
          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
          03-18-2023, 10:33 AM
        • mikey5791
          Is it possible for transformer substitution?
          by mikey5791
          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
          My questions are
          1. How do i test to see if the transformer is in good working condition?
          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
          Hope you guys understand what i was asking. My intention is...
          11-03-2022, 02:11 AM
          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 04:40 PM
          ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
          This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
          09-06-2024, 12:00 PM
