Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
  • ohren
    • Mar 2015
    • 121
    • Sweden
    Hello!
    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
    Measured voltages with no load:
    After rectifier diodes
    12V: 6.17 V
    5V: 5.67 V
    Secondary transformer pins AC measurement (really don't know if this says anything)
    12V: 2-2.5 V
    5V: 1.04 V
    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79, 5.36, 8.9-11.9, 6.3-6.9 V (depends a bit on probe polarity apparently — due to DC component?)
    Also, measuring AC on transformer input pins just confuses me greatly and I imagine a DMM is the wrong tool. The sick PSU measures ~10 V (really?) The healthy PSU measures ~150 V. Again, I'm not sure it says anything to measure presumably square wave pwm at hundreds of kHz with a DMM, and also seems to depend on probe polarity as well as the specific voltage setting on DMM. I guess I don't have the theory or technique down for AC measurements.
    Observations and details
    * I'm not aware of any service manual or schematics for this PSU
    * I don't really have any easy load to measure with (Xbox will not stay on)
    * 5.67 V for 5V rail is out of spec assuming a 10% tolerance. Assuming a 5% tolerance would put the Delta out of spec too.
    * Bulk cap stable at 315 V
    * Switching transistor seems fine
    * 12 V cap healthy (1014 uF 0,06 ohm ESR) according to cheap component tester and my eyes
    * All twin rectifier diodes healthy (symmetric 150-200 mV drops which I understand is ok for Schottky). All their joints were resoldered for good measure.
    * 5/12 V rails share transformer T1 while 3.3V uses T2, so I assume a single feedback for each transformer (two optocouplers and two switching transistors in total)
    * 3.3V output stable
    * I assume 5 V being too high is because 12 V is too low (?) Both 5 and 12 V go to the control board so I'm assuming both levels are taken into account for feedback
    * 5 and 12 V rails are separated by 36 ohms in accordance with heatsunk resistor of corresponding color code
    * I can't really get at the vertical PWM control board (tl3845) during operation, and only half of the board otherwise. It's wedged between the bulk cap and primary heat sink. I did figure out what's connected to it although I fail to deduce the transformer topology from it, since I'm not that experienced with different types of smps designs.
    * I can get at the vertical control board only with difficulty. It's covered by all the output cables.
    * I hear a buzzing from the transformer which doesn't sound entirely healthy (see attached audio)
    * Earlier, when the sound changed momentarily the output voltage jumped up momentarily, a volt or so. It stopped doing that.
    * Measuring one pair of the three T1 pins on the primary side (in 750 V AC mode) changes the sound — it becomes quieter
    * Percussive maintenance doesn't produce an effect
    * I suspect maybe some mechanical trigger to the problem: it appeared after I took the PSU out to inspect and resolder the (previously repaired by me) AC input jack. This was in response to stepping on the plugged in end of the power cord and hearing a crunching sound. Since there was no visible damage on the board I attributed the crunch to 15 year old hot glue coming loose when the AC input jack bent downwards. Still, some mechanical stress is put on the board when pulled out of the Xbox and my inspection was probably the cause.
    I strongly suspect the transformer. How do I go about confirming that?
    Am I jumping to conclusions before checking everything properly? Did I miss something obvious?
    What should my next step be in troubleshooting?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transform
    You need to test the PSU with a higher minimum load on the 5V rail. I would say 1 Amp minimum on the 5V rail.
    Use a 12V car light bulb rated for 20 Watts or more or an MR12 12V halogen bulb rated at 20, 35, or 50 Watt. Connect this bulb to the 5V rail. The 12V rail should measure much closer to normal now.
    12V: 2-2.5 V
    5V: 1.04 V
    Most regular DMMs won't show proper AC voltage at the output of an SMPS transformer. So it's a test you can skip doing in the future.
    Yes, DMM is NOT something you should use on the high-voltage side of an SMPS's transformer. Again, the high switching frequencies combined with high voltages will show meaningless results at best. At worst, some meters can even get damaged. So that's another test to skip in the future. The only way to measure switched AC on the primary side is with an oscilloscope AND ONLY if you have an isolation transformer (otherwise, you'll likely blow your scope or the PSU fuse.)
    Well, if it wasn't, you wouldn't get any output from the PSU.
    The smaller transformer is for the 3.3V Standby supply.
    Once the Xbox sends a PS-ON signal to the PSU, the main PS turns on, which generated the 5V, 12V, and 3.3V rails. 3.3V rail appears to be generated from the 5V rail through a mag-amp circuit - pretty much the same thing as a group-regulated ATX PC PSU.
    Yes.
    And note the current (and power ratings) of each rail.
    5V: 13.2 Amps (66 Watts)
    12: 1.4 Amps (16.8 Watts)
    The original Xbox uses a variant of the Pentium 3 CPU. CPUs of that era drew their power from the 5V rail instead of the 12V rail, much like the early AMD Athlon CPUs and Pentium II's. So it's expected that even with the Xbox running idle, there would still be at least 5-10 Watts of load on the 5V rail (i.e. 1-2 Amps). If you're testing the PSU without an Xbox motherboard and without any load, then it shouldn't be a surprise that the 5V rail runs high and the 12V rail runs low. Of course, this may not happen with every Xbox PSU. Depending on who made the PSU and how it was designed, the 5V and 12V rails could read close to spec without a load. But some PSU designed won't... and it appears that this is one that may not be. So to verify, put a load on the 5V rail and see if the PSU voltages appear more normal. Again, try to put at least 1 to 2 Amps of load on the 5V rail. The 12V rail should be OK without a load, but if you want to connect something like a low-power PC fan, that should be OK.
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      • Romania
      FWIW, the recent modchipped 1.6 I got had a 733/128 marking on the CPU - I'm much inclined to believe it's a Celeron Coppermine - a standard P3 at the same speed is shown to have 256KB of cache.
      Main rig:
      Gigabyte B75M-D3H
      Core i5-3470 3.60GHz
      16GB DDR3-1600
      Samsung SH-224AB DVD-RW
      Delux MG760 case
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        You can read about it here: https://en.wikipedia.org/wiki/List_o...-128"_(180_nm)
        A custom Coppermine-based Pentium III version was developed for Microsoft's Xbox game console. The only significant change was that the chip lost half of its L2 cache, dropping it down to 128 KB. Unlike the Celeron Coppermine-128 variant with the same size L2 cache, but reduced 4-way L2 cache associativity, Xbox's Coppermine core kept all of its 8-way L2 cache associativity from the Pentium III. This means that the Xbox CPU's L2 cache is more efficient than Celeron's. The Xbox CPU was manufactured onto the same Micro-PGA2 packaging as notebook chips, but in a BGA (ball grid array) format.
        • ohren
          • Mar 2015
          • 121
          • Sweden
          Yes.
          Couldn't have asked for a better answer. I was hoping you'd reply based on your replies in https://www.badcaps.net/forum/showthread.php?t=95744.
          Turns out you're absolutely right, and I didn't need to find a lightbulb; I tried it again in the box again and it just worked. What am I even doing here... It was repeatedly shutting down when powering it up before. If I fixed it it might have been bad joints on the rectifier diodes who were sharing a heatsink, since they were the only ones looking matte. The only problem after that was some arcing between the diode pins, but they seem to have dug their own isolation slot by now.
          Thanks for pointing out what tests I don't need to bother with in the future — it's something I always want to know! Sometimes I only get advice on what to do next without learning how they figured it out. And I will rewatch that EEVBlog episode on blowing up my scope if I ever get one. As far as I remember I can always use mains earth as a reference without isolation, but that's it. (Would the negative lead of the bulk cap not work?)
          I always do this kind of mistake. A transformer just for standby power sounds a bit much to me so I assumed it did something more, considering 3v3 was spot-on unlike the other rails. Now I have to go back and look, and look up mag-amp circuits.
          If I understand you right you're saying that the 12 V rail is actually low because the 5 V rail is high (not vice-versa), since the assumption that 5 V has a constant load is broken combined with the fact that they share the same feedback signal.
          This will no doubt all come in handy on my subsequent repairs. In fact, the day after starting this thread I came across another Xbox (and other treasure), so I went from one working box to three just now. A bit ridiculous — I don't even have that many good controllers! I should start a thread about repairing broken plastic screw posts.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            That's the exact way to do it if you want to blow up your oscilloscope!
            You can confirm this very very easily:
            Measure from the negative of the bulk cap to chassis ground WITH A MULTIMETER
            If the value shows anything else than 0.00VAC AND 0.00VDC then it is not a ground and if you connect your oscilloscope ground lead = mains earth ground cable then you will have sparks flying!
            If instead you float your scope the scope will not explode when you connect it, but you will die when you touch the exposed metal on the BNC connectors, or switches, or whatever else is metal on the scope.
            Please see this thread in addition to the EEVBlog video on how not to blow up your oscilloscope:
            https://www.badcaps.net/forum/showthread.php?t=96508
            • ohren
              • Mar 2015
              • 121
              • Sweden
              I must've remembered incorrectly
              I think I read through that thread a while ago. Good compilation, thanks! Been careful around those heat sinks since then.
              Come to think of it the negative lead, even discounting the cap's charge, is only at mains earth potential 50% of the time... I'm really not touching AC often enough. I foresee an explosion.
              • grimacelord
                Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                by grimacelord
                Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                10-24-2024, 12:31 PM
              • Nagy Daniel
                Lowest possible resistance on laptop motherboard rail - Guide Table request
                by Nagy Daniel
                Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                So, I generated a table with AI so I can...
                03-04-2025, 08:24 AM
              • TMTGTR
                An Xbox One PSU Odyssey
                by TMTGTR
                Firstly I am not a tech. You guys may see mistakes or oversights in my methods so don't be bashful and feel free to post corrections/opinions.
                =>Background:
                I bought my son a used Xbox One original model: A12-220N1A Rev: 02 with original PSU & 2 controllers 7 years ago. I “modded” the unit placing a 4.5” 12V exhaust fan with a 9v wall wart adapter on top of the vent/fan of the unit. And plugged the Xbox PSU into a Tripplite LTR-600 voltage regulator. Also connected to the Tripplite are a 275w computer tower, an Xbox 360 PSU and a Westinghouse 52” LED TV. ...
                06-17-2022, 05:40 PM
              • Victor Moreira Silva
                Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                by Victor Moreira Silva
                I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                Well, my decice specs are the following:
                Model: Acer Nitro 5 AN517-54-55T5
                CPU: Intel Core i5-11400H
                GPU: NVIDIA GeForce GTX 1650
                Motherboard: GH51G LA-L181P Rev:1c
                The symptom:
                When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                05-26-2025, 10:49 AM
              • learnmore
                Help choosing replacement transformer for Levoit 600S SMPS
                by learnmore
                Hello Community,
                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                Peace
                LM...
                11-04-2025, 09:35 AM
