Emerson clock radio transformer
  • littlejohn
    • Mar 2022
    • 26
    Hello I have a Emerson research clock radio model CKS3516C and the transformer went out on it ,the label on the clock radio says 120VAC 6 watt backup battery DC 3v CR2430. the numbers on the transformer ST3591C-13SEN which I can't find anywhere for it. Can anyone please tell me the AC output voltage. Thanks
  • R_J
    • Jun 2012
    • 9638
    Re: Emerson clock radio transformer
    Did you try the internet? a search of ST3591C-13SEN found this https://www.ebay.com/itm/283611561711
    Looks like it is a 18vac center tap 9+9 vac 12watt
      • 31317
      if the primary is open, check under the insulation for a thermal fuse
      • littlejohn
        • Mar 2022
        • 26
        Thanks guys , I'm going to see if I have a 9vac 6w wall transformer and tie that into the board , the transformer and shipping out of the states is worth more than the clock radio
        • R_J
          • Jun 2012
          • 9638
          The transformer is an 18vac center taped transformer, not a 9vac transformer, as mentioned, check the primary, if it is open, there is likely a thermal protection fuse which can be replaced if you can get at it
          • littlejohn
            • Mar 2022
            • 26
            I tore into the transformer and can not find a thermal fuse. I have a ST3591C-13SEN transformer with 2 secondary wires, the one on Ebay is ST391C-13DN with 3 wire secondary. Hence my thought 9vac.
            • R_J
              • Jun 2012
              • 9638
              I missed that EN vs DN at the end, I guess it could be a 9vac single output as I cant find any datasheet on the transformer.
              • shelby5041
                clock radio / radio lifespan?
                by shelby5041
                hi
                ive got a modern digital clock radio approx 15yrs old
                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                it uses very little power just a few watts i would imagine that may have something...
                09-14-2024, 03:30 AM
              • UserXP
                Vintage SONY Digital Clock Radio ICF-C12W no audio
                by UserXP
                Dear all,
                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                My question is, do you know of this brand of capacitors and how bad are...
                07-21-2025, 08:35 AM
              • TinkerTron
                Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                by TinkerTron
                Hey everyone,
                I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                Instead, here's what's been bugging me so far:
                The schematic...
                03-06-2025, 02:03 PM
              • ClockChip
                GE 7-4643A Clock radio - Is this a common pictogramme for 9-volt battery backup on appliances?
                by ClockChip
                I came across this sticker recently:
                (It's from a 1980s GE clock radio - the model number is at the bottom left.)
                I worked out the top pictogramme (indicating a 12/24 hour facility) and bottom pictogramme (120v or 220v mains power) fairly quickly. But the middle pictogramme...ah. That one left me baffled for a time.
                (I won't say how long, exactly, because it would be too embarrassing.)
                Eventually, it dawned upon me that this was a pictogramme to indicate a 9-volt battery backup facility.
                My question is: has anyone...
                08-27-2024, 09:02 AM
              • praveenramavath
                Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                by praveenramavath
                Hello All,
                I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                https://www.hifivision.com/threads/m...-screen.98243/
                Troubleshooting Summary: Majority Internet Radio - Flash Chip
                04-26-2025, 09:08 AM
