sony KDL-46S4100 proper voltage
    • 12206
    • U.S.
    have a quick voltage question, I'm getting 11.54 coming from the a board goes down to 11.30 volts at the tcon, and still no red standby on front just steady green, no video or audio, black screen, is this proper or do I maybe need a new lvds cable, any ideas, Thanks.
  • sordids999
    • May 2013
    • 2156
    Re: sony KDL-46S4100 proper voltage
    https://www.badcaps.net/forum/showthread.php?t=39740
      • 12206
      • U.S.
      thinking 11.30 v at the tcon isn't enough to make it display.
        Most T-CON operating Voltage range is +/-10%.
          • 12206
          • U.S.
          don't know where to measure the standby voltage, can't see the stby printed on board anywhere, sorry no pics., no access to camera, thanks.
            • 12206
            • U.S.
            ok, so I'm good with 11.30, does it seem strange that it goes from 11.54 to 11.30 at the other end?, THANKS.
              • 12206
              • U.S.
              I have the service manual and see the test points for the a board but not sure how to test it.
                • 12206
                • U.S.
                got a rebuilt a board from shop jimmy, then 1 from ebay, 1 gives me what looks like the age pattern when bl-on wire is unplugged the other just gives two different solid colors with bl-on unplugged, all the voltages from the connectors on g board test good, solid green light on front, no red standby light on front, flowchart says if volts are right at g board replace aboard but also says if no menu at all seen, and proper voltage at tcon, replace t-con, tried 3 t-cons, if not that it says bad panel, would I get back light if panel is bad?, THANKS.
                  • 12206
                  • U.S.
                  wonder if I could do a factory reset without being able to see the menu?
                    • 12206
                    • U.S.
                    only other thing I can think of, it might need the firmware replaced but no firmware for this model on sony website.
                      • 12206
                      • U.S.
                      I'm thinking a power surge during a storm borked my firmware???
                        • 12206
                        • U.S.
                        got different a board, have strange condition, with lvds cable unplugged from a board side only, get backlights on in about 8 seconds, with lvds unplugged from tcon side only, no backlight at all, any ideas?, THANKS. trying to post pics., having some trouble, will keep trying.
                          • 12206
                          • U.S.
                          some pics.
                            • 12206
                            • U.S.
                            some pics.
                            sorry bout the poor pics., best I could get out of this 5mp camera.
                              • 12206
                              • U.S.
                              when unplug bl-on connector from g board, get 2 red blinks on front but I think it's just because it's unplugged, when plugged in the blinks go away and theres no red standby at all.
                                • 12206
                                • U.S.
                                would like to test everything on the a board and tcon that I can with dmm, can't seem to find any good pics. or videos on the subject.
                                  • 12206
                                  • U.S.
                                  if all the voltages at my plugs on the g board are correct, does that usually mean I can rule out the g board?, thanks.
                                    • 12206
                                    • U.S.
                                    been reading the manuals, can't figure out why I have no red led standby on front, just steady green, anyone know what to check on g board or elsewhere, when no red standby on front?, getting proper voltages at g board to a board plugs, tried testing cn1 read 000 on 200 and 750 acv, unless I'm testing it wrong.
                                      • 12206
                                      • U.S.
                                      tested it wrong, there is 122v at cn1.
                                        • 12206
                                        • U.S.
                                        I was thinking there's supposed to be a red standby light on front, when tv is off and plugged in but none of my working tvs have that, it must be normal.
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          by sam_sam_sam
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                          Based on Intersil's Robust Ripple Regulator...
                                          11-05-2024, 03:24 PM
                                        • ruletero
                                          Acer a515-43 low battery charge voltage
                                          by ruletero
                                          Hi
                                          Acer A515-43
                                          LA-H801P
                                          Fail: Does not charge battery, has low voltaje on connector.
                                          Laptop didn't want to turn on, only charge led blinked.
                                          I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                                          I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                                          Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                                          10-24-2022, 02:31 PM
