Would this problem be a bad panel? Sharp LCD
  • tucocaps
    • Apr 2013
    • 331
    • United Stated
    Trying to avoid what might be another Ebay disaster. Buyer is buying a mainboard (along with a tcon) to "fix" this problem. He says the lines are green in color, and other pictures he had show them being even darker. They look kind of random and all over the screen to me. Based on what I know, I thought this could maybe be a panel problem. As the main is kinda pricey, I don't want to send this to him, only to hear complaints or begging returns because a bad panel was the culprit. Thanks!
  • Ltank
    • Jun 2013
    • 776
    Re: Would this problem be a bad panel? Sharp LCD
    What is the model ? LED or Plasma TV?
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      This does not look like a panel problem at all to me.
      A working TV? How boring!
        I have seen Double images due to bad tab bonding.
        http://s807.photobucket.com/user/bud...tml?sort=3&o=8
        Something like this I would re-seat the cables, heating and cooling the board, flex the panel, etc.
          Not a panel issue IMHO.
          • tucocaps
            • Apr 2013
            • 331
            • United Stated
            Thanks for the input. I normally keep a "hands off" approach to any of my miscellaneous ebay activity, and almost never post about it on a forum like this. Mainly , because I have enough problems I need help with myself
            Like I said, I'm just hoping the mainboard and/or the mainboard/TCON combo will fix this particular buyer's set ... because of how it is on the bay nowadays. You sell a TV part on there, and all of a sudden you are responsible for the part AND fixing the buyers set ... all for absolutely zero money ... and if things don't go right often abuse/hassle/cost on top of it.
            • perzyk23
              Lenovo T580 - LCD Panel problem - error 0288
              by perzyk23
              Good morning,
              I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
              10-25-2024, 12:42 AM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Andrew453
              Crestron TPS-2000L with Sharp LQ5AW136R panel
              by Andrew453
              I have numerous Creston TPS-2000L touchpanel home automation devices, which incorporate a Sharp LQ5AW136R panel. They all exhibit the same fault. They are about 10-15 years old.
              The fault can be seen in the attached photo. Basically the displays are all washed out, to be point of being unreadable.
              Clearly it's an issue with the panel. But my question is whether it's just aging related (e.g. all the pixels in the LCD wearing out) or whether it could actually be a more specific component (i.e. one capable of being individually replaced). I've seen suggestions on other...
              01-28-2023, 02:54 PM
            • porfyriadhs
              LG 49UJ701V Panel problem
              by porfyriadhs
              Hello I have a tv with bad panel
              Brand LG 49uj701v. At first screen wasnt working only sound with backlight was working welll. The I tried tape at the lvds and it works but I get have image with shadoe
              10-05-2024, 06:18 AM
            • Davi.p
              Sony KDL-42W705B panel problem
              by Davi.p
              Hi, this has panel problem for certain (AUO panel), in the troubleshooting process, after pressing ON button i am with set making a short lamp of backlight with status light shortly white then green/yellow repeated, in this situation main board remain powered and also tcon with all their correct output voltages. I cant find in the service manual description of this state, can you brief me ? thanks
              01-26-2023, 07:56 AM
