Lenovo T580 - LCD Panel problem - error 0288
  • perzyk23
    • Mar 2017
    • 31
    • Poland
    Good morning,
    I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise. Regards​
  • reformatt
    • Feb 2020
    • 1746
    Check voltages at LCD connector, and any fuses etc.
    You should put as much info as possible in your post if you want help, like motherboard part number, link to schematic/boardview etc, background of the issue.
    • perzyk23
      • Mar 2017
      • 31
      • Poland
      Motherboard: LTS-2 MB 17812-1
      CPU: I7-8650U
      Graphics card: Intel UHD 620
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • s_specialist
        Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
        by s_specialist
        Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
        07-07-2025, 11:47 AM
      • konradx
        Lenovo Thinkpad T15 Touchscreen problem bios
        by konradx
        i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
        That is my DUMP.
        My device:
        SN: PF29Y4N6
        1s20S7S2WF00PF29Y4N6
        MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
        09-06-2024, 01:33 AM
      • madrali
        lenovo e15 gen2 bios ? problem
        by madrali
        Model: Lenovo ThinkPad E15 Gen 2 (Intel)
        20TD-50S0KU00
        Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
        I used Lenovo's SmartBeep decoder and it returned error 0284:
        "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
        I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
        06-16-2025, 12:06 PM
      • Wojban
        Lenovo V330-15IKB -> problem with powering on
        by Wojban
        I have a problem
        The problem is that when the laptop is not in use for a while, it won't turn on or respond to the power button. The BIOS battery is good. After disconnecting the main battery and reconnecting it, sometimes it will turn on and function normally. Sometimes it will display the error "real time clock error - check date and time settings" and stop turning on. Sometimes it won't respond to the button at all. I thought it was a problem with a damaged BIOS chip or KBC.
        I thought that, when the BIOS battery is good, and it still losses settings, maybe...
        12-07-2025, 10:25 AM
