Hi I have a 3d LG 47" LW 6500. The screen has washed out colors and the menu does as well. I tried replacing the tcon to no avail. Everything works fine and the firmware is up to date. Is it the panel? Any help would be appreciated.
photo negative LG 47" LW6500
Re: photo negative LG 47" LW6500
Looks like bad GAMMA Voltage ref problem in the T-CON board.
Pictures of the back side of the TV?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
You have to carefully remove that metal shield to get to the T-CON board. Show us the back side of the TV.Never stop learning
Hi,I took off all of the boards but I didn't feel qualified to remove the metal shield that remained. It didn't come off easily and I got nervous forcing it.I took two more pics of the screen. Any advice on how to remove the shieldingComment
Post pictures of the shielding. Maybe there is a foot attached to the shielding. Dont forget to remove the screws near scart/hdmi sectionI only repair Panasonic plasma tv's! Currently owning a TX-P55VT50 and still searching for a ZT60!
A lot of times these shields are taped down with anti static tin tape or some sort of felt tape. Also they could be stuck to the top of the sponge like chip heatsinks.
Take a look around the shield sometimes they can be surrounding the TFT ribbons so you don't want to yank it off.
Most are only held on by 4-5 screws.
http://www.shopjimmy.com/lg/47lw6500-uaComment
I would say bad LCD panel then is the next most likeliest option.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
Hello there. I have the same tv series LW6500 but a 65". One side of screen looks wash out and the other half is black. Disconnecting the ribbon cables from the t-con (wash out side) the whole screen looks perfectly black. I would like to give T-con a try but can't find this board anywhere. Any suggestion on component level repair options? T-Con Part Number: 55.64T05.C04
If any body have the board for sale pls message me.
Thank you guys.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi, i have the same TV having the same problem, washed out picture with a single bad vertical line. And i cant find any other posts on this same model. would it be wise to post my photos and steps to this thread? i haven't opened her up yet. but would love to help someone else as reading through some other posts helped me to repair a friends Samsung with a bad IC AS15 chip.
or would it be better to start a new thread? thanks for your help!
by x_orange90_xJust bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
- Loading...
