photo negative LG 47" LW6500
  • quietwar
    • Mar 2014
    • 15
    Hi I have a 3d LG 47" LW 6500. The screen has washed out colors and the menu does as well. I tried replacing the tcon to no avail. Everything works fine and the firmware is up to date. Is it the panel? Any help would be appreciated.
    Re: photo negative LG 47" LW6500
    Looks like bad GAMMA Voltage ref problem in the T-CON board.
    Pictures of the back side of the TV?
    • quietwar
      • Mar 2014
      • 15
      You want pics of the panel without the metal sheet? Or with the attached boards? Sorry if this sounds like a ridiculous question. I'm a newbie and I am trying to learn
        You have to carefully remove that metal shield to get to the T-CON board. Show us the back side of the TV.
        • quietwar
          • Mar 2014
          • 15
          Hi,I took off all of the boards but I didn't feel qualified to remove the metal shield that remained. It didn't come off easily and I got nervous forcing it.I took two more pics of the screen. Any advice on how to remove the shielding
          • quietwar
            • Mar 2014
            • 15
            Forgot to include these pics.
            • Moreno83
              • Jun 2014
              • 2008
              • The Netherlands
              Post pictures of the shielding. Maybe there is a foot attached to the shielding. Dont forget to remove the screws near scart/hdmi section
              • Shinju
                • Mar 2014
                • 1239
                A lot of times these shields are taped down with anti static tin tape or some sort of felt tape. Also they could be stuck to the top of the sponge like chip heatsinks.
                Take a look around the shield sometimes they can be surrounding the TFT ribbons so you don't want to yank it off.
                Most are only held on by 4-5 screws.
                http://www.shopjimmy.com/lg/47lw6500-ua
                • quietwar
                  • Mar 2014
                  • 15
                  Hi, I bit the bullet and took this to an electrician. They said that an I.c. was bad on the panel. Oh well. Thanks anyways
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I would still try a T-con.
                    • quietwar
                      • Mar 2014
                      • 15
                      I tried that in my original post. Didn't work. Also, the shop tried it with a new one, same result.
                        I would say bad LCD panel then is the next most likeliest option.
                          • 12151
                          • U.S.
                          so your saying the shop guy tested the IC on the panel?
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Once, I had happen something very similar, with another older TV.
                            There is usually an adjustable resistor, on the panel's PCB and it was touching(shorting) to the panel's metal frame.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              Once, I had something very similar, with another older TV.
                              • Louis82
                                • Feb 2012
                                • 240
                                Hello there. I have the same tv series LW6500 but a 65". One side of screen looks wash out and the other half is black. Disconnecting the ribbon cables from the t-con (wash out side) the whole screen looks perfectly black. I would like to give T-con a try but can't find this board anywhere. Any suggestion on component level repair options? T-Con Part Number: 55.64T05.C04
                                If any body have the board for sale pls message me.
                                Thank you guys.
                                • ROOBZ
                                  • Jan 2016
                                  • 10
                                  • New Zealand
                                  Hi, i have the same TV having the same problem, washed out picture with a single bad vertical line. And i cant find any other posts on this same model. would it be wise to post my photos and steps to this thread? i haven't opened her up yet. but would love to help someone else as reading through some other posts helped me to repair a friends Samsung with a bad IC AS15 chip. or would it be better to start a new thread? thanks for your help!
                                  • x_orange90_x
                                    TCL 50S535 bad tcon or panel issue?
                                    by x_orange90_x
                                    Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                    03-29-2025, 11:02 PM
                                  • advant
                                    by advant
                                    02-03-2020, 12:25 AM
                                  • Hakuu
                                    by Hakuu
                                    Hi There,
                                    More Details
                                    TV Model - LG OLED77G1PUA
                                    07-12-2023, 02:37 PM
                                  • Daren87
                                    Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                    by Daren87
                                    I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                    08-13-2023, 03:25 PM
                                  • alltvrepairs
                                    Lg TCon test pins for screen test
                                    by alltvrepairs
                                    i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                                    Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                                    Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                                    Appreciate your help....
                                    06-13-2025, 06:33 AM
