Panasonic TC-32LX85 Dead
    Re: Panasonic TC-32LX85 Dead
    You can try that, limit temperature to about 90C.
    • kevinm34232
      • May 2012
      • 1884
      It seems like heating up C7011 causes it to work. I am using a small nozzle just aiming at that cap.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #83
        thats the cap you have changed a couple of times? i wonder if the track has a break in the circuit? as you already have replaced that cap unless its something else really close to that capacitor?
        • kevinm34232
          • May 2012
          • 1884
          Im waiting for it to cool down again then try to heat it from the side to make sure, but I suppose it can be anything close that is heating up too.
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #85
            can you post a picture of the area? are there parts on both sides of the board in that area?
            • kevinm34232
              • May 2012
              • 1884
              Pics... C7011 is directly right of transformer.
              • kevinm34232
                • May 2012
                • 1884
                Im trying to use freeze spray and heat to isolate the area, but I can't seem to get it stay 'off' with the freeze, but the heat definitely works to get it on. I think it's something on the bottom.
                The last time I got it stay off I blew heat down the 2 small holes from the top, which are right above Q7000 and it came on instantly. Ill have to keep experimenting..
                • kevinm34232
                  • May 2012
                  • 1884
                  I think this is fixed, replaced IC7000, Q7000, and PC7000 and it seems to be working consistently. I suspected Q7000 but I replaced all 3 at the same time just to be sure.
                    Thanks for posting the follow-up, hopefully it will stay working.
                    • kevinm34232
                      • May 2012
                      • 1884
                      As of now still working after several cold starts. So thank you Bud and Tom for the help. FYI the VCC at IC7000 is about 15.2V now as opposed to around 14.5V before which still seems low but it's working.
                      • solrac8126
                        • Nov 2014
                        • Panama
                        #91
                        Hello, new here, i was looking on the web info on the same tv .
                        Mine does power on and shut off after a few minutes, then it blinks every 4 seconds not 3 as in the Inverter SOS.
                        I see no swollen caps i re heat the 3 items kevinm34232 said.
                        and this time flickered a bit.
                        And left it alone.
                        I will appreciate any help.
                        • BigPete
                          Panasonic Heatpump Dryer Repair
                          by BigPete
                          I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                          The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                          In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                          Unfortunately the whole machine has to come apart to fix it.
                          I have...
                          11-01-2025, 06:40 PM
                        • badcappo
                          Dead Panasonic Viera TX-P65STW50 Plasma TV
                          by badcappo
                          Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                          Diode type G972s6 - D101 with a short
                          Mosfet 06N90E - Q301 shorted
                          Fuse T5AH 250V - F103 blown
                          Diode D301 shorted
                          Relay DG1U-17VDC II - RL001 blown
                          I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                          11-24-2024, 11:27 AM
                        • Andre Gilbert
                          by Andre Gilbert
                          Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                          Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                          11-20-2024, 08:52 PM
                        • Super360
                          Panasonic TC-P50G10 DEAD
                          by Super360
                          Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
                          12-27-2021, 11:40 AM
                        • double_DD
                          How can I be sure that my EC chip is dead?
                          by double_DD
                          As the title suggests, how can I be sure that my EC chip is really dead?
                          I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                          Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                          03-12-2025, 07:47 AM
