Panasonic TC-32LX85 Dead
    Re: Panasonic TC-32LX85 Dead
    Just a quick test. Does IC7000 on power board have any markings?
    C7011 could be bad, or R7003 could be high resistance.
    • kevinm34232
      • May 2012
      • 1884
      Funny I was just looking at C7011 and saw it was a Rubycon and figured it would be good.
      IC7000:
      A6159
      SK872
      Which I think is this:
      http://pdf1.alldatasheet.com/datashe...STR-A6159.html
      I also noticed the pin on PC7000 that connects to STB5V looks like it may have a burn mark next to it?
        Over-current threshold is 0.77V for that IC, 2.7R sense resistor.
        I=V/R=285mA primary current or ~9.4A short circuit protection threshold assuming transformer ratio of 1:33
        (Realistically it will be much less)
        So I think it should be able to supply the current.
        C7011 could still be bad, even if it's a Rubycon, they aren't immune from failure, it's just infrequent.
        • kevinm34232
          • May 2012
          • 1884
          How bout the photo coupler with would could be a burn mark next to it? I found another cap for C7011 I can try that now and Ill check R7003, that's 2.7 ohms right?
          • kevinm34232
            • May 2012
            • 1884
            R7003 measured 3 ohms on my crappy meter.
            • kevinm34232
              • May 2012
              • 1884
              Well I replaced C7011 (with a salvaged cap), right away I tried the resistor and it maintained 5V. However after putting it all back together, when plugged in, it started clicking erratically and now the voltage is low under load again.
              • kevinm34232
                • May 2012
                • 1884
                Could IC7000 be bad? This PS board is not available.
                  When you use the external power supply, is there current limit setting on that power supply since 400mA should not cause your external power supply to drop.
                  • kevinm34232
                    • May 2012
                    • 1884
                    Yea there are knobs to adjust voltage and current up and down but I don't know if it stops when it reaches where you adjust to, I would guess. I could turn it up but I didn't want to burn anything out.
                    • kevinm34232
                      • May 2012
                      • 1884
                      Is there anything here that would cause the STB5V to shut down without causing a SOS? I am trying to figure out why changing the cap caused relays to click, like the first time I turned the TV on, then nothing after that. Can I check any pins to see if it's triggering a shut down?
                      If there are some suspect parts I'd like to order them to try to figure it out.
                        OK, the main power power relay runs off the 5V STBY power supply, when the relay contact is closed (the relay is turned on through Q7027 which it gets the SUB_ON (PS_ON) from the main board when the power switch is activated), then the main power supply will turn on and the various voltages will eb supplied by the transformer T7002, if there is over voltage condition from any one of the +12V, SUB_5V, SUB_9V, Sound_VCC it will activate the OVP Shutdown circuit (Q7054-57) which will shut down the power relay.
                        But right now we are not sure if the main board is drawing too much current or the power supply is not able to supply enough current to run the main board.
                        So right now when you apply the 120VAC to the TV, the relay should not come on until the power switch is activated, at this point the 5VSTBY should be steady at 5V.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Things keep changing. Right now, when the main board is connected to PS, the STB5V goes low. When I tried putting a load earlier with the resistor, it would not stay at 5V. I changed the cap C7011 and then with the resistor it would maintain the 5V. Then I reconnected the main board and plugged in, and relays were clicking erratically, then it was dead again and STB5V is around 3V with main board connected.
                          I asked the person who had this thread what he had found..
                          https://www.badcaps.net/forum/showth...ight=tc-32lx85
                          And he replaced the PS board and it fixed it.
                          So I'm thinking it has to be something in the PS, very similar..
                          Also this all happens when just plugging into AC, I have never been able to hit power button, or just get a standby light.
                            It does sound like you do have 5VSTBY problem, as to what is causing it I do not know right now.
                            • kevinm34232
                              • May 2012
                              • 1884
                              Would changing IC7000, IC7001, PC7000 and surrounding zener diodes make sense at this point?
                              (Or I guess if you were going to try to rebuild the standby circuit what would you replace?)
                                Looking at the diagram of that 5VSTBY, it does not have much in it, the cap 7011 (4.7uF) is very small in value and not other large cap on the VCC pin, just a 0.1uF.
                                At this point I will use external supply again and set the current limit to 1A and try it again, the TV should work using the external supply if every thing else is OK, I do not expect this small supply to put out may be 1A at most.
                                I want to verify for sure that the TV will function with external 5V supply.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  I thought about this earlier, but I just need some details:
                                  -Do I need to apply the 5V from the external PS to the main board and isolate it from the PS board? Or can I just connect it to the PS board?
                                  -I'm not sure how to set the external PS max current because without being connected it will not show current. It has course and fine dials for current.
                                    Ok, so you have a CC/CV power supply. What this means is it will never exceed a set current limit (CC) or a set voltage limit (CV). For example, if you attached a 1 ohm resistor to a normal, non-current limited 3V power supply (such as some kind of 3V battery) the current would be 3A. On a CC/CV power supply you would be able to set the current LIMIT (CC) to 1A, which would then limit the output voltage to 1V. It always limits when either property is exceeded (so if you remove the load, the output current is 0A and the output voltage is 3V because now the CV limit is hit.)
                                    Hopefully that makes sense...
                                    To set the current limit of a CC/CV power supply:
                                    • Turn power supply on
                                    • Set output voltage to about 1V. The CV LED should illuminate.
                                    • Apply a short across the output using a thick piece of wire. You may see a small spark as the output capacitors discharge, this is OK. The CC LED should illuminate.
                                    • Now increase the current set point using the current control, in this case to 1000mA or 1.00A. The output current limit is shown on the meter. If the CV LED illuminates, you need to increase the output voltage (the short is possibly not low enough resistance.)
                                    • Remove the short and leave the current control where it is.
                                    • Set the output voltage as desired (5V)
                                    • Apply load, you now have a 5V/1A power supply, if the current tries to go above 1A the power supply will drop the output voltage to keep the current within 1A.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      OK will do. And is it OK to apply the 5V as-is or do I need to remove the STB5V from the internal PS.
                                        Don't connect the power board, only connect your power supply.
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          OK I did the process to set the current. (when you say use a thick piece of wire, could I just connect the alligator clips together to make the short?)
                                          So PS set to 1 amp and 5V, I removed the main board again and checked it, and it goes to about 400mA at first but then settles around 56mA. So it seems OK right?
                                          Now, I think Bud was asking me to apply the 5V with the external PS to see if TV turns on. In this case do I need to isolate the STB5V from the internal PS??
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                                            11-24-2024, 11:27 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • Super360
                                            Panasonic TC-P50G10 DEAD
                                            by Super360
                                            Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
                                            12-27-2021, 11:40 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
