Panasonic TC-32LX85 Dead
  • kevinm34232
    • May 2012
    • 1884
    Re: Panasonic TC-32LX85 Dead
    Ok let me look...
      Originally posted by kevinm34232
      I just want to be sure, above you said use a 4.7uF 50V on the VCC pin?
      I just want try with the small value first to see what effect it will have.
      • kevinm34232
        • May 2012
        • 1884
        All I have is a used 22uF 25V, and some new 10uF 16V
          You can try the 22uf for testing on the VCC pin, but I have a feeling the C7011 should be bigger than 4.7uf as it is right now.
          • kevinm34232
            • May 2012
            • 1884
            OK with the 22uF 25V cap attached across pins 2 and 3, relay is clicking on and off, over and over, VCC gets up to about 14.5V before it clicks off but it won't come on.
              OK, move that cap to where C7011 (4.7uF) is.
              • kevinm34232
                • May 2012
                • 1884
                OK did that, same reaction with clicking and same 14.5V VCC voltage.
                  That is really strange symptom. I am ready to suggest to connect the VCC circuit like it is shown in the application notes but sure like to know how it works before the way is it connected right now.
                  • kevinm34232
                    • May 2012
                    • 1884
                    Its clicking seems like it just doesn't have quite enough voltage to start up, but a lot closer than before when it was mostly just dead.
                    • kevinm34232
                      • May 2012
                      • 1884
                      Anything else I can check, I'm no expert reading the schematics but is VCC coming from pin 3 on T7001? Could D7005 be leaky? Is this being cause by the O.L.P., or just low voltage to the VCC pin?
                        The VCC must have got to 17V minimum startup voltage because it does startup, but then it goes into cycling mode so the VCC is cycling up and down. Do you have power supply to test Zener diode, I do not know the value of that D7005.
                        • kevinm34232
                          • May 2012
                          • 1884
                          Yes I have a power supply. Im just wondering if I can trace that VCC line to see where it's originating and where it might be going low or isolating it. Can I lift D7005, is it likely something right in that area?
                            OK, I would like to try something, put 100 Ohms 1/2W in parallel with D7008 and see what happen (I am bypassing Q7000 with resistor).
                            • kevinm34232
                              • May 2012
                              • 1884
                              I got the new 4.7uF 50V caps and replaced C7011 again and the TV came on. Ill have to test it for a bit.
                              Well I just went back and plugged in again and same clicking has returned, grrr. Ill try the resistor next.
                              Could that cap be getting 'damaged' when the TV comes on, because it did the same thing when I replaced it last time?
                                It would be unlikely to be being damaged, more likely something is intermittent. Maybe the soldering heat is helping temporarily cure the fault.
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  I tried the resistor idea from Bud, same clicking.
                                  Could the A6159 IC ever fail like this?
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    Maybe you're right about the heat, I just resoldered all the pins in the circuit in case of any bad joints, and the TV came back on. Ill let it cool back down now.
                                    Would there be any likely suspect parts if it was heat (caps, diodes, resistors) or any of them?
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      Cooled down and now completely dead again.
                                        With TV clicking, set your iron to a low temperature (150C or less) and touch it against the A6159 IC, does it stop clicking and start up? Be careful not to touch any pins with it, as your soldering iron may be grounded which would probably blow the fuse or do other damage. Also don't hold it there for more than 10 seconds if it doesn't react.
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          Right now TV is dead, there is a little < 14V at the VCC pin. I added some heat with the iron and no result. I have a hot air station should I just heating stuff up around there?
                                          • BigPete
                                            Panasonic Heatpump Dryer Repair
                                            by BigPete
                                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                                            Unfortunately the whole machine has to come apart to fix it.
                                            I have...
                                            11-01-2025, 06:40 PM
                                          • badcappo
                                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                                            by badcappo
                                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                                            Diode type G972s6 - D101 with a short
                                            Mosfet 06N90E - Q301 shorted
                                            Fuse T5AH 250V - F103 blown
                                            Diode D301 shorted
                                            Relay DG1U-17VDC II - RL001 blown
                                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check πŸ˜€...
                                            11-24-2024, 11:27 AM
                                          • Andre Gilbert
                                            by Andre Gilbert
                                            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
                                            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
                                            11-20-2024, 08:52 PM
                                          • Super360
                                            Panasonic TC-P50G10 DEAD
                                            by Super360
                                            Hi everyone I have a plasma here that is absolutely dead no power light. When I press the power button the relays click the fan spins for a second then it's dead and nothing happens on the screen. Anyone have any suggestions?
                                            12-27-2021, 11:40 AM
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
