Acoustic solutions lcd32761hdf
  • Hamie
    • Apr 2014
    • 1383
    Working on this tv for a neighbour.
    It's the tv their kids use to play the Xbox on.
    Symptoms. Stuck in standby.
    Powersupply - dreaded vestel 17pw26-4
    Originally had a few obvious caps bulging. Replaced and the power supply appears to be working. All voltages ok 24 volts to the inverter etc.
    Tv still remains the same turns on looks like will power up then back to stand by.
    Unplugging the inverter and the tv powers up steady voltage and runs fine. Has sound etc
    Looks like and inverter problem. Or possibly has a bulb drawing too much current.
    Don't mind replacing the inverter as can get one for a only few quid.
    But will this resolve the issue?
    What's the best way to test to see if it's the inverter or bulb issue?
    I also have not found a way to jump the back lights on without the mainboard as I don't know the pin layout.
    Any advice would be great.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Acoustic solutions lcd32761hdf
    Sorry double post
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      Please can you post pictures using manage attachments. Rather than in line or off site so that they will remain to help others.
      Is there a fuse on the inverter board - tested?
      Is 24v getting to the fuse?
      • Hamie
        • Apr 2014
        • 1383
        There is voltage getting to the board.
        24v on all positive legs of capacitors.
        Transformers all 3.9k ohm resistance between output legs.
          May not be the inverter.
          Did you replace the 15n 630V caps near top of transformer?
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            http://www.tv.quuq.org/forum/index.php?topic=2278
            post 5 int or no iverter
            • Hamie
              • Apr 2014
              • 1383
              Cheers, I actually have a working powersupply that I've just installed that I reclaimed from a smashed up Alva, I know this power supply to be good because I've tested it on a Toshiba.
              The fault remains. I'm convinced the fault lies with the inverter/bulbs.
              I decided just to removed all the transformers from the inverter and jump them. To try and exclude bulb failure.
              The fault remains. Therefore I'm pretty convinced the inverter has a fault.
              Apologies about photo format, can't seem to upload any other way from my phone.
                Jump... the transformers? How?
                  I cannot see how that will work, the MOSFETS will basically drive the <1 Ohms loads which are supposed to be the primary windings of the inverter transformer, now they driving short piece of wires, and the lamps are now just sitting there without high voltage drive from the transformers. I wonder if those MOSFETs are still OK, now the inverter circuits will really draw lots of current.
                  • Clydeuk
                    • Jan 2012
                    • 193
                    You'll probably get the inverter connector pinout by looking online for the datasheet for the panel. The pinouts tend to be fairly standard in my experience over a range of panels from different manufacturers.
                    • Kilroys
                      • Feb 2014
                      • 70
                      • Sweden
                      How about the voltage on pin 12 BL_ON/OFF, the blue wire
                      PL802. Whats the name of the controller ic on the inverter,
                      beginning with OZxxxx ?
                      • Hamie
                        • Apr 2014
                        • 1383
                        Ok so put the inverter back together.
                        I'm now thinking my other powersupply has developed a fault.
                        Basically If you turn the tv on without the inverter plugged in. Let it start up for around 30 seconds then plug in the inverter the tv works fine.
                        Unsure where to turn with this one! :-/
                        • Hamie
                          • Apr 2014
                          • 1383
                          Just thought id update some voltages going to the inverter.
                          With the inverter unplugged.
                          Red wires - 23.94 on all wires.
                          Black ground.
                          Orange 3.32
                          Blue - 3.23
                          When I turn the set on for 30 seconds then push in the inverter the voltages change to:
                          red wires - 22.29
                          Black all ground.
                          Orange - 3.32
                          Blue - 2.99
                          With the inverter plugged from start up all voltages briefly appear apart from the blue wire that gets to .5 - .7 volts then shuts down.
                          • repair-it
                            TOSHIBA DLP 52HM95 How to reset timer module on bulb
                            by repair-it
                            I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                            Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                            10-11-2023, 07:18 PM
                          • ezenia
                            LUMIMAN Smart Bulb IC ID?
                            by ezenia
                            I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                            In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                            04-28-2025, 05:56 PM
                          • x_orange90_x
                            Vizio E55-E1 bad backlights or bad inverter?
                            by x_orange90_x
                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                            I don't know how exactly to test the inverter itself. Is it...
                            01-29-2025, 09:24 PM
                          • Gentian
                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                            by Gentian
                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                            03-06-2023, 07:07 AM
                          • valvashon
                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                            by valvashon
                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                            01-04-2024, 01:44 PM
