Hisense H55U7B vertical stripes
This topic has been answered.
  • halen
    • Jun 2011
    • 16
    I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
    1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
    2. Connected only left side of LCD to tcon, big stripes
    3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
    Where could be problem?
    Tcon RSAG7.820.7932/ROH
    Main board RSAG7.820.8698/ROH
    Jan
  • Answer selected by halen at 07-05-2025, 12:02 PM.
    lotas
    • Jan 2016
    • 4616
    • Russia
    A common problem with these TVS diode assemblies (they have breakdown or leakage of zener diodes).
    • Diah
      • Feb 2013
      • 6376
      i would like to see yours mainboards with out heat sink of the SoC and the panel buffer boards side as yours test No 2
      • halen
        • Jun 2011
        • 16
        In this configuration of tcon was possible to view picture and use menu of TV. I will upload soc tomorrow. And one correction to previous test. When is connected tcon in this way and connect 12V, then RGB colours are switching normally and fast . White, red, green, blue, black. When I use second half of tcon then RGB is switching too, but slowly and lazy color change with some blurring colors together, but finally end on correct color.
        • Diah
          • Feb 2013
          • 6376
          this why i am interested on the Panel buffer boards side at yours post 2, you have there issue... but to know how SoC feeds LVDS we will know the / T-CON Panel function to analysis yours previous test
            • 12206
            • U.S.
            Well bad caps thanks for fuking up the layout of the site YET AGAIN, it really wasn't necessary. So make it hard to navigate by keeping on changing shit up, I just will be skipping this site.
            • Diah
              • Feb 2013
              • 6376
              this new layout and distances over posts are just money earning over advertising , but who thought to destroy to earn money are stupid. we are now at open source webs , we are now at 2025 not 1995 the time of Netscape browsers LOL
              • CapLeaker
                Leaking Member
                • 8180
                Hahaha! 95 Netscape browser... LMAO
                • halen
                  • Jun 2011
                  • 16
                  There are photos of main board soc, MSD6886NQHAT-8-00GH.
                  • Diah
                    • Feb 2013
                    • 6376
                    One SoC with GPU, so yours issue 100% at the Panel self, remove the metal cover of the bad side and inspect the buffer boards
                    • halen
                      • Jun 2011
                      • 16
                      I did it. Measure if there is something shorted, like capacitor or transistors, but all seeems ok.
                      • lotas
                        • Jan 2016
                        • 4616
                        • Russia
                        • halen
                          • Jun 2011
                          • 16
                          Part Is littelfuse SP1064E-04UTG (marking 4264H) And I did measurement And looks in good shape. No Ohm shortage to ground. Carefully checked rest of components on driver and nothing found. IT could be defective tcon or it is not possible?
                          • Diah
                            • Feb 2013
                            • 6376
                            you need to put only the bad side at RGB test as you did before , and monitor the Temperature of the ESD diode or zener one.... they read fine. but they are not realy good, so Temprtaure will be rise
                            • halen
                              • Jun 2011
                              • 16
                              Yes, I tested it already and temperature is normal, like other components. May I try to replace tcon or it is 100% sure, that tcon is ok? Because half of display switching colors normally, bad half slowly and I cannot find anything bad at all.
                                • 12206
                                • U.S.
                                I think they're trying to save money while trying to monetize by letting...I think first graders or chimps from the zoo, redesign the layout.
                                • Diah
                                  • Feb 2013
                                  • 6376
                                  try to mask tape only the pins 1 & 2 far left of the bad side, between temperature rise up by time not immediately
                                  • halen
                                    • Jun 2011
                                    • 16
                                    What exactly you mean with it? Isolate first two pins of flex cable? From tcon to driver?
                                    • Diah
                                      • Feb 2013
                                      • 6376
                                      1-2
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4337
                                        • Italy - Milan
                                        Hi, are you able to retouch or replace well solder tin on tcon big main chip? bye
                                        • halen
                                          • Jun 2011
                                          • 16
                                          Yes, I'm able to resolder main bag chip of tcon module. I did isolation of two pins and result is same.
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • kotel studios
                                            Samsung LC32HG70QQUXEN - vertical and horizontal stripes across the screen
                                            by kotel studios
                                            Just now my Samsung LC32HG70QQUXEN monitor gave up on me. On cold boots I get many vertical stripes going across the screen (see the attached picture). After it runs for 1-2 minutes those go away but there are horizontal stripes going across the whole screen no matter of the input and PCs I use. (couldn't take an picture of it since the image size goes to 20MB and the camera doesn't pick them up)
                                            In a video about a 27" monitor with an similar issue the guy removes one resistor and supposedly the entire monitor goes back to life? For sure this fix is only temporary....
                                            08-06-2025, 02:07 AM
                                          • ahoonid
                                            MacBook A1990 vertical stripes on external screen
                                            by ahoonid
                                            Hey everyone,
                                            I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                            The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                            Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                            06-20-2025, 08:54 AM
                                          • jason123
                                            Hisense 65R6E3 double-image / horizontal strips - TCON?
                                            by jason123
                                            Hello all. 3 years back, with your help, I replaced the LEDs on this TV. It's been working great. Yesterday, I turned it on (garage TV), and it has blurred horiz / vert lines as you see in photos. Definitely no physical hit or damage. Top 1/6th of the screen is perfect. Could it be main / TCON board? No tabs to cut on this model. Thank you...
                                            07-19-2025, 08:07 AM
                                          • kevinman
                                            KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
                                            by kevinman
                                            Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
                                            12-17-2023, 06:22 AM
