Hisense H55U7B vertical stripes
  • halen
    • Jun 2011
    • 15
    I have Hisense H55U7B TV with no picture, only big vertical stripes. I did several tests and I'm not sure, where is problem.
    1. Connected tcon to 12V, white, red, green, blue, black picture visible in cycle on full LCD without error
    2. Connected only left side of LCD to tcon, big stripes
    3. Connected only right side of tcon, visible normal picture on the right. Working as expected.
    Where could be problem?
    Tcon RSAG7.820.7932/ROH
    Main board RSAG7.820.8698/ROH
    Jan
  • Diah
    • Feb 2013
    • 6343
    i would like to see yours mainboards with out heat sink of the SoC and the panel buffer boards side as yours test No 2
    • halen
      • Jun 2011
      • 15
      In this configuration of tcon was possible to view picture and use menu of TV. I will upload soc tomorrow. And one correction to previous test. When is connected tcon in this way and connect 12V, then RGB colours are switching normally and fast . White, red, green, blue, black. When I use second half of tcon then RGB is switching too, but slowly and lazy color change with some blurring colors together, but finally end on correct color.
      • Diah
        • Feb 2013
        • 6343
        this why i am interested on the Panel buffer boards side at yours post 2, you have there issue... but to know how SoC feeds LVDS we will know the / T-CON Panel function to analysis yours previous test
          • 12083
          • U.S.
          Well bad caps thanks for fuking up the layout of the site YET AGAIN, it really wasn't necessary. So make it hard to navigate by keeping on changing shit up, I just will be skipping this site.
          • Diah
            • Feb 2013
            • 6343
            this new layout and distances over posts are just money earning over advertising , but who thought to destroy to earn money are stupid. we are now at open source webs , we are now at 2025 not 1995 the time of Netscape browsers LOL
            • CapLeaker
              Leaking Member
              • 7986
              Hahaha! 95 Netscape browser... LMAO
              • halen
                • Jun 2011
                • 15
                There are photos of main board soc, MSD6886NQHAT-8-00GH.
                • Diah
                  • Feb 2013
                  • 6343
                  One SoC with GPU, so yours issue 100% at the Panel self, remove the metal cover of the bad side and inspect the buffer boards
                  • halen
                    • Jun 2011
                    • 15
                    I did it. Measure if there is something shorted, like capacitor or transistors, but all seeems ok.
                    • lotas
                      • Jan 2016
                      • 4459
                      • Russia
                      A common problem with these TVS diode assemblies (they have breakdown or leakage of zener diodes).
                      • halen
                        • Jun 2011
                        • 15
                        Part Is littelfuse SP1064E-04UTG (marking 4264H) And I did measurement And looks in good shape. No Ohm shortage to ground. Carefully checked rest of components on driver and nothing found. IT could be defective tcon or it is not possible?
                        • Diah
                          • Feb 2013
                          • 6343
                          you need to put only the bad side at RGB test as you did before , and monitor the Temperature of the ESD diode or zener one.... they read fine. but they are not realy good, so Temprtaure will be rise
                          • halen
                            • Jun 2011
                            • 15
                            Yes, I tested it already and temperature is normal, like other components. May I try to replace tcon or it is 100% sure, that tcon is ok? Because half of display switching colors normally, bad half slowly and I cannot find anything bad at all.
                              • 12083
                              • U.S.
                              I think they're trying to save money while trying to monetize by letting...I think first graders or chimps from the zoo, redesign the layout.
                              • Diah
                                • Feb 2013
                                • 6343
                                try to mask tape only the pins 1 & 2 far left of the bad side, between temperature rise up by time not immediately
                                • halen
                                  • Jun 2011
                                  • 15
                                  What exactly you mean with it? Isolate first two pins of flex cable? From tcon to driver?
                                  • Diah
                                    • Feb 2013
                                    • 6343
                                    1-2
                                    • Davi.p
                                      • Sep 2009
                                      • 4270
                                      • Italy - Milan
                                      Hi, are you able to retouch or replace well solder tin on tcon big main chip? bye
                                      • halen
                                        • Jun 2011
                                        • 15
                                        Yes, I'm able to resolder main bag chip of tcon module. I did isolation of two pins and result is same.
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • ahoonid
                                          MacBook A1990 vertical stripes on external screen
                                          by ahoonid
                                          Hey everyone,
                                          I bought a MacBook A1990 with no screen. I bought it knowing the motherboard was defective but wasn't sure what the problem was until I received it. It actually turns on but as you see from the attachment, it has vertical stripes, on an external screen!!
                                          The board is neat. Not opened before for sure. Just a little dust, nothing more.
                                          Recovery using wifi can be opened, as can also be seen in the photo but it doesn't go all the way through after connecting it to a wifi. It downloads the initial Recovery files but never completes the rest of the...
                                          06-20-2025, 08:54 AM
                                        • kevinman
                                          KD-55X9005A Vertical Stripes Right Side Mirrored Vertically At Start
                                          by kevinman
                                          Hi, TV boots with distorted image right side mirrored verticaly sometimes vertical stripes making off-on turns picture to normal and "perfect" (netflix image) that I highly doubt this is something related with t-con signal lines?? rather it looks software corruption bad mem chips voltage collapse or an intantaneous fault with fluctuating powerboard voltages?? As it happens usually when TV is cold sometimes fault comes back after a full day use should I check powerboard voltages with oscilloscope??
                                          12-17-2023, 06:22 AM
                                        • mopenstein
                                          Looking for Vertical IC for RCA Chassis CTC159L CRT
                                          by mopenstein
                                          I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
                                          Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
                                          I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
                                          09-24-2023, 10:41 AM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
