LG 55LD520 wont turn on
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: LG 55LD520 wont turn on
    Post 11 in the thread I keep asking you to read.
    • burner6999
      • Jun 2012
      • 89
      Just to be clear the little black things by the capacitors are the mosfets? Also do I need to remove them to test them?
      Pin 1-2 1.9
      Pin 1-3 1.9
      Pin 2-3 0.7
      It is the same across all of them I tested the ones on slave 2 and nothing happened on the multimeter.
      • Ltank
        • Jun 2013
        • 776
        Mosfet have a Q number. 3 legs and a tab. The middle leg is electrical the same. The tab and under side are difficult to remove because it is also the heat sink. They are in parallel so if one is shorted all will show bad. Damaged mosfet is not always obvious
          Pin 1-2 1.9
          Pin 1-3 1.9
          Pin 2-3 0.7
          Are those readings in Ohms, K Ohms, M Ohms?
          • burner6999
            • Jun 2012
            • 89
            I had the meter set at 200ohms. I went ahead and ordered a new board. I will post back and let you know if it works. Thanks guys.
              OK, they are shown as shorts, thanks.
              • burner6999
                • Jun 2012
                • 89
                Just wanted to let everyone know that I got the board today and it solved my problem. Thanks to everyone that helped in finding a solution.
                • 102mm
                  • Dec 2013
                  • 181
                  • us
                  #28
                  Thank you! You guy/gals in this forum have fixed another TV! I had two bad FETs on my slave 2 board. I pulled them off and the TV powered up as normal. Now I just have to find a way to order the replacement parts.. thanks to you all!
                  Craigslist Picks & Fixes
                  2 ea - Samsung 52"
                  Samsung 60"
                  • lostone
                    Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                    by lostone
                    Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                    First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                    When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                    05-19-2024, 11:40 AM
                  • RdeveLabs
                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                    by RdeveLabs
                    To all the members here...
                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                    05-05-2025, 04:59 AM
                  • robante15
                    Acer Aspire 4520 won't turn on after reboot
                    by robante15
                    Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                    It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                    The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                    If I remove the...
                    04-06-2024, 06:50 PM
                  • masoksian
                    Dell latitude e7470 not turn on .power buton on off and Run Power problem
                    by masoksian
                    I am dealing with the problem of turning on and off my Dell e7470 notebook.
                    The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                    The system does not turn on, there is no post.
                    I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                    The problem continues in the same way.
                    I tried to turn on the Fn key, nothing came to the screen....
                    02-15-2025, 12:08 PM
                  • dqtech
                    lenovo x240 nm-a091 wont turn on
                    by dqtech
                    i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                    board number VIUX1 NM-A091 REV:1.0...
                    02-07-2024, 01:57 AM
