VIZIO E320-A1... Gets power but no picture
  • p2computing
    • Jul 2014
    • 49
    Hi everyone. Such a fantastic forum!
    I have a Vizio E320-A1 that is getting power but has no picture nor sound.
    Here is what I currently know
    White light stays solid when pressing the power button
    Capacitor C9810 reads 165-170 DCV
    From here, I am at a loss. I am not an expert with electronics but will do my best to follow along and provide feedback while testing.
    --The EEPROM is labled on the board as U409--
    Looking forward to getting this TV working for my kids! =)
    Re: VIZIO E320-A1... Gets power but no picture
    Can you read the numbers as printed on the white bar code sticker on the power supply board for me so I can find out if shojimmy will have good pictures of both sides of the board?
    • martino
      Not so "senior"
      • Aug 2013
      • 997
      • canada
      165-170 DCvolt on main filter cap when pressing the power button means the power supply doesn't come oput of standby(165 when in standby,394volt DC when active)
      We need to figure out if the mainboard even tries to turn the power board on.
      Can you post a close up picture of the connector that runs from the power board to the main board? That shows the legend printed near the connector?
      Proud owner of dozens of broken TV's and many,many,many boards.
      Our website and passion:http://hollenhundshepherds.com/
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        sry budm,we crossed posts, Your on stage,while I sneak off to the side line lol
          I think this is your board:
          http://www.shopjimmy.com/vizio-adtvc...upply-unit.htm
          It also has the EEPRROM IC, so that can be one possible problem:
          http://www.shopjimmy.com/catalogsear...=VIZIO+E320-A1
          Hi Matino, this board does not have PFC since it is an LED BACKLIT which consumes little power, they left the PFC parts (L9801, D9802, Q9801, etc.) out.
          • martino
            Not so "senior"
            • Aug 2013
            • 997
            • canada
            oops,surely didn't know that..!!
            Saw this setup and got enthusiastic lol (pic)
            Sry for the interruption,carry on
              No problem, we are all here to learn, I just hope it is not EEPROM problem since it is hard to isolate software problem from hardware problem.
              Once we verify that is is the same board as shown at SJ then we can use those pictures SJ, I really have to give credit for putting ups lots of really good pictures.
              • p2computing
                • Jul 2014
                • 49
                Thanks for the start on this one fellas! (martino, i think that's the board i've got)
                Here are two images. White background is power, green is mainboard.
                Let me know what is needed next =)
                  OK, your board is really close to what SJ has on the web site.
                  Using the black probe on the chassis then take the DC Voltage readings on connector CN9902 (13 PINS) and report the reading on each pins as shown in the pictures when TV is OFF and when TV is ON:
                  For example
                  PIN1.NC = no need to test this one
                  PIN2. 5.2V = XXXV (OFF), XXXV (ON)
                  PIN3. 5.2V = XXXV (OFF), XXXV (ON)
                  PIN4. PS_ON = = XXXV (OFF), XXXV (ON)
                  • p2computing
                    • Jul 2014
                    • 49
                    Found the connector. Here are my readings for the TV plugged in, unsure if powered on.
                    Edit: If i leave the TV unplugged for a bit, i can plug it in without the white light illuminating. This allows me to press the power button to turn it on, but pressing the power button again does not turn it back off.
                    Pin2: on= 5.29 (same when off)
                    Pin3: on= 5.29 (Same when off)
                    Pin4: on= 4.86, off= 0.08
                    • p2computing
                      • Jul 2014
                      • 49
                      Anything else I can test for now?
                        I need the reading of the rest of the pins except the GND pins. So far the, 5.2V, PS_ON are OK.
                        • p2computing
                          • Jul 2014
                          • 49
                          No problem!
                          :Pin:
                          1 - n/a
                          2 - Same as before
                          3 - Same as before
                          4 - Same as before
                          5 - OFF=0 /ON=24.9
                          6 - OFF=0 /ON=24.9
                          7 - OFF=0 /ON=0
                          8 - OFF=0 /ON=0
                          9 - OFF=0 /ON=0
                          10 - OFF=0 /ON=12.4
                          11 - OFF=0 /ON=12.4
                          12 - OFF=0.04 /ON=0
                          13 - OFF=0.02 /ON=0
                          Added all pins for sake of ease
                          • p2computing
                            • Jul 2014
                            • 49
                            Anything else i can add to keep this thread alive?
                            Once again, greatly appreciate the assistance Budm!
                              OK, you do have two bad signals from the main board: Pin12 the Dimming signal, and the Backlight on (ON/OFF) pin13 are not being sent from the main board.
                              So you do have bad main board problem. The question is, is it the EEPROM problem or something else, I do not know for sure.
                              I would look and see or contact shopjimmy to see if the EEPROM will solve the problem or the main board will have to be replaced, just tell them that you are not getting any ON/OFF signal for turning on the inverter board.
                              • TechOp
                                • Oct 2013
                                • 21
                                I'm going thru my stock pile of vizo parts.....I think I have 2 of these Tvs with broken LCDs.
                                Will check back
                                sigpic
                                Anything can be fixed with enough TIME and enough MONEY
                                • p2computing
                                  • Jul 2014
                                  • 49
                                  Awesome thanks Bud and also TechOp.
                                  I will contact ShopJimmy and see what he has to say
                                  • p2computing
                                    • Jul 2014
                                    • 49
                                    Response from shopjimmy is as follows:
                                    Here are the most common malfunctions associated with EEPROMs:
                                    - On screen display is stuck on logo screen
                                    - TV won’t power on with remote or buttons (LED indicator remains same color)
                                    - TV won’t turn on after being off for 30+ minutes
                                    - TV shuts off by itself during channel scan or when switching inputs
                                    - TV turns on and is stuck in color test pattern mode forever
                                    - TV turns on but there is no backlight (LED indicator shows TV is on but there is no image)
                                    Think this means potential EEPROM replacement needed?
                                      "- TV turns on but there is no backlight (LED indicator shows TV is on but there is no image)" Your set has this problem, no backlights due to no on command from the main board to the inverter board. I do not know how much the replacement board or the EEPROM are. If the EEPROM does not fix the problem due to other failure then you will end up buying the new board.
                                      • p2computing
                                        • Jul 2014
                                        • 49
                                        Sounds conclusive. I will purchase a replacement EEPROM and solder it on.
                                        • csmith
                                          Vizio D50u-D1 Powers up no picture
                                          by csmith
                                          I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                                          Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                                          supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                                          issue. Set will power up with remote but not power off....
                                          07-11-2025, 11:52 AM
                                        • gavric
                                          Vizio M70-C3 Half picture is bad, main board on its last leg?
                                          by gavric
                                          Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
                                          When tv powers on vizio V logo shows nice on whole screen. picture 1
                                          When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
                                          When i start youtube picture shows on left side fine, right is all scrambled. pic 2
                                          When i click video to start playing picture goes black(like when you change...
                                          09-02-2021, 08:55 PM
                                        • ggil44
                                          Vizio M65-E0 No Picture, No Sound
                                          by ggil44
                                          Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
                                          09-03-2024, 08:30 PM
                                        • maricm
                                          Vizio m65-c1 picture flashing on and off on the screen
                                          by maricm
                                          HI all,
                                          hope someone point to the possible issue before I start buying replacement parts.
                                          Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
                                          Backlight stays on all the time,
                                          Sound works fine.
                                          screen keeps changing form black to full picture in about 1sec intervals.
                                          Picture looks fine with no visible artifacts.
                                          I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
                                          Disconnecting left and right ribbons on...
                                          11-25-2023, 06:32 PM
                                        • Fly_Among_Stars
                                          VIZIO E70-E3 Half picture with half TCON
                                          by Fly_Among_Stars
                                          I have a VIZIO E70-E3.
                                          Symptoms: Black screen, no picture, but LED backlights are working.
                                          I probed the power board and voltages are as listed on the board.
                                          Main board appears fine, too.
                                          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                                          There are two separate ribbon cables feeding the LCD.
                                          If both are connected, the screen is black.
                                          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                                          04-24-2023, 08:20 PM
