Samsung Power Supply Board BN44-00874F
    • 12196
    • U.S.
    #81
    You don't see a resistor there because there isn't one.
    • Nicktronic
      • Mar 2023
      • 247
      All the SMD resistors test fine as far as I can tell.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4330
        • Italy - Milan
        #83
        what you use to remove the insulating glue? primary side of the two transformers tested? CM801s , CM802s, DM807 Tested? what voltage on cathode of DM807?
        • Nicktronic
          • Mar 2023
          • 247
          I used isopropyl, a brush and a plastic spudger. All components tested good. Cathode of DM807 on power up was 5.45VDC slowly discharging at a rate of 0.01vdc/second
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4330
            • Italy - Milan
            #85
            Search in secondary side for a TL431 or equivalent in sot23 and replace it, 5,5v is too low, before it check the main stage ic primary side with its datasheet, if vcc is as usual around 16v then is so..
            • Nicktronic
              • Mar 2023
              • 247
              Hi, I will get to this, just been really busy!
                by sam_sam_sam
                After all of...
                07-13-2024, 08:14 PM
              • repair-it
                Need advice testing a samsung power supply board with scope
                by repair-it
                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                07-12-2025, 11:00 AM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                by ohren
                09-08-2023, 05:24 PM
