Samsung Power Supply Board BN44-00874F
Ok, not exactly sure but might be able to get a clue by testing resistance from neg. leg of filter cap to pin 10 VCC, see what you get, done with tv unplugged from power.Last edited by nomoresonys; 03-19-2025, 01:11 PM.Comment
I am not mistaken in this case, in post #10, the datasheet clearly labels pin 12 as VCC, so it must not have been a match to your IC.Last edited by nomoresonys; 03-20-2025, 06:27 AM.Comment
Maybe reflow the solder joints on the transformers and anything on a heatsink or any others that may need it, just in case it's a simple thing like that.Comment
Can you post a good clear picture of that IC and the mosfet area you replaced? can be two pictures just need a little more detail.Comment
Make sure none of the resistors are bad or have risen in value, it doesn't take much to mess up the balance.Comment
Guess this ones too tough for me, maybe test all your blue ceramic caps on top of board, test them in ohm mode in circuit, they should probably read in the m or k ohms. They can be bad and not show externally, I assume you did check all the solder joints paying extra attention to transformers and things on heatsinks, the joints can get micro-cracks that are not easily detected. Just tried this test but didn't work on my meter tho.Last edited by nomoresonys; 03-21-2025, 09:06 AM.Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... - Loading...
