There's some very smart folks on youtube, diving deep into how these boards work. In some basic ways they all work the same but of course there's just enough variance in some to make it complicated at times.
Samsung Power Supply Board BN44-00874F
I will. Is there any chance it could be the FA6B22N?? I was saying that there was 7 volts on the FB line, but am not sure if that is normal or possibly is keeping the IC from fully operating...Comment
If you have not, check DP802 and 803 Diodes on underside of board by the big caps. Also double check all those resistors, make sure none are open or drifted.Comment
I would switch it out. Sometimes it's just easier, specially if you don't have an accurate cap tester.Comment
Seems like we covered most of the potential faults, if it's not a bad solder, resistor, cap, guess that leaves the pfc IC. Guess you can check it for a short. I believe there's only one ground, maybe check, with tv unplugged, neg probe on neg leg of filter cap/hot ground, positive probe on each pin of IC, make sure only one pin has continuity as in only one will show 0 ohms or beep in continuity/diode mode if meter has that feature, same as testing a fuse.Comment
Well test QP802CS, should prolly test the same as QP801CS, the numbers on them are the same, yes?Comment
It would be easy enough to change out all the parts listed at the bottom of that parts kit. Those 4 blue caps and the 2 transistors, one of which you already changed out.Comment
Checks out ok, no shortsSeems like we covered most of the potential faults, if it's not a bad solder, resistor, cap, guess that leaves the pfc IC. Guess you can check it for a short. I believe there's only one ground, maybe check, with tv unplugged, neg probe on neg leg of filter cap/hot ground, positive probe on each pin of IC, make sure only one pin has continuity as in only one will show 0 ohms or beep in continuity/diode mode if meter has that feature, same as testing a fuse.Comment
I'm at a loss....everything I've checked seems ok, but I'm having trouble following the circuit to understand exactly where the 10VDC (that should be 14-29) is sourced from. It appears to start tapped off that big transformer and through a diode, but how is the TXFMR producing V without any switching happening. Does anybody have a schematic close to BN44-00874F?? Can anybody confirm that this board should be fully on when on the bench (like other samsung power supply boards), or do I need to install it?Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by repair-itI am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
by CooperrI picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board... -
by sam_sam_samI was working on this CNC machine today found no keyboard functioning no control relay powering on
The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
Found shorted diodes on main controller relays there are 3 of them that... - Loading...
