Samsung Power Supply Board BN44-00874F
  • nomoresonys
    • 12332
    • U.S.
    #81
    You don't see a resistor there because there isn't one.
    • Nicktronic
      • Mar 2023
      • 247
      All the SMD resistors test fine as far as I can tell.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4544
        • Italy - Milan
        #83
        what you use to remove the insulating glue? primary side of the two transformers tested? CM801s , CM802s, DM807 Tested? what voltage on cathode of DM807?
        • Nicktronic
          • Mar 2023
          • 247
          I used isopropyl, a brush and a plastic spudger. All components tested good. Cathode of DM807 on power up was 5.45VDC slowly discharging at a rate of 0.01vdc/second
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4544
            • Italy - Milan
            #85
            Search in secondary side for a TL431 or equivalent in sot23 and replace it, 5,5v is too low, before it check the main stage ic primary side with its datasheet, if vcc is as usual around 16v then is so..
            • Nicktronic
              • Mar 2023
              • 247
              Hi, I will get to this, just been really busy!
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                After all of...
                07-13-2024, 08:14 PM
              • repair-it
                Need advice testing a samsung power supply board with scope
                by repair-it
                I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                07-12-2025, 11:00 AM
                Mitsubishi CNC switching power supply board dead / relay board bad diode failure
                I was working on this CNC machine today found no keyboard functioning no control relay powering on
                The screen powered on and was giving an operation error but the manual was not very clear about what the error exactly was but with a little bit of troubleshooting and finding out that the control relays not powering on and no keyboard functions we narrowed down to this one switching power supply which of course does not have any indicator LED light they are on the keyboard interface/relay controller board
                Found shorted diodes on main controller relays there are 3 of them that...
                01-07-2023, 05:43 PM
              • Cooperr
                Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                by Cooperr
                I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                10-21-2025, 01:11 PM
