Samsung Power Supply Board BN44-00874F
    • 12145
    • U.S.
    #41
    There's some very smart folks on youtube, diving deep into how these boards work. In some basic ways they all work the same but of course there's just enough variance in some to make it complicated at times.
    • Nicktronic
      • Mar 2023
      • 247
      I will. Is there any chance it could be the FA6B22N?? I was saying that there was 7 volts on the FB line, but am not sure if that is normal or possibly is keeping the IC from fully operating...
      • lotas
        • Jan 2016
        • 4589
        • Russia
        #43
        I posted a pdf in post 20. Your VCC supply is underestimated 10v, but it should be about 18-22v​
          • 12145
          • U.S.
          #44
          I wonder if CP810 is ok.
            • 12145
            • U.S.
            #45
            If you have not, check DP802 and 803 Diodes on underside of board by the big caps. Also double check all those resistors, make sure none are open or drifted.
            • Nicktronic
              • Mar 2023
              • 247
              Thank you all, I will check tomorrow.
              • Nicktronic
                • Mar 2023
                • 247
                Good
                • Nicktronic
                  • Mar 2023
                  • 247
                  They test good.
                  Which resistors? I've checked all the through ones and think they're ok.
                  • Nicktronic
                    • Mar 2023
                    • 247
                    With power applied on the bench, CM814 and CM815 have 10VDC, equal to the VCC of ICM801S, but CM810 reads 0VDC. Not sure what role it exactly plays, but there should be something right? Sure would love a schematic! 😬
                      • 12145
                      • U.S.
                      #50
                      I would switch it out. Sometimes it's just easier, specially if you don't have an accurate cap tester.
                        • 12145
                        • U.S.
                        #51
                        Seems like we covered most of the potential faults, if it's not a bad solder, resistor, cap, guess that leaves the pfc IC. Guess you can check it for a short. I believe there's only one ground, maybe check, with tv unplugged, neg probe on neg leg of filter cap/hot ground, positive probe on each pin of IC, make sure only one pin has continuity as in only one will show 0 ohms or beep in continuity/diode mode if meter has that feature, same as testing a fuse.
                        • lotas
                          • Jan 2016
                          • 4589
                          • Russia
                          #52
                          Well, if this is a frequent malfunction, check the other components that are in the Repair list...
                            • 12145
                            • U.S.
                            #53
                            What ohm reading are you getting on that cap?
                              • 12145
                              • U.S.
                              #54
                              Well test QP802CS, should prolly test the same as QP801CS, the numbers on them are the same, yes?
                                • 12145
                                • U.S.
                                #55
                                It would be easy enough to change out all the parts listed at the bottom of that parts kit. Those 4 blue caps and the 2 transistors, one of which you already changed out.
                                • Nicktronic
                                  • Mar 2023
                                  • 247
                                  Yes lotas, this is exactly what I did to start the repair. But I'm still having this issue. I will check again though...
                                  • Nicktronic
                                    • Mar 2023
                                    • 247
                                    Checks out ok, no shorts
                                    • Nicktronic
                                      • Mar 2023
                                      • 247
                                      Rechecked, they are good and the same.
                                      • Nicktronic
                                        • Mar 2023
                                        • 247
                                        I'm at a loss....everything I've checked seems ok, but I'm having trouble following the circuit to understand exactly where the 10VDC (that should be 14-29) is sourced from. It appears to start tapped off that big transformer and through a diode, but how is the TXFMR producing V without any switching happening. Does anybody have a schematic close to BN44-00874F?? Can anybody confirm that this board should be fully on when on the bench (like other samsung power supply boards), or do I need to install it?
                                          • 12145
                                          • U.S.
                                          #60
                                          Did you replace CM810?
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • repair-it
                                            Need advice testing a samsung power supply board with scope
                                            by repair-it
                                            I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                            07-12-2025, 11:00 AM
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
