There's some very smart folks on youtube, diving deep into how these boards work. In some basic ways they all work the same but of course there's just enough variance in some to make it complicated at times.
Samsung Power Supply Board BN44-00874F
I will. Is there any chance it could be the FA6B22N?? I was saying that there was 7 volts on the FB line, but am not sure if that is normal or possibly is keeping the IC from fully operating...Comment
If you have not, check DP802 and 803 Diodes on underside of board by the big caps. Also double check all those resistors, make sure none are open or drifted.Comment
I would switch it out. Sometimes it's just easier, specially if you don't have an accurate cap tester.Comment
Seems like we covered most of the potential faults, if it's not a bad solder, resistor, cap, guess that leaves the pfc IC. Guess you can check it for a short. I believe there's only one ground, maybe check, with tv unplugged, neg probe on neg leg of filter cap/hot ground, positive probe on each pin of IC, make sure only one pin has continuity as in only one will show 0 ohms or beep in continuity/diode mode if meter has that feature, same as testing a fuse.Comment
Well test QP802CS, should prolly test the same as QP801CS, the numbers on them are the same, yes?Comment
It would be easy enough to change out all the parts listed at the bottom of that parts kit. Those 4 blue caps and the 2 transistors, one of which you already changed out.Comment
I'm at a loss....everything I've checked seems ok, but I'm having trouble following the circuit to understand exactly where the 10VDC (that should be 14-29) is sourced from. It appears to start tapped off that big transformer and through a diode, but how is the TXFMR producing V without any switching happening. Does anybody have a schematic close to BN44-00874F?? Can anybody confirm that this board should be fully on when on the bench (like other samsung power supply boards), or do I need to install it?Comment
Assuming...7 Photos -
by sam_sam_samI did not have any 27uf @ 50 volt capacitors but one nice thing is that it has enough room for two capacitors in parallel a 22uf and a 4.7uf @ 50 volts 22 plus 4.7 equals 26.7uf which so very close to 27uf I will show some pictures of it sometime tomorrow
After all of... -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by ohrenI hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
The models launched in 2018 and 2019 respectively.... -
by C152HeavySamsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
Summary for TL-DR readers:
• VCC pin (18) of PFC... - Loading...
