Sony KDL32L5000 screen stays black but audio works fine
  • Mandraco
    • Apr 2013
    • 50
    • Puerto Rico
    Hello friends, I'm having trouble with a Sony LCD tv, at first it showed some vertical lines but they were incomplete lines. Some started at the top solid green in color and started fading the nearer they got to the center of the screen others faded near the fourth quarter of the screen. Others looked faded in the center of the screen and hot more solid as they approached the bottom while some others crossed the screen from top to bottom. There was about four consecutive horizontal lines at the top of the screen and near the bottom half.
    Well, I put it aside until recently when I took a look inside the t.v. I couldn't see any bulged or leaking caps so I tried to check the small board connected to the LCD panel.
    1- I removed the flex cable going from the board( I think it is called T control) and saw no image so...
    2- I connected the flex back,this time TV was still ON. The screen turned white entirely.
    3- I turned TV off and reseated the cable, turned it ON and now the screen was black.
    4- I hooked up my DVD via Red,Yellow,White cables and managed to get to the input until I heard sound. Now that's the current state of my TV.
    I notice the relay clicks 1-2 seconds after I plug it to the electric outlet and clicks again approx. 2 seconds after the first click. I removed the cord from the electric outlet and removed the connector going from POWER board to AV board and plugged the TV back to the outlet, there was no click at all. Also there is a series of very rapid clicks when I disconnect the TV from electricity after it has been on for a while, they sound like TRRRR.
    I tested the 14- pin connector going from POWER board to AV board, connector CN6201 the readings are with TV ON / TV OFF for each of the colors from top to bottom. Readings from the connector are as follows:
    At the top there is a pin labeled "REG 12V" This one is unused, the others correspond to a cable which color I mention along with the reading for it.
    THE UNUSED PIN ALSO READS 0 / 11.89
    The next are marked REG 12V
    BLACK= 0 / 11.89
    BROWN= -0, 0 / 11.89
    RED= 0 / 11.89
    The next are marked REG12V GND
    ORANGE= 0 / -0
    YELLOW= -0,0 / -0
    GREEN= 0 / -0
    The next are marked UREG 15V AU-GND
    BLUE= 0 / -0t
    PURPLE= 0 / -0
    GRAY= 0 / 16.56
    WHITE= 0 / 16.56
    The next is marked SYBY 3.3V
    BLACK= 3.26-3.31 / 3.31
    The next is marked AC DET
    BROWN= 2.81 / 2.79
    The next is marked P ON
    RED= 0.02 / 2.72
    Any help would great, I reposted this here since by an error I originally posted to the "Announcements and Related News" section, sorry for any confusion that may cause and thanks in advance.
    • 31047
    Re: Sony KDL32L5000 screen stays black but audio works fine
    can you post a foto of the power supply.
    • Mandraco
      • Apr 2013
      • 50
      • Puerto Rico
      Thanks for the reply, yes, I can but I'm using a cell phone, is there a limit for size, resolution of pictures?
        • 31047
        no, bigger is better - but upload them.
        dont link to a foto host.
        • Mandraco
          • Apr 2013
          • 50
          • Puerto Rico
          Hello, I'm having trouble attaching the pictures from my windows phone, it seems I need to find a working PC since mine is dead for a couple of months now. I'll try to get to a PC and then upload them. Or maybe I can try to upload them to my file sharing account and use the "upload from URL" option. What should I do, friend?
            • 31047
            upload from url should work.
            • Mandraco
              • Apr 2013
              • 50
              • Puerto Rico
              Hello stj, I thought I could use mediafire to upload you my pictures but the service's loader doesn't work either. I was able to upload pictures to SkyDrive, though I can't get the link to the folder in order to share it here. Any other ideas as to how can I upload the pictures? I'm using a Lumia 920, since my laptop is having problems with startup... This is so frustrating :-/
              • Mandraco
                • Apr 2013
                • 50
                • Puerto Rico
                Hello, stj, at least I got my hands on a PC I attached three pictures: The first one is a full view of the back of the TV without the back cover, the second is a closeup of the POWER board and the other is a closeup of the connector where I tested all those PINs (CN6201 ), I hope that helps you a bit, thanks for the patience.
                  • 31047
                  1st thing that comes to mind,
                  where the fuck did all that rust come from??????
                  • Mandraco
                    • Apr 2013
                    • 50
                    • Puerto Rico
                    Well I live in a tropical place, the weather changes unexpectedly every day and maybe that has some effect on that guard. Every price of electronics I've checked is the same after a couple of years of normal use. I have noticed some devices accumulate dust and that dust creates an area of oxidation on the metal plates covers in many of them, mostly video games consoles.
                    Does the rust matters? I've seen TVs that look worse than this which are completely functional, though.
                      So right now, do you still have 12VDC on both ends of the SMD F1 on the T-CON board? I have a feeling you have bad panel.
                        • 31047
                        rust matters on chip or transistor pins because they are close enough for it to touch.
                        and lead-free solder can rust - i'v seen it!
                        • Mandraco
                          • Apr 2013
                          • 50
                          • Puerto Rico
                          I have read other threads here and some asked to test some "dots" found on the TCON board, I don't remember all the names for each one of those little dots(VCC, VSS, VON and such) but most of them bring no reading on my multimeter. About the SMD FUSE you might be referring to one marked FP1,looks made out of ceramic, at its right is one of those dots labeled VIN, below the FP1, CON1 is located(the cable coming from the board which has all the video and audio inputs.
                          I'm not home now, I'll check the fuse when I arrive and report back to you, thanks.
                          • Mandraco
                            • Apr 2013
                            • 50
                            • Puerto Rico
                            I know about the corrosion you talk about, but what I've seen is more like green or blueish in color than the brown/red of this one. I checked the pins and they are OK, no rust or corrosion detected. I live in Puerto Rico so maybe the corrosion in the metal Shields are expected. Most if the equipment is like that, over here you can have a hot day with temperature around 95 degrees and suddenly it starts to rain and you cam see the steam raising from the ground. The greater portion of population lives in rural homes like myself, that means no air conditioner which means old fashioned ventilation with windows open 24/7 and a lot of dust comes into the house. I also live 7 miles from the coast... Too many factors to consider but it affects mainly exposed metal, but if you look closer the picture you will see the RCA connectors metal on the outside is like new, no rust. That makes me think it has more to do with the high temps under that shield, as it happens with cars exhausts/ mufflers.
                            • bammbammfran
                              • Apr 2014
                              • 476
                              Since you use to have a picture with some lines and now no picture, I would opt to try a new t-con board if you can find one at a decent cost
                              • Mandraco
                                • Apr 2013
                                • 50
                                • Puerto Rico
                                Hello, I used my multimeter at 20 VDC and placed the BLACK probe on the chasis/ metal to which the boards are adjusted and the RED probe to each side of the FP1 FUSE with the TV turned on(I could see the backlight): on one side I get 11.86 while on the other I only get 0.18.
                                I have read some threads and see they ask about the readings on some spots or dots that look like open trails. I think they are there so you can pinpoint the component giving you trouble or at least to know how much Voltage you get to specific areas or components like ICs, connectors and so on. I can check them and post the results later. What should I do now?
                                  • 31047
                                  fuse is bad.
                                  maybe for fun, maybe because of something else.
                                  • Mandraco
                                    • Apr 2013
                                    • 50
                                    • Puerto Rico
                                    I don't understand what you mean by this. What is for fun or because something else? Should i get a FUSE replacement?
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      some fuses can blow for no apparent reason something else maybe a shorted capacitor etc etc i would just replace the fuse with the correct amps and voltage and try it.
                                        The fuse may have blown due to this:
                                        "2- I connected the flex back,this time TV was still ON. The screen turned white entirely"
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
                                        • Adam Russ
                                          Black screen on Sony 65x90ch (65x900h from Costco)
                                          by Adam Russ
                                          Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                          09-15-2024, 05:46 PM
