Transformer substitution - Sanyo DP42849-01
    • 31300
    Re: Transformer substitution - Sanyo DP42849-01
    frequency counter should be fine if you use it between the chip and fet.
    and put a ceramic cap between the counter & target circuit to block dc.
    just remember that the counter is 5v so it really wont like higher voltages on it's pins.
    the same applies to comercial counters btw.
    • lookimback
      • Aug 2013
      • 1489
      I was just thinking about that. Because whatever the frequency is between the chip and the FET, it will be the same at the transformer.
      Now, I still need to figure how to determine the transformers inductance (LCR meter?), and it's input voltage and current rating. Is the input voltage the same as at the PFC?
      ------------signature starts here------------
        • 31300
        o.k.
        at these prices - not worth making stuff anymore!
        http://www.ebay.de/itm/251555691479
        you can get inductance with an LCR meter.
        this thing does it all!!
        (i'm getting one!)
        • lookimback
          • Aug 2013
          • 1489
          Now, would I need to get the inductance from the secondary or primary? And powered on or off?
            You can use LCR meter. BTW, how did you determine the turn count? There are two High voltage secondary windings, and two primary windings (connected in parallel) from what I see looking at the bottom side of the board.
            • lookimback
              • Aug 2013
              • 1489
              I carefully unwrapped a bad transformer. Those numbers are only for one side so they are probably incorrect. Each primary and each secondary have the number of turns I posted in post #2.
                Man, you sure did the details works and lots of patience.
                • lookimback
                  • Aug 2013
                  • 1489
                  And I did it all twice so. Wanted to make sure I didn't miscount.
                  Here's the bottom view of one of the transformers. With pin out.
                  • lookimback
                    • Aug 2013
                    • 1489
                    Oh, if they're parallel then the numbers would be correct.
                      • 31300
                      you counted the secondarys?
                      want to tell us how long that took!
                        BTW, when you unspool all those wires, did you see any burnt wires, broken wires, if not, the transformer may not be bad then?
                        • lookimback
                          • Aug 2013
                          • 1489
                          I had high resistance on one of the secondarys. 1k. Good transformer was 26-27 ohms. Both were measured out of board. Plus, board worked with the good transformer which came from a board with bad PWM. I just swapped them out because the new PWM hadn't arrived yet. I did find a break in the one. The second one I didn't unwrap the bad side, it's still soaking. One I did a couple months ago burnt right at the pin but I didn't realize it until after I broke the ferrite trying to get it apart. I think I could have fixed that one.
                          • lookimback
                            • Aug 2013
                            • 1489
                            Secondarys didn't take long. Here's a pic. Each section has 110 turns.
                            • lookimback
                              • Aug 2013
                              • 1489
                              OK, I ordered these.
                              http://www.ebay.com/itm/121326345997...84.m1439.l2649
                              http://www.ebay.com/itm/Green-0-1MHz...item3ce27ddcb1
                              I'd rather have some higher quality equipment but I'll get better stuff eventually.
                              Now, how can I determine input voltage and power ratings? My Fluke can't read the high frequency input current.
                              • lookimback
                                • Aug 2013
                                • 1489
                                Got another one today with a bad secondary. 27 ohms on one side, 1.7k on the other. I might have found a way to get them apart. I soaked one of the broken ones in PVC pipe cleaner for 3 days and got it to come apart. So I'm soaking just the secondarys until this time Friday. I also made a pulling jig so I can evenly pull the ferrites without using pliers. Fingers are crossed. I'm still going to try to find a suitable replacement too. I'm trying to get a CRT oscilloscope, a HV differential probe, and some other stuff, from ebay.
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  Got the transformer wire today. Made this jig and am working on the first one. So far, so good. Resistance on the one bobbin I've completed is about 32 ohms. Working transformers I've tested were average 27 ohms. Is 5 ohms going to make a difference? Actually, I had a working transformer months ago which was 31.5 so this should be OK. Definitely could do better with a counter attached to this.
                                    It is the turn ratio that you need to maintain also, smaller gauge wire can have higher DCR compare to the the same turn using bigger gauge wire. You should also use LCR meter to test the inductance which is also important spec. The Phase of the winding should also keep that in mind.
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      I used a caliper to gauge the wire (bare). I'm using 35 AWG triple poly nylon. They both read the same on the caliper. I'm going to get an electronic counter for my jig so I can better maintain the turn ratio. I did this slow so I wouldn't lose count though. I will test with the LCR too. I will have to pull a good transformer to get a comparison reading. I was careful to make sure I wrapped them in the right direction, which I guess would be the phase.
                                      • Ltank
                                        • Jun 2013
                                        • 776
                                        A inductive pickup. A simple loop of wire at end of coax on counter should work fine for checking the frequency.
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          I tested it briefly, just a few seconds but it was enough to see that it works. I want the epoxy to fully cure before I let this heat up.
                                          This will be the counter I get. I'll epoxy the magnet to the handle and mount the proximity switch to the upright. I guess I won't be buying a ready made winder now. My jig works too well.
                                          http://www.ebay.com/itm/5-Digital-Di...item4d1e220f6d
                                          • mikey5791
                                            Is it possible for transformer substitution?
                                            by mikey5791
                                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                            My questions are
                                            1. How do i test to see if the transformer is in good working condition?
                                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                            Hope you guys understand what i was asking. My intention is...
                                            11-03-2022, 02:11 AM
                                          • learnmore
                                            Help choosing replacement transformer for Levoit 600S SMPS
                                            by learnmore
                                            Hello Community,
                                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                            Peace
                                            LM...
                                            11-04-2025, 09:35 AM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • dennis_elx33
                                            3PHASE STEP-DOWN Transformer in Check
                                            by dennis_elx33
                                            Hello All,
                                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                            Problem statement: Power tripped Off
                                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                            Action Done:
                                            1) Replaced the faulty parts with good spare.
                                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                            12-02-2024, 06:52 AM
                                            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 04:40 PM
