Transformer substitution - Sanyo DP42849-01
  • lookimback
    • Aug 2013
    • 1489
    Re: Transformer substitution - Sanyo DP42849-01
    OK, laser temp probe arrived today.
    Good board with stock transformer, after about an hour, secondaries were about 163°.
    Board with rebuilt transformer, 190-199°.
    And those are open air readings. I suppose they would be hotter if enclosed in the TV. Definitely not safe. These will not be sold. I have one more awaiting rebuild and I'm going to try a larger gauge wire. If that makes a difference, I will attempt to disassemble the ones I rebuilt already. To my advantage, I know what epoxy I used and have some left. So, I'll make some samples and see what solvents will work best to break it down. At least I'm learning from doing this.
    ------------signature starts here------------
      • 31296
      was the heat on the primary side, or secondary?
      • lookimback
        • Aug 2013
        • 1489
        Secondary
        • lookimback
          • Aug 2013
          • 1489
          The wire I used is .0005 smaller than the original. 0.0045 instead of 0.005. 35awg triple insulated. It was supposed to be 0.005. I should have sent it back when it was smaller than it should have been. I didn't think it would make this much difference though.
            • 31296
            wouldnt it be better to oversize a little - given that the original design dies a lot?
            your difference there is hardly small - 10% diameter, but the actual area is probably closer to 20
            • lookimback
              • Aug 2013
              • 1489
              That would probably be a good idea. I hadn't thought of that. There isn't a whole lot of extra room on the bobbins though. Maybe I could go up a half gauge. Not much more though.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5095
                • New Zealand
                #67
                You've done a good job so far, most people wouldn't even bother trying!
                -David VanHorn
                • lookimback
                  • Aug 2013
                  • 1489
                  Thank you
                  • lookimback
                    • Aug 2013
                    • 1489
                    I don't have any way to figure out the voltages in these secondaries. Do you think I really need triple insulated wire? It is incredibly expensive.
                      Only if you want it to go to compliance testing. I had to do that in our export products.
                      • lookimback
                        • Aug 2013
                        • 1489
                        So a heavy build would probably be OK then?
                          "heavy build" I do not understand the heavy build. BTW, the winding are on its own bobbin too to the leakage between the windings will be very very low.
                          • lookimback
                            • Aug 2013
                            • 1489
                            Heavy build is double insulated I guess.
                              • 31296
                              i dont understand the need for double or tripple insulated, isnt it about the thickness/material rather than the number of layers?
                              • lookimback
                                • Aug 2013
                                • 1489
                                I thought that was how you got the desired thickness
                                • lookimback
                                  • Aug 2013
                                  • 1489
                                  I think I may have solved this. I tried again using 34AWG HPN. The "35" I'd used before was way under specs and was more likely 37AWG. So, using the 34AWG, the open air temp was around 170-180°F. Still hotter than a working stock transformer, but about 20-30°F lower than my last attempt. Resistance measurements were around 24.5Ω as opposed to 26.5Ω on a working stock transformer.
                                  I found the housing for this TV in a pile in my basement so I decided to see what effect enclosing it would have on the temp. I used a wire probe for these tests, inserted between the two secondaries, rather than the laser. The temp gradually rose to 234°F and stayed there throughout the 12 hours of testing.
                                  In previous tests, I'd determined that the board with a rebuilt transformer was drawing 1.68A and a stock one was drawing around 1.45A. About a 13% increase.
                                  Up to this point, I've been carefully disassembling these so I could save the primaries. Now I'm led to believe the primaries are the cause for the increased current and for the secondaries burning out in the first place.
                                  Going over datasheets for 25/40 litz wire, which is what the primaries are wound with, I've determined that I should have around .82Ω on each primary. I determined that by unwinding and measuring the wire, then calculating based on the resistance at 1000' from the datasheet. What I have on several bad primaries is around .70Ω. That's pretty close to 13% less resistance. 13% less resistance would mean 13% more current flow right? I no longer have a working stock board.
                                  I've several times swapped good transformers from boards with bad PWMs or other bad components, when I didn't have the parts on hand, so I'm pretty confident that the sole problem is the transformers. I've lost count of how many of these I've encountered. I know I have 8 boards without transformers right now, and I've sold at least that many.
                                  I'm probably on my final attempt now. I've ordered enough 25/40 litz wire to rebuild 1 transformer. I wasn't able to find it unserved for a reasonable price, so I'm going with served litz wire. For anyone wondering what that means, served litz wire has a sleeve over it to provide additional insulation.
                                  If this doesn't work, then the only other possible explanation I could think of would be that the ferrites have been damaged from overheating. Is that even a possibility?
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5095
                                    • New Zealand
                                    #77
                                    It is interesting that the primary winding has lower resistance than expected, but the question is why? Does a 'good' transformer have the same resistance or closer to the expected 0.82 Ohms?
                                    I don't know if they can be damaged, but they do change with temperature: http://www.mag-inc.com/products/powd...r-powder-cores
                                    -David VanHorn
                                    • lookimback
                                      • Aug 2013
                                      • 1489
                                      I no longer have a good board with a stock transformer. I couldn't keep the money tied up for too long. I can say, just from memory, that I usually get above .4 Ohms on a good transformer tested in board. They are connected in parallel so the actual resistance on each side would be double that. So, about .8 Ohms.
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 5095
                                        • New Zealand
                                        #79
                                        I wonder if the resistance dropped due to failure, maybe shorted turns? Did you ever try a ring tester on these?
                                        If the resistance was lower from the factory, I guess it would have to have less turns or thicker wire. Less turns might be plausible if they changed the core material I suppose but I am not an expert...
                                        In any case a lower resistance should mean higher current assuming nothing else is controlling it. Maybe that leads to overheating and breakdown?
                                        Don't overlook the possibility of bad design, of course.
                                        -David VanHorn
                                        • lookimback
                                          • Aug 2013
                                          • 1489
                                          I'm do believe bad design plays a role. Or rather, substandard materials. But they typically last a few years. I unwrapped 2 and tested them with my LCR meter. The first tested at .89 ohms. But I forgot what it tested on the bobbin. Chalk that up to my frustration with unwrapping it without removing the ferrite. The second measured .70 on and off the bobbin, but there was no ferrite when I tested it. I don't think that makes much difference though. Increased resistance I can understand. They have a bondable coating so I could see the possibility of damage while unwrapping. But reduced resistance while unwrapped, that has me baffled.
                                          I don't have a ring tester.
                                          • mikey5791
                                            Is it possible for transformer substitution?
                                            by mikey5791
                                            Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                            Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                            My questions are
                                            1. How do i test to see if the transformer is in good working condition?
                                            2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                            Hope you guys understand what i was asking. My intention is...
                                            11-03-2022, 02:11 AM
                                          • learnmore
                                            Help choosing replacement transformer for Levoit 600S SMPS
                                            by learnmore
                                            Hello Community,
                                            I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                            Peace
                                            LM...
                                            11-04-2025, 09:35 AM
                                          • ohren
                                            Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                                            by ohren
                                            Hello!
                                            I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                                            Measured voltages with no load:
                                            After rectifier diodes
                                            12V: 6.17 V
                                            5V: 5.67 V
                                            Secondary transformer pins AC measurement (really don't know if this says anything)
                                            12V: 2-2.5 V
                                            5V: 1.04 V
                                            I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                                            03-18-2023, 10:33 AM
                                          • dennis_elx33
                                            3PHASE STEP-DOWN Transformer in Check
                                            by dennis_elx33
                                            Hello All,
                                            i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                            Problem statement: Power tripped Off
                                            Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                            Action Done:
                                            1) Replaced the faulty parts with good spare.
                                            2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                            12-02-2024, 06:52 AM
                                            ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                            This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-06-2024, 04:40 PM
