Transformer substitution - Sanyo DP42849-01
  • lookimback
    replied
    Re: Transformer substitution - Sanyo DP42849-01
    You're welcome.
  • Amonaco9
    replied
    Roger that. Thank you
  • lookimback
    replied
    Go by the number on the label. It will be either 1AV420C41500, or, 1AV420C41501. And, they are both interchangeable.
  • Amonaco9
    replied
    Yep, ive been keeping an eye on some psu's on eBay but they go quick. And still have trouble finding a DPS-260LP(a). All i usually find are "b" models. Not sure if it will be that much of a difference.
  • lookimback
    replied
    I gave up on trying to find a replacement. I've been rebuilding the old ones and doing an exchange service on eBay. I have 2 disassembled on my bench now, awaiting rebuild. I'll probably get to them this weekend.
  • Amonaco9
    replied
    So from reading this theead, im guessing there is no comparable or replacement transformer available? Looks like im taking a shot in the dark and crossing my fingers with an Ebay psu.
    Ive been working on the same issue with my 42849-01 and found open secondary.
    Man, u got patience!!!
  • lookimback
    replied
    I had actually tried putting one in the oven last year. 45 minutes at 350°. Tried boiling too. But I think too much time elapsed between removal from the oven and my extraction attempt. I have an old tcon cover I fashioned into a pulling jig. The lip on it slides behind the lip on the ferrite allowing you to pull evenly without gripping the ferrite with pliers. I may revisit the oven technique because I didn't have that the last time.
  • Agent24
    replied
    Trying to heat them via inductance is probably more likely to cause overheating damage to the ferrite, I would guess, but I don't know.
    How about http://shaddack.twibright.com/projec...ferrite_cores/ or http://www.imajeenyus.com/electronic...er/index.shtml
  • lookimback
    replied
    On second thought, I think I'm going to stick with 34AWG. I got thinking about it and, although there is a very high rate of failure among these transformers, these TVs were made in 2009-2010. That said, it would seem that they do last 4+ years. I think now I need to focus on better methods of disassembling them. I've broken 6 so far, but three were ones I had to take back apart a second time. I've tried various solvents (Cyclohexanone, Methyl Ethyl Ketone, Acetone, and PVC pipe cleaner), all of which are extremely hazardous. The pipe cleaner seems to be the most effective, but very slow. They are made of polystyrene, which is acid resistant, so I think I'm going to try sulfuric and muriatic acids next. It shouldn't take more than a few drops. I have no issues removing the epoxy on the outside of them. My heat wand and a razor make quick work of that. It's the stuff on the inside of the secondaries that gives me a hard time. I have found that it's best to remove both secondaries together and worry about the ferrite after they're out. Pushing the ferrites out from the bottom, after scraping the adhesive from around them, works better. I'm thinking the acids may corrode the pins, so I'll test on some broken pieces first. Another option may be to somehow heat the ferrites. I tried with my soldering iron before, but I couldn't get them hot enough. I'm wondering if I could heat them with inductance.
  • lookimback
    replied
    I think I'm going to play around a little with the next one. I'd like to try and reduce the temp a little beyond what the stock ones are. Maybe a 5% increase in inductance, or a larger secondary conductor. I think that, since it's the secondaries which get hot, then maybe I'll try a larger gauge conductor first. If I reduce the current by increasing inductance, it may cause it to be too little current and cause premature lamp failure. Or, maybe even cause sets with older lamps to not work at all.
  • lookimback
    replied
    I don't give up easily. I do have to step away sometimes though. I couldn't have done this without the insights and suggestions from everyone, particularly Budm. So, thanks everyone.
  • Agent24
    replied
    Congratulations! Just goes to show the old saying is right. Don't give up, you never know how close success is.
  • lookimback
    replied
    I finally got time to work on this a little more and I believe I got it beat. It was the inductance all along. Or rather, the air gap. I found that the inductance was as high as 6mh when the ferrites touched, and separating them by no more than a millimeter reduces that to around 1mh. I decided that it would be better to try to tune them with my LCR meter rather than chance that separating them a certain distance would be accurate. So, I pulled a good transformer and checked the inductance. I got about 1.75mh on the primary side and 40mh on the secondaries. On this attempt, I cemented the secondaries in place first and once the epoxy cured, I adjusted the primary side ferrite until I got a reading of exactly 1.80mh on both sides. Epoxying them without them moving wasn't easy. I decided the best way was to just drip some on each side without actually touching them, just to tack them in place, then, once that cured, I put more on. 3 1/2 months, 3 failed attempts and about $325 invested (about $80 of that was new shop equipment though), and I'm pretty confident I got it right this time.
    So here's the numbers:
    Startup current draw: Rebuilt about 1.5A. Stock about 1.6A (last board was 1.48A).
    Current draw after ten minute warm up: Rebuilt 1.24A. Stock 1.23A.
    Temperature (left side, right side): Rebuilt 170°, 160°. Stock 177°, 163°.
    Inductance: Rebuilt 1.80mh. Stock 1.75mh.
    According to the label on the back of the tv, it is rated at 216 watts. I dont know what the power factor should be but, with a power factor of 1, that would be 1.8 amps.
  • lookimback
    replied
    Originally posted by Agent24
    Didn't you say you measured the original glue at 0.52mm? I guess the correct gap would be that much? Or maybe I missed something.
    I thought that too. But, it wasn't even. That was the thickest point on the piece I broke out. On a working stock transformer, I measure 57mm from the back of one ferrite, to the back of the other. I currently only have 1 loose ferrite to measure and it is 28.125mm. Double that and you get 56.25mm. Subtract that from 57mm and you are left with .75mm. So, I'd say .75mm is what it should be. But, that's assuming they are all precisely the same size. I prefer having more than 1 so I can get an average. And then too, I have never disassembled a working transformer so I don't know that the failed ones don't have some physical defect, such as the ferrites each being .375mm too short. I've also never measured one before disassembly. I must admit, I never had a clue there was this much involved in building/rebuilding a transformer.
  • Agent24
    replied
    Originally posted by lookimback
    maybe there is supposed to be a gap, but if so, I need to determine exactly what that gap needs to be.
  • lookimback
    replied
    After reading up on the purpose of an air gap (thanks Budm), I can be led to believe that maybe there is supposed to be a gap, but if so, I need to determine exactly what that gap needs to be. What's clear is that my last attempt is 1.24mm more gap than what it should be.
  • lookimback
    replied
    I just put a caliper on a good transformer, and the last one I rebuilt. Good transformer, 57mm. Transformer I rebuilt, 58.24mm. That's from the back of the primary ferrite to the back of the secondary ferrite.
  • lookimback
    replied
    I guess when cool the inductance is enough for the circuit to work, but after heating up it drops just enough to prevent it from restarting again. Or perhaps the transformer drive circuitry is also being overworked in some way and ends up needing a rest before it can start again.
    Also, the resistance on the wire increases as the temperature rises. Both probably play a role.
  • Agent24
    replied
    Of course! I was told about the core gap and effect on inductance a while back but had forgotten: https://www.badcaps.net/forum/showthread.php?t=36874
    replied
    I did not have a chance to read through them yet.
    http://powerelectronics.com/content/why-have-air-gap
    http://info.ee.surrey.ac.uk/Workshop/advice/coils/gap/
  • mikey5791
    Is it possible for transformer substitution?
    by mikey5791
    Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
    Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
    My questions are
    1. How do i test to see if the transformer is in good working condition?
    2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
    Hope you guys understand what i was asking. My intention is...
    11-03-2022, 02:11 AM
  • ohren
    Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
    by ohren
    Hello!
    I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
    Measured voltages with no load:
    After rectifier diodes
    12V: 6.17 V
    5V: 5.67 V
    Secondary transformer pins AC measurement (really don't know if this says anything)
    12V: 2-2.5 V
    5V: 1.04 V
    I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
    03-18-2023, 10:33 AM
  • dennis_elx33
    3PHASE STEP-DOWN Transformer in Check
    by dennis_elx33
    Hello All,
    i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
    Problem statement: Power tripped Off
    Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
    Action Done:
    1) Replaced the faulty parts with good spare.
    2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
    12-02-2024, 06:52 AM
    ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
    This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 04:40 PM
    ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
    This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
    09-06-2024, 12:00 PM
