sharp lc-65ub30u plays but screen is flashing on and off
  • Diah
    • Feb 2013
    • 6386
    Originally posted by JunkmanJimbo
    The backlights remain flashing for 20 seconds after powering the TV off.
    however do what i asked you last post.18. unless you need to take out the screen and inspect visually BL and sockets connection under the screen.
    • JunkmanJimbo
      • Mar 2017
      • 194
      I remved the power supply and I removed the LED driver board but I didn't see any cracked solder joints.
      • Diah
        • Feb 2013
        • 6386
        the last things disconnect the 4 ribbon cable between T-CON and Panel then turn on see the BL remain flashing... if yes keep them disconnected and take it apart.... tv will remain work with out screen unless you have stable BL
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4350
          • Italy - Milan
          anyway, Jimbo i never repaired a similar defect on a similar set {Local dimming type), my guess is that those two many pins QFP ic on the blue board are something like a specialized CLPD, with D/A and so on, with their own program inside, the program went bad (voltage transients etc) and they are no more able to drive the mosfets, you see the light again when shut down because of that long column of electrolitic caps still charged, i suggest you to try and find a replacement blue board..
          Note from admin. Removed negativity from this post. All opinions and users are welcome and should be respected. Personal attacks will result in a ban.
          • Diah
            • Feb 2013
            • 6386
            also you need to figure out the BL_ON signal which it go to PSU or LED driver boards if it remain on stable or it cut off and on.... to be sure every things are correct then take it apart
            • JunkmanJimbo
              • Mar 2017
              • 194
              I looked for a LED driver board but apparently the only way to get it is to buy the power supply.
              • Diah
                • Feb 2013
                • 6386
                Aggressive personality will not fixed by deleting content only,
                now is the right time to stop my accounts on this site.
                OP sorry that i cant continue with you... really sorry. good luck for all.
                • JunkmanJimbo
                  • Mar 2017
                  • 194
                  I am getting steady voltage at the BL_ON terminal. Do you still think it's a backlight problem?
                  • JunkmanJimbo
                    • Mar 2017
                    • 194
                    Come on Diah. You got me this far.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4350
                      • Italy - Milan
                      #30
                      People can read, we are not analphabed, Diah started the battle..
                      ​​​​​​anyway, Jimbo, try ti find the datasheet of the 2 LED board controlllers..
                      • JunkmanJimbo
                        • Mar 2017
                        • 194
                        Where would I find that?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4350
                          • Italy - Milan
                          #32
                          normal web search or from manufacturer's site directly.. today is difficult..
                          • JunkmanJimbo
                            • Mar 2017
                            • 194
                            I can't find the datasheet. I'm going to order another power supply to see if that fixes the problem. If that doesn't fix it I will assume there is a backlight problem. Thanks for your help. I will let you know if that fixes it.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4350
                              • Italy - Milan
                              #34
                              Note for moderators: i ask again that *** filters my messages like i did with him, otherwise we are here always battleing and him that tells he leaves the forum and he really does not.. bhe
                              see note below - admin
                              • Admin
                                • Oct 2003
                                • 5334
                                • United Kingdom
                                #35
                                Davi.p - it's up to you to go to your settings and select hide for members you don't want to see. The forum is welcoming to all opinions (including the member you mentioned) and all users are welcome to contribute to any thread. All we ask is that things are kept positive.
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4350
                                  • Italy - Milan
                                  #36
                                  Is it normal that the questioned person tells "don't listen to him, unresponsible man etc etc.."? How can a correct forum permit this? I feel not inferior to him tchnically.. one can sentence "that is error" or "that is error for me" , not prevaricate, i made the error myself in the past, reading totally wrong diagnosis i felt useful for the requester to let him to know that, not ruining a chance to fix a device.. only this.. everybody knows me personally thinks i'm good educated guy, only in the forums i am 'taken as a bully, punk etc..
                                    • 12206
                                    • U.S.
                                    #37
                                    Any update?
                                    • JunkmanJimbo
                                      • Mar 2017
                                      • 194
                                      Any update?
                                      I ordered and installed a power supply but that wasn't the problem. I dissassembled the tv to check the backlights. While checking the backlight strips with a LED backlight tester I found one backlight that wouldn't come on at first. After turning the tv on, all the backlights, including the one that wouldn't come on with the tester, came on and started flashing. These are 6 volt backlights. I checked the voltage at that one backlight and the voltage would climb to 12 volts +. So, I changed that one backlight with a new one and that fixed the problem. Thank you guys for all your help.
                                        • 12206
                                        • U.S.
                                        #39
                                        Glad to hear it, Diah was working hard there, thanks for the "prompt" feedback. AND guess who was right again, good work Diah.
                                          • 12206
                                          • U.S.
                                          #40
                                          Not too hard to see who is the bad apple here, is it? Indeed even a pig who lost his sense of smell could find that truffle. That member seems to be trying to get all of us out, my vote is JUST he goes. He has been the rotten apple for a VERY long time.
                                          • HTR-Informatique
                                            by HTR-Informatique
                                            02-09-2025, 06:51 AM
                                          • sefoster
                                            Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                            by sefoster
                                            I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                            11-20-2022, 09:29 AM
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • EazyBone
                                            Sharp LC-65Q620U White Screen
                                            by EazyBone
                                            Another TV topic!!
                                            I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                            The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                            Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                            08-21-2024, 12:56 PM
                                          • reformatt
                                            by reformatt
                                            07-31-2025, 08:37 PM
