Hey guys! It has been awhile since I've been on here. I hope everyone is doing well. I just picked up this Sharp lc-65ub30u. It plays but the screen is flashing on and off. Other than that i seems to be a great tv. Any ideas what the problem might be? I haven't pulled the back off yet. I thought I would get some opinions first. Thanks in advance for any help you can offer.
sharp lc-65ub30u plays but screen is flashing on and off
Tags: None
Here's pictures of the boards. The backlights are flashing on and off. Thinking it might be a bad power supply. What's your opinion?3 PhotosComment
This Sharp TV backlight settings are from +16 to -16. I set them all the way to -16 and nothing changed.Last edited by JunkmanJimbo; 09-07-2024, 02:47 PM.Comment
My ipotesis is that one or more sector power transistor led driver is not ok, the reason? The electrolitic caps i guess no, set is too.young, maybe all sector leds are gone, i dont think so, maybe controlling big IC has to be solder renewed because they driven bad those..Comment
Actually I don't see any shadows on the screen. Not saying they're not there but from what I can see the picture looks great except for the flashing. So, do you still think my problem is still the backlights? Is there any way it could be the LED driver board that's mounted on the power supply? Thanks for your help. If you still feel like it's the backlights I will pull the screen to check them but I probably can't do thet until Monday or Tuesday. Thanks again!Comment
Something else I noticed.....when I turn the power off by the power button the backlights contnue to flash for another 20 seconds before they turn off.Comment
Hey Diah. I decided to pull the yellow cable today. When I pulled the yellow cable between the LED driver board and the mainboard the backlights would not come on. When I plugged the cable back in the backlights still wouldn't come on. I had to unplug the power cord and plug it back in for the backlights to come back on, still blinkiing. What's your opinion on this? Thanks!
use yours DM in DC mode measure each channel of LED at start up you have 4 each have LED + & LED -
or try to unplug one channel at time.Comment
But why would the backlights stay on for another 20 seconds after I power off the TV?Comment
if remain ON for 20 seconds.... we need to tray log in first in service menu and do clear chip as hard reset... to avoid any mistake at BL_ON signal send BY MB.
also take out the power boards and the LED driver boards and inspect the down side of cracking joint solderComment
stay on for 20 seconds or it remain flashing for 20 seconds after you put it in STBY.=
I also had corrosion/oxidation on the... -
by sefosterI have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
by Ryan.manHello everybody! Posting this in hopes somebody has some expertise that leads to a clear path of troubleshooting that saves me a lot of time!
This time the original cable broke too close to the screen, it can't be fixed without tearing the screen... -
by EazyBoneAnother TV topic!!
I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?... -
by reformattJust had a customer bring in a M2 MBA A2681 that had had a screen replacement in April at another repairer. Since then, she has been getting intermittent kernel panics. It's an aftermarket screen, and of course it fails in diagnostics as the calibration hasn't been done. The error in the panic log is "No device added after powering on the rails".
It seems the original repairer has swapped the board and the screen to other MAC's, and said that it isn't a screen issue. From what I understand, by doing a quick search on Google, this is in fact a screen issue. The panic relates...07-31-2025, 08:37 PM - Loading...
