Sharp LC-65Q620U White Screen
This topic has been answered.
  • EazyBone
    • Jun 2023
    • 1351
    • United states
    Another TV topic!!
    I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
    The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
    Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?
  • Answer selected by EazyBone at 08-21-2024, 02:19 PM.
    EazyBone
    • Jun 2023
    • 1351
    • United states
    And this is why I come here. Pulled 3/4 ribbon VGH back to 30v. Now can see some sort of damage occured on the panel. It's a tosser. Thx diah, sometimes I forget to do certain tests I always do .
    Dead tv
    • Diah
      • Feb 2013
      • 6400
      Originally posted by EazyBone
      Another TV topic!!
      showing source then went to white are sign of BGA at the Soc.
      to be more sure of this possibility , test the panel / T-con as stand alone, or half screen via ribbon... or 3/4 screen via the U ribbon cable
      • EazyBone
        • Jun 2023
        • 1351
        • United states
        Good idea. I forgot to mention that it no longer shows input then white, it only shows white now. The TV sat for a long time and when I got it, worked for the 30 seconds and now always white screen. But I'll report findings
        • EazyBone
          • Jun 2023
          • 1351
          • United states
          Dead tv
          • Diah
            • Feb 2013
            • 6400
            Dead tv
            can you show here what kind of damage on screen!
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • harp
              White screen repairs
              by harp
              To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
              Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
              On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
              05-13-2024, 03:43 AM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • Megan0
              Sharp LC-70UD1U Half screen Normal half screen is white
              by Megan0
              My Sharp LC-70UD1U Screen is black and flashing, "I attached the video"
              Well, I opened the back cover and as you can see in the picture, I unplugged 2 L (left) ribbon, TV turned ON, but half of screen (Right) is normal, and the other side (Left) is white. I continued to test...
              Result:
              I swapped the ribbons L<-->R = Blinking 2x power light, 5x timer light
              Unplugged 2 R Plug 2 L = Blinking 2x power light, 5x timer light
              Unplugged 2 L Plug 2 R = Blinking 2x power light, 5x timer light
              Only in the first test, where I did not
              01-19-2022, 11:20 AM
