Toshiba 46TL963 3D LED Smart TV - No backlight
  • safesurfer65
    • Feb 2014
    • 112
    • Scotland
    Hi all
    Hope someone can help. I've got in a Toshiba 46TL963 3D LED TV with no backlight. Has sound, if you shine a torch into the screen you can see the picture. Just over a year old. Could it be a faulty T-Con board ?
    Mark
  • philliesfan30m
    • Aug 2013
    • 542
    Re: Toshiba 46TL963 3D LED Smart TV - No backlight
    if you can see a picture it isn't the t-con. take a picture of the whole back of the tv and all the individual boards. the problem is with the leds or it isn't getting the signal to turn the leds on.
      Check the 24V to the led driver board, if it has one, and check the fuse on it.
      • safesurfer65
        • Feb 2014
        • 112
        • Scotland
        ok thanks guys I'll try that.
        • perplexed
          • Nov 2014
          • 10
          • Ireland
          Hey guys. Can I post a question here?
          • mmartell
            • Oct 2013
            • 3189
            I think you just did...
              Create your own thread - stops possible confusion between different faults.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                LOL
                • wadclip
                  • Sep 2011
                  • 5
                  Originally posted by safesurfer65
                  Hi all
                  Mark
                  Ok guys wondering if you can help me out here Tom, Been on the tvs for 20 years + now, just got one of these in, have a backlight with good picture from anywhere between 5 to 25 mins then the set will start to flicker then the backlight goes of. Picture is still there, I have checked all voltages and they are correct. I then changed the inverter board with no effect, i then tried the PSU thinking it may have an internitent fault but the same again. i doubt it is the main board?? so you think im looking at stripping the tv down to the LEDS and going through them!! id rather not but just thought i would take opinions on it.
                  Thanks guys for any help
                  • Alastair E
                    Chief Womble
                    • Mar 2013
                    • 1963
                    • U.K.
                    Prob the LED chains--one or two going intermittent...
                    Common issue it seems, the LED's are chained in series--One out--All out!--Bit like 70's Union members!
                    TELEFIX
                    • wadclip
                      • Sep 2011
                      • 5
                      Yes, i thought so Alastair!! well here goes to a strip down!!! lol
                      • Alastair E
                        Chief Womble
                        • Mar 2013
                        • 1963
                        • U.K.
                        About the only thing it can be--if there's supply to 'em and they go out with supply staying there!
                        TELEFIX
                        • wadclip
                          • Sep 2011
                          • 5
                          Yes they do mate, 24v still there and 3.4v signal. what a nightmare!
                            @wadclip:
                            Please upload the pictures of your LED driver board and the pictures of the whole backside of your TV.
                            24V is probably for feeding the LED driver board but more likely that this 24V is fed into the Boost converter to get higher Voltages to drive the LED strings.
                            But as we have seen so many threads on LED TV in BC, it is more likely to be bad LED or bad wiring to the LED strings.
                            • viduka
                              • Mar 2014
                              • 64
                              • Scotland
                              Hi
                              Was there a resolution to this issue ? Got same Tv with the same fault.
                              How difficult is it to source and replace LEDS ?
                              • sordids999
                                • May 2013
                                • 2161
                                • uk
                                Just a quick question if this tv has no backlights but you can see a image if u shine a torch would this still be a possible bad LED bulb or driver board fault ?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  You will need to diagnose that, what Tv is it ?
                                  • sordids999
                                    • May 2013
                                    • 2161
                                    • uk
                                    Toshiba 46TL963
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Checked the return voltage going to the Led strips ? Is one different from the others ? Will link video showing how to do so if you need help.
                                        Toshiba 46TL963
                                        How about the pictures of the whole back side of the TV, and each board so I can see how the LED strings are being powered? The OP never upload any pictures for us to see.
                                        • triplefour
                                          by triplefour
                                          09-13-2023, 10:43 PM
                                        • Boyxba
                                          TOSHIBA BACKLIGHT MAINBOARD C55-a-1h9
                                          by Boyxba
                                          I have a toshiba laptop satelite series c55-a-1h9 with a burnt item on pcb motherboard which is responsible for backlight display. the short came after installation of cable lvds and broken the leg with the v+ of backlight and made this short . the lvds cable replaced and i have working display now but not backlight. the problem is i dont know what was the component that burned in order to change it. voltage i have in this points of burned item at up side 19v and dropping and from down i have steady 19v . can anyone help me? i shall post some photos to see....
                                          05-13-2023, 11:47 AM
                                        • DanPoka
                                          by DanPoka
                                          02-15-2025, 05:05 AM
                                        • Comp_Pro
                                          No Backlight Macbook A1990 820-01041
                                          by Comp_Pro
                                          Hello all,
                                          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
                                          Tests performed:
                                          There is no backlight even with a good screen.
                                          Backlight IC is receiving the correct support voltages.
                                          Fuse F8400 ok
                                          Current sense resistor R8400 ok
                                          Backlight IC is receiving 3.3V on enable pin.
                                          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
                                          Backlight IC receiving 5V from PP5V_G3S
                                          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
                                          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
                                          05-06-2024, 10:23 PM
                                        • willis6732
                                          Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
                                          by willis6732
                                          This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
                                          Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
                                          The Driver board looked pretty toasty in the LED Driver Area.
                                          So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?...
                                          12-17-2024, 04:09 PM
