Toshiba 55lf621c21 Dim Picture / Backlight afterbypassing a Burnt LED
  • willis6732
    • Feb 2023
    • 41
    This TV came in for a backlight Repair. I bypassed the Burnt LED as shown in Picture. I thought it was fixed and returned to customer. So I dont have the TV anymore, but customer says its not really watchable.
    Now the TV Is much dimmer than before. It does a quick bright flash when it first turns on.
    The Driver board looked pretty toasty in the LED Driver Area.
    So I am wondering.. how can i Tell if this is a LED or Driver Board Issue?
  • Diah
    • Feb 2013
    • 6534
    are you calling what you did was repair or fix? how about if there are Zener diode build in LED unit... what about currents to calculated how many LEDs build in..... how much you charged him LOL
    delete please yours photo before other things who are here to repair are cheat persons
    • willis6732
      • Feb 2023
      • 41
      Holy symantics. Looking for help, not to be critisized about life. Not sure how to delete photo. Edit button is gone. Yes ive fixed many TV's with this method. Got the Method from Electronics repair school channel if you want to critisize sorin. If you dissagree with anything i did, just state the correct method. Jeese
      • Diah
        • Feb 2013
        • 6534
        you called my post to you as criticized, however the answer was include it...
        Zener diode build in ------- test one working LED unit if there zener diode build in reserve way .. yes need to replace all as the value of the zeners got changed to low or high over all other LEDs
        currents measurement -------- measure the pulling V at start up from cold state--- if its pull high and then reduced ... if yes then replace all strips
        • willis6732
          • Feb 2023
          • 41
          Well sorry if ive posted dumb misleading information.
          Thanks for the help on diagnosis LED Strips. THis is valuable information i was unaware of. Could you please clarify some things before a get the TV back here...
          "currents measurement -------- measure the pulling V at start up from cold state--- if its pull high and then reduced ... if yes then replace all strips"
          So i should check for voltage droping on backlight circuit. Im assuming to use High mode on Voltmeter? What is an acceptable voltage fluctiation 1V, 5V, 10V ??
          I also dont understand how to tell if a LED has a zener diode in it.
          "Zener diode build in ------- test one working LED unit if there zener diode build in reserve way"
          How do i perform this test? Just with Diode mode? What is an acceptable reading?
          Ive attached a pic of the Driver board. The small coil or Choke at the very top toward the right next to the two electrolitic caps is the area that was very toasty looking. Wondering if this is an area of concern....
          • Diah
            • Feb 2013
            • 6534
            zener test .. use diode mode of yours DMM. in way the fine LED will light on dim... and if you put the probe in reserve way... if there are zener you will have 0.65-0.75 dropping on your DMM... if there are nothings need to test another LED to be sure same value so if nothings then no zener build in
            dropping current... but your DMM on 250V DC with refrence to TV chassis put the red probe on LED+ at the socket of BL on PSU.. then turn on.... you will have high and low reading
            • EazyBone
              • Jun 2023
              • 1362
              • United states
              This is a fix for your own tv.. not a customer. Replace the lights fully.
              • willis6732
                • Feb 2023
                • 41
                Thanks. I havnt dealt with zener LEDs before. I didnt know DMM could be used on them
                I dont have the TV with me, and i did find the LEDs from china for $36 so i went ahead and orderred the out of my pocket
                I will report back with BL output wheni get the LEDs
                PS. I am brutally honest with customers and they know as much as i do about the validity of the repair.
                • willis6732
                  • Feb 2023
                  • 41
                  Hello, I received replacement LED strips and wanted to give an update on those
                  In Diode mode the LEDs light up one direction and OL in the other direction. So by your explaination im guessing they are not Zener.
                  Except one of the LEDs doesnt light up with diode mode and reads .2 to .3 each directions.
                  But with the LED tester that LED lights up normally.
                  Each LED strip x8 shows 15V on my LED Tester. I tried shorting the one weird LED for fun and Voltage goes to 12.3V for the strip
                  Wondering, do i just ignore the LED with the weird diode readings since it seems to be functioning ok?? hrmmmm
                  More updates when i Get the TV here.
                  • Diah
                    • Feb 2013
                    • 6534
                    take this complete out from strips and find one with lens from old one. cut it .. and stick it in place and jumper - + to the bad led rails.
                    • willis6732
                      • Feb 2023
                      • 41
                      The TV brightness has returned to normal with all the LEDs working.
                      I have some dark mark in the lcd from suction cups. are suctions cups ok to use? Maybe mine are too strong?
                      • EazyBone
                        • Jun 2023
                        • 1362
                        • United states
                        What cups do you have? Super strong ones aren't recommended.. I'm sure you tried wiping it down with cloth and water.. sometimes I got to put some gentle elbow grease into it and it will come off. But I think it's dirt in my case.
                        Also I assume you changed all the LEDs and that fixed it
                        • willis6732
                          • Feb 2023
                          • 41
                          Yes replacing the LED fixed the dim light display issue.
                          What do you mean elbow grease? Like actually massage the LCD in a buffing motion? Would be funny if you were pulling my leg and got me massaging the tv.
                          I didnt really rearch much when buying my suction cups. I went for bigger. The seems very heavy duty. lol
                          https://www.amazon.ca/dp/B0D1FSZXHL?...sin_title&th=1
                          Any recomendations for suction cups?
                          • EazyBone
                            • Jun 2023
                            • 1362
                            • United states
                            Oh my lord those are way too heavy duty.. although maybe if you didn't pump too much it would of worked. I use these
                            https://www.harborfreight.com/4-23-i...8aAmK7EALw_wcB
                            One for each hand, I've done up to 82 by self so they work well
                            I mean generally the rubber leaves a mark in a circle on the screen so a microfiber cloth and a small spritz of water and sometimes you got to rub it to get the circle out. After seeing those cups though, you may have put that into the screen.
                            But it may just be able to be rubbed out. Don't press super hard but you gotta use some elbow grease.. very slight pressure into the cloth and see if any gets removed and if it starts to the massage that S.O.B until it's good
                            • willis6732
                              • Feb 2023
                              • 41
                              Oh those suction cups look great. Thanks
                              TO clarify, its the LCD panel that has dark circles in the LCDs themselves. Its not marks on the surface of the screen. I got those out pretty easy with some iso.
                              • petehall347
                                • Jan 2015
                                • 4448
                                i use very similar ones to pull dents out of car bodywork
                                • EazyBone
                                  • Jun 2023
                                  • 1362
                                  • United states
                                  Yes you moved the liquid around probably. Too strong
                                  • willis6732
                                    • Feb 2023
                                    • 41
                                    Well so much for that. This was the TV today.... Thanks everyone
                                    • triplefour
                                      by triplefour
                                      09-13-2023, 10:43 PM
                                    • TR103
                                      by TR103
                                      - it keeps rebooting
                                      01-22-2025, 04:12 PM
                                    • Mgiffune
                                      by Mgiffune
                                      06-09-2024, 10:28 AM
                                    • howardc64
                                      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
                                      by howardc64
                                      Problem
                                      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
                                      Model & Board Pics
                                      Conflicting Spec
                                      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
                                      https://www.shopjimmy.com/vizio-gj-2k1...
                                      10-10-2024, 01:16 PM
                                    • Ierwin
                                      by Ierwin
                                      05-13-2025, 03:31 PM
