Sony XBR-75X800G - Android start up only and dark blue screen
    • 12151
    • U.S.
    #101
    Firmware update directions there, looks like Nicks already put it on the usb so you can go straight to update procedure: https://www.sony.com/electronics/sup...tware/00262031
      • 12151
      • U.S.
      #102
      Originally posted by NolesFan
      just called Nicks, they said the USB was for pairing the MB back to this TV, so they sent me instructions on how to do and will perform that now.
      yes original remote
      Theres a silly little button on remote that you probably already tried, the PIC OFF button.
      • NolesFan
        trying to learn
        • Jul 2024
        • 94
        Several times and did not perform anything
          • 12151
          • U.S.
          #104
          • NolesFan
            trying to learn
            • Jul 2024
            • 94
            "If the set doesn't auto turn on, then press the power button. In rare cases, the board does not require to be paired. If the set turns on and shows picture, you are done, no need to pair the mainboard!"
            Im assuming since I plugged in the MB and it went thru the process and allowed me to perform a factory reset it, it has paired?
            • NolesFan
              trying to learn
              • Jul 2024
              • 94
              Originally posted by Diah
              remove the speaker and let see the panel buffer boards.. on each side you have at the middle U ribbon... try disconnect one a time and turn on the TV with signal to wake up the Soc GPU
              Ill try this now, but what is meant by " turn on the TV with signal " ? Do you just mean to power up tv?
                • 12151
                • U.S.
                #107
                I would run Nicks update/re-pair, its different than a reset, plus its probably the latest firmware for it.
                • NolesFan
                  trying to learn
                  • Jul 2024
                  • 94
                  So I removed the speaker and there is nothing behind it. Its just 2 wires coming off it.
                  What is the panel buffer boards?
                  Im sorry, Im getting lost at what yu want me to do
                  • Diah
                    • Feb 2013
                    • 6363
                    under the speaker you will have plate on each side you need to remove them then you will have access to the panel buffer boards which the 2 ribbon cable from T-con connected to them... take look at the middle you will find U ribbon cable connect 2 pieces together on each side
                    • Diah
                      • Feb 2013
                      • 6363
                      turn on tv with signal mean fed the tv with cable or areal or hdmi signal
                      • NolesFan
                        trying to learn
                        • Jul 2024
                        • 94
                        Diah, you are referring to that panel in the first photo and not to the gold ribbons in the second, correct?
                        • Diah
                          • Feb 2013
                          • 6363
                          yes under the metal plate there are the panel buffer boards
                          • NolesFan
                            trying to learn
                            • Jul 2024
                            • 94
                            Secret to removing them? I took out the screws for the stands and I removed the 3 screws that were holding it down, but there is no play in the plate.
                            • Diah
                              • Feb 2013
                              • 6363
                              lol... common.... sorry man. i have doubt right now with yours standalone test and this small things... please seek help from around before you cause unforgivable damage to the set
                              • NolesFan
                                trying to learn
                                • Jul 2024
                                • 94
                                Ok thanks for trying and appreciate the patience. If you have doubt with the standalone test, which Im guessing that means you think either A its the panel or B my skills at the test, then theres no point in going further and Ill scrap it.
                                  • 12151
                                  • U.S.
                                  #116
                                  Do you really want to give up? ALL is not tried yet, now listen up, DO or at least try to do the update/re-pair, no joy then DO these tcon tests, a video is worth a million words. This is one of those youtubers that knows what hes doing, just follow his lead, lets see what we get. once again this is tv repair not brain surgery, these tests are really not that hard, specially with a good how to video right there: https://www.youtube.com/watch?v=P5uD1tzMdUs
                                    • 12151
                                    • U.S.
                                    #117
                                    Those tests on tcon have been done OVER and over and are tried and true, when you have missing vgh with one cable unhooked but comes back with the other side unhooked, you have found the fault, this case is the panel, which can be "fixed" or at least made workable.
                                    • Diah
                                      • Feb 2013
                                      • 6363
                                      i didn't judged yours skill or any other users.. i just have concern no damage happen to the set
                                      all screw of the plate need to take out...
                                      • NolesFan
                                        trying to learn
                                        • Jul 2024
                                        • 94
                                        Sorry Diah, I assumed by the statement since I was having trouble getting the plate off ( small things ) and the doubt about the standalone test and then with the final seek help before i cause damage, I figured you were doubting me and wanted to give up. I doubt my skills haha thats why Im here. i was able to figure out how to remove that panel, after the screws removed there were 3 of 4 black things holding it in place that needed to be pushed in so the panel could be lifted and slid back. I could see the panels and all the u shaped ribbons running to the panel itself.
                                        • NolesFan
                                          trying to learn
                                          • Jul 2024
                                          • 94
                                          Of course not nomoresonys, dont like giving up, but when its an avenue that I dont travel much and I dont understand things or words. By nature I like to try to fix everything before i throw it away, but my skill level in electronics of this nature is not very high. Ill try to run the updates and all that and see if that helps. I was actually going to try a new Tcon board also just to see. Right now, there is no change in the screen if i unplug the Tcon or leave it plugged in with the ribbon cable coming from the MB.
                                          • Ryan.man
                                            by Ryan.man
                                            02-04-2025, 12:23 PM
                                          • Chrissygizmo
                                            Sony KD-55XG9505 lines on screen problem
                                            by Chrissygizmo
                                            Hello again everyone,
                                            This is my latest mission, to try getting this Sony tv back to normal working order…
                                            I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                            02-19-2025, 11:31 AM
                                          • zukdj
                                            SONY KD65x750F cycles through a white-red-green-blue screen when powered on
                                            by zukdj
                                            A new main board and power supply was installed on my TV last night, purchased the parts at ShopJimmy. I had no power before installing both parts. Now the TV powers on and I hear music as it cycles through a white-red-green-blue screen. I was thinking it may be a firmware mismatch with the parts however I am skeptical as to plugging in a USB stick with the newest firmware on it since I cannot do any user interaction since all I see is colors on the screen, will the firmware start and complete on its own once the USB is inserted or does it require user input? Someone told me it is in Purity Check...
                                            06-05-2021, 04:56 PM
                                          • Adam Russ
                                            Black screen on Sony 65x90ch (65x900h from Costco)
                                            by Adam Russ
                                            Weird issue with this tv. Was streaming to the from a computer when it stopped working and the screen went black. Ever since then there has been. o image. Just a black screen. The audio works and yhe backlights do come on when it's powered on, it's just a black image. It presented like a backlight issue. So I finally got around to getting new backlights and a backlight tester. All of them test the same as the good backlights with the same voltages. There are no blinking lights. Just the white led at startup and when buttons on the remote are pressed signaling it's receiving from the remote....
                                            09-15-2024, 05:46 PM
                                          • Ihandyrepair
                                            sony 55X850D black screen no front white or red led light.
                                            by Ihandyrepair
                                            Hi guys
                                            strange one
                                            I have a dead Sony 55X850D
                                            when plug in, black screen, no front white or red LED, no back light no screen
                                            Voltages I get
                                            3.3v LD/power and main board
                                            reg 12V
                                            reg 19V
                                            3.3v on power on pin
                                            no Tcon on
                                            no tcon 12v
                                            no BL_on
                                            I do get BL_ERR 2.0v
                                            I tried to bypass it by ground it but still get same symptom
                                            I did also found a possible shorted cap on main board as it is showing 10 ohms when measure with meter
                                            or is possible the chip next to...
                                            08-07-2024, 04:58 AM
