Philips 55PUS7303 LCD lines
  • lotas
    • Jan 2016
    • 4535
    • Russia
    #41
    What kind of control do they have? These protective diode assemblies stand on the CLK lines, protecting them from static and voltage surges.
    So I don't understand why you should advise changing the motherboard if the problem is not in it or in the software.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4286
      • Italy - Milan
      #42
      Good.. so the gate drivers seemed bad but not.. i think the replacenent diodes are important, we all days see how gate drivers dies.. here in this model there is an intelligent solution to avoid this to happen.. also is important to avoid touching the tv with naked hands especially on the bottom.. i suspect this is the way these faults happens.. Good Lotas..!
      • Maalobs
        • Jun 2016
        • 120
        • Sweden
        #43
        Aha, so the TVS diode, a "Transient Voltage Suppressor", acts as a surge protector for the next IC on the line.
        There was a descriptive picture on page 2 in this application report from TI:
        The marking in the pictures is 6514P, which appears to be a Semtech part, here it is a DigiKey and here at Mouser.
        Mouser has a datasheet V3.0 from 2015, while I guess this is Semtech's own latest datasheet V3.4 from 2021.
        I can't get a sense of the scale from the pictures in the thread, but the proportions seem to match the 2.5x1.0mm package type.
        Anyway, is this part supposed to protect the next IC by dying?
        It seems wierd to me that the surge protector is commonly killed by ESD. 💀
        On the other hand, the maximum voltage defined in the datasheet is 120V, so if ESD kills it, I guess it's still sensitive to high voltage even if the current is low.
          • 20570
          Originally posted by Davi.p
          Don't buy any board unless a gift from Diah!! Bad screen, but some clever tinkerer can obtain an usable set from this..
          You will be banned if you keep goading.
          Originally posted by Diah
          you are wrong 1 too.... look on the first post when TV boot logo, and screen when half screen test... how it come you will be as the other asshole.
          Both you and Davi.p can stop being assholes, you can agree to disagree and leave it at that.Lotas deserves an apology.​
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            #45
            Ahh, my happiness was short. TV worked like 1h and than i got this lines again and after resetting TV the screen was black with backlight.
            edit:
            i fond this burned on left side of panel where i removed the diodes
            ...the quieter you become the more you are able to hear...
            • lotas
              • Jan 2016
              • 4535
              • Russia
              #46
              Your ceramic capacitor has burned out (shorted), this happens often, remove its remains, clean the area and replace the resistor.
              It’s not clear here, it’s hard to see, isn’t this solder residue?
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                #47
                This is burned trace not solder residue. The cap is not shorted. I removed it but not the burning happens on seconds 0 Ohm resistor. I dosconect that part of LCD and other side show error like grom begining
                • lotas
                  • Jan 2016
                  • 4535
                  • Russia
                  #48
                  So there could be a short in this place, if not the capacitor
                  • rtstorm
                    • Feb 2012
                    • 971
                    • Croatia
                    #49
                    I remove the caps but the short are in layer of board
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      #50
                      I found a short but now i have this on screen. I think i am giving it up
                      • Diah
                        • Feb 2013
                        • 6355
                        please don't advice some things you didn't try or faced before... its just to avoid harming users devices.. its absolutely no fun at it and who enjoy it then need to visit clink soon.
                        • Diah
                          • Feb 2013
                          • 6355
                          if you are going to delete this post again and don't delete yours... no more reason we can be here as you abuse your Admin power........
                          copy from deleted post.....
                          don't be rude for users in name you have admin power... show grateful to people spend time to help other... this is technical forum not chatting one... who knows and tried before some things helping threat welcome always.. but to harm users devices no place here... this what i do understand....over all the forum when links for youtube or other crazy stupid ideas linked in threat to run tests ... the end users devices went to trash. same this one.. do you call yours self ADMIN when this happened !!!!! so funny.
                          • lotas
                            • Jan 2016
                            • 4535
                            • Russia
                            #53
                            I myself removed these diodes more than once and there were no problems, I gave advice here on this forum to four people with this problem and they were happy (these topics were not saved, it's a pity), I gave a link to YouTube for reference, and your advice to buy and replace the working motherboard and the panel would work...
                            That's about it
                            https://www.badcaps.net/forum/troubl...7e-la?t=118195
                            https://www.badcaps.net/forum/troubl...cture?t=118339
                            • Diah
                              • Feb 2013
                              • 6355
                              Originally posted by lotas
                              I myself removed these diodes more than once and there were no problems, I gave advice here on this forum to four people with this problem and they were happy (these topics were not saved, it’s a pity), I gave a link to YouTube for reference, and your advice to buy and replace the working motherboard and the panel would work...
                              i don't have any things against you... we are talking on issue i did talked about it before FREQ... TV depends on this part... not cut this or mask that---i am sure you know that...
                              i could be wrong too... no one perfect... but we relay our mind and thinking on yourube or other crazy stupid one one to run SMPS PSU with 1X 2.6V batteries which over all net and here too to find !!!!
                              at the end who said over here this fault with out testing method advised he should keep silent including me.
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                #55
                                Hey, today i got the same model but with horizontal black line on tho bottom of the screen. After testing i found that one line was shorted to the ground and this line is coming from T-con board 55T32-COL CTRL BD. I order another one and waiting for it, hope it will fix the issue. I will post the result
                                  • 12096
                                  • U.S.
                                  #56
                                  Well since I spent time reading the thread, I'll just say I've learned MORE from the electronic GENIUSES on youtube, than anywhere else, granted there are a lot of people there that don't know what they are doing BUT there's plenty that know whats up x 1,000,000. Now I could show 10 examples right now but I'll let folks find them like I did, more fun that way. There were at least 2 such youtubers that BudM referred to a lot, I'm sure many members know who they are. This would be a much better site if WE ALL could just check our egos when we log in and hold until we log out. I have been guilty of it myself of course but I'm not the biggest offender. It is kind of sad when every debate turns into a war.
                                    • 12096
                                    • U.S.
                                    #57
                                    And even the pros are wrong from time to time, unavoidable, as long as it isn't a lot like some members that we know who they are. It takes a real mentally challenged moron to keep harping about an error when they also make them but FAR more often. Diah has always done a great job here, anyone trying to run him down is just jealous of his knowledge.
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      #58
                                      Well i got the part but the issue is the same, still lines on lcd panel. I tried to remove the diodes on the end of the but that also did not help. I guess than the issue is in the lcd panel
                                        • 12096
                                        • U.S.
                                        #59
                                        Any update, did you try taping this new one that you acquired?
                                        • rtstorm
                                          • Feb 2012
                                          • 971
                                          • Croatia
                                          #60
                                          Yes i try that, no help. I return the TV to friend.
                                          • advant
                                            by advant
                                            02-03-2020, 12:25 AM
                                          • grandad99
                                            philips 58PUS8105/12 horizontal lines
                                            by grandad99
                                            hi all and hoping i could get some help please.
                                            my philips 58PUS8105/12 has started acting weird.
                                            its getting these lines across it and sometimes a strange black half circle sometimes appears on the right hand side edge of the screen,the screen is cool to the touch all the way around except where you get to that black halfcircle about the size of a smartie right on the bezel edge of the screen,its quite hot.
                                            tv prob 3 years old and only used on weekends for a few hours so not done much.
                                            i popped the back off and cleaned the ribbon contacts all to no...
                                            08-01-2023, 10:37 AM
                                          • Stanley1843
                                            by Stanley1843
                                            06-29-2024, 11:54 AM
                                          • Daren87
                                            Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                                            by Daren87
                                            I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                            08-13-2023, 03:25 PM
                                          • x_orange90_x
                                            TCL 50S535 bad tcon or panel issue?
                                            by x_orange90_x
                                            Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                            03-29-2025, 11:02 PM
