Insignia NS-50DR620NA18 w/ large vertical lines & no picture
  • srs
    • Dec 2014
    • 24
    • usa
    I'm not sure what to do next and came here since y'all helped me fix a 50" plasma TV back in 2014, which is still working!
    A friend gave me an Insignia NS-50DR620NA18 50" TV that suddenly developed large vertical lines on it. He said he had no idea what might have caused it and has replaced it with a larger TV. He was going to throw it away.
    I did not notice any bulged or leaking caps on any board, the voltages produced by the power supply match the voltage that the pins are marked. The backlight leds are working. I have tried cleaning the ribbon cables on the T-CON board with isopropyl alchohol with no changes. I noticed that the mainboard seems to be working as the display changes (more red) when I push the Netflix button on the remote.
    I have swapped the T-CON board as well as the mainboard with no changes to failure mode. I tried unpluging the ribbon cables from the T-CON board to the tab bonding board one at a time and the vertical lines stay with the side that is still plugged in, the other side has no picture.
    I've lightly pushed on the tab bonding board flex cables and saw no changes in the picture.
    Let me know if you would like more/better/different pictures and I will get them for you.
    Thanks in advance.
  • nomoresonys
    • 12328
    • U.S.
    Re: Insignia NS-50DR620NA18 w/ large vertical lines & no picture
    Looks like you have done a good job testing things, not a lot left, maybe test the little mlc caps on the panel driver boards for shorts or very low ohms.
    • srs
      • Dec 2014
      • 24
      • usa
      I'm not certain what caps I'm looking for or the values I should expect to see. I have attached some pics of the tab boards, can you give me some guidance on what I'm looking for? Thanks.
      • nomoresonys
        • 12328
        • U.S.
        Those little brown ceramic caps, they have the designator next to them, the ones starting with C are capacitors.
        • nomoresonys
          • 12328
          • U.S.
          The big copper pad on the end should be ground for each board, put neg. probe on it, pos. probe on either side of cap one side should show continuity to ground the other should not, can also put a probe on each end of cap and see if it shows a short, can also test in ohm mode with test lead on each end of cap see if it tests very low. These tests done with tv UNPLUGGED from power of course.
          • lotas
            • Jan 2016
            • 4850
            • Russia
            Replace these resistors with 10 Ohm and remove these protective diode assemblies and everything will be fine.
            And in vain they bought both the motherboard and t-con.
            It's been the exact same problem for a while now. https://www.badcaps.net/forum/showthread.php?t=118195
            • srs
              • Dec 2014
              • 24
              • usa
              I unplugged the panel boards from the T-CON and tested all of the caps. Most were over 100kohms, some many megohms, one on each board was 770 ohms - same cap on each board. Does that sound right?
              Lotas, thanks for this info. I haven't seen this info yet so I really appreciate you sharing it. I'll have to search for replacement 10 ohm resistors on dead laptops or something and give this a try. No caffeine for me that morning…
              Should I put the extra mainboard and T-CON boards on the classifieds here or just put them back on eBay?
              • lotas
                • Jan 2016
                • 4850
                • Russia
                To begin with, carefully remove the diode assemblies (even all 4 pieces are possible), without damaging the board or cables, then look for resistors.
                • srs
                  • Dec 2014
                  • 24
                  • usa
                  I removed the 2 diodes that you marked in the pictures and it is working correctly now.
                  Thanks so much for your help!
                  • lotas
                    • Jan 2016
                    • 4850
                    • Russia
                    Please!
                    • Stanley1843
                      Screen Display Vertical Multicolor Lines
                      by Stanley1843
                      Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesn’t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                      06-29-2024, 11:54 AM
                    • pni
                      LG 49uf695v vertical coloured lines
                      by pni
                      Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
                      11-14-2025, 03:15 AM
                    • Falki
                      Colorful LCD Vertical Lines on Samsung ue55es8090
                      by Falki
                      Hello there, ive recently found an older 55inch Samsung SmartTV.
                      Sadly it has vertical lines at the left and one line in the middle-right.
                      I have already tested out the connections and have looked at the soldered ribbons of the LCD panel to see if some contacts got loose by pushing them a bit but with no success.
                      I have factory resetted the TV as well but also with no luck.
                      I am afraid that it is indeed a LCD Panel issue but there are NO scratches or any impact-marks..
                      A similar issue has been posted as well but also with no actual response ...
                      08-12-2025, 04:19 AM
                    • visionbluedemon
                      Help. Sony kd-65x85dj vertical lines
                      by visionbluedemon
                      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
                      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
                      tried blocking LC lines too, but same results
                      is it lcd panel issue or tcon board issue?...
                      07-25-2025, 04:56 AM
                    • gpo23
                      Sony KDL-40V3000 - Vertical lines
                      by gpo23
                      i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                      With the new t-con the color are good but there are vertical lines on all the screen :
                      I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                      Is there a way to fix the vertical lines on the new t-con ?
                      Thank you for your help
                      gpo23...
                      10-04-2023, 09:11 AM
