Philips 55PUS7303 LCD lines
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    Hello, I have this 55" Philips TV that suddenly has these vertical lines on the LCD panel. I have checked the T-con board and I noticed some caps have 40Ohm I don't know if this is normal. These caps have 1.2V on them. I mark them on the photo with a silver pen. The T-con board has 1.2V, 12V, 25V, etc. Does anyone have any idea what could it be?
    i try to disconect one ribon cable and the problem is the same, one side is white other side have the lines (the same is in other way)
    T-con model: 55T32-C0L
    Main Board: 715G8579-M0F-B01-005T
    ...the quieter you become the more you are able to hear...
  • Diah
    • Feb 2013
    • 6440
    from initial boot photo it sound to me mainboards data issue
    how about if you disconnect half screen.. did you get half clear white?
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      Here is the image
      • Diah
        • Feb 2013
        • 6440
        mainboards data issue.... try with first SW , if didn't help then check after vision Soc could be there BGA no vision... wrong from me.... let see yours mainboards with out heat sinks
        go here and under TPM171E
        download from 2018 download early firmware with upgrade_loader put it on USB formatted FAT32 MBR mode
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4476
          • Italy - Milan
          100% faulty panel..!! i'm afraid..
          (VGL leakage)
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            I did the firmware flash but the issue is the same. I Downloaded the FW and Loader. Extracted FW and Loader and put in the root of the USB 8GB FAT32. This is the version I tried
            Code:
            TPM171E _ 107.000.230.000 – Date: 2019/03/11 (Upgrade_Loader)
            Is this correct way?
            • Diah
              • Feb 2013
              • 6440
              on same side where you download they write how to do.... USB stick must formatted FAT32 in MBR mode
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                i have tried 2 version now and the problem is the same on the TV.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4476
                  • Italy - Milan
                  Don't hope.. relax.. bad screen..
                  • Diah
                    • Feb 2013
                    • 6440
                    disconnect the LVDS from the T-CON and fed the fuse on T-CON 12V on F101 to test the panel and t-con as stand alone., you should have color pattern
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      I disconnected the LVDS from tcon board, turn on the TV and put 12V on F101 but the screen is black
                      • Diah
                        • Feb 2013
                        • 6440
                        did the backlight come on?
                        • rtstorm
                          • Feb 2012
                          • 971
                          • Croatia
                          Yes, backlight is on. But there is no image.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4476
                            • Italy - Milan
                            In the test pattern the first seconds screen is black, then white. green etc..
                            • Diah
                              • Feb 2013
                              • 6440
                              replace mainboards
                              • rtstorm
                                • Feb 2012
                                • 971
                                • Croatia
                                I was able to capture the white line on first second when i connect the 12V after that is all black.
                                • Diah
                                  • Feb 2013
                                  • 6440
                                  from where you got the 12V ?
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4476
                                    • Italy - Milan
                                    Don't buy any board unless a gift from Diah!! Bad screen, but some clever tinkerer can obtain an usable set from this..
                                    • rtstorm
                                      • Feb 2012
                                      • 971
                                      • Croatia
                                      I have bench power supply
                                      • Diah
                                        • Feb 2013
                                        • 6440
                                        Removed by admin - See below
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • grandad99
                                          philips 58PUS8105/12 horizontal lines
                                          by grandad99
                                          hi all and hoping i could get some help please.
                                          my philips 58PUS8105/12 has started acting weird.
                                          its getting these lines across it and sometimes a strange black half circle sometimes appears on the right hand side edge of the screen,the screen is cool to the touch all the way around except where you get to that black halfcircle about the size of a smartie right on the bezel edge of the screen,its quite hot.
                                          tv prob 3 years old and only used on weekends for a few hours so not done much.
                                          i popped the back off and cleaned the ribbon contacts all to no...
                                          08-01-2023, 10:37 AM
                                        • advant
                                          by advant
                                          02-03-2020, 12:25 AM
                                        • kca
                                          by kca
                                          Hello all ~
                                          08-31-2025, 06:38 AM
                                        • Stanley1843
                                          by Stanley1843
                                          06-29-2024, 11:54 AM
