Samsung le46b530p7w
  • sordids999
    • May 2013
    • 2156
    Samsung le46b530p7w
    hi
    anyone got any ideas on this problem please
    my main tv has just started to play up the screen goes black but i still have audio,so i ordered a new invertor board due to still being able to see images when i shined a torch onto the screen.
    the tv is fine until i plug in either a hdmi lead or a scart lead into the main board then the picture just goes ?
    tested voltages on power supply they seem fine
    maybe the screen is shot time too bin the tv ?
    thanks
  • munirutech
    • Oct 2013
    • 72
    • Ghana
    Re: Samsung le46b530p7w
    what are the voltages you are getting from the psu to the inveter board?
    you should expect this two important voltages 24v and 5v for BLON
    • sordids999
      • May 2013
      • 2156
      the cable going to the invertor is reading 12v like it says on the psu
        That is actually error signals from balancer, you need to check BL ON OFF from main board to power board, that being said it is unlikely the balancer board (not inverter) would cause this. There is a jumper JP852 that needs to be cut to fix this issue -- design error by Samsung.
        • sordids999
          • May 2013
          • 2156
          ok tom found it so what now ?
          thanks
          • sordids999
            • May 2013
            • 2156
            ok now the tv seems to be staying on for now !
            thanks tom your a star !
              Nice to hear. This issue also affects 55" but strangely not 40", and only B and C series Samsung LCD. Something to do with the AC detect circuit -- bane of my life!!
              • sordids999
                • May 2013
                • 2156
                ahhh now the tv picture has gone again with still audio
                  Backlight still lit?
                  • sordids999
                    • May 2013
                    • 2156
                    no tom
                    • sordids999
                      • May 2013
                      • 2156
                      its strange if i go into the menu and change the picture mode then i just have audio so left it off for a while and it worked fine when i turned it back on,so changed the picture mode again and back with just audio
                      • sordids999
                        • May 2013
                        • 2156
                        Ok worked for 20 mins then just audio again
                          Check the voltage across the two large 450V capacitors.
                          • sordids999
                            • May 2013
                            • 2156
                            383v on both caps
                              Does that remain through the fault?
                              BN44-xxxxxx[A-Z] number on power board?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                tom would a eeprom reset help?
                                http://wiki.samygo.tv/index.php5/UnB...y_EEPROM_Reset
                                  Probably not if audio remains. If audio cut out too, I'd be thinking that might be a cause of the problem. (Watchdog mode, etc.)
                                  • sordids999
                                    • May 2013
                                    • 2156
                                    Can't get the picture to come on now so can't see if the voltages drop
                                    BN44-00265B REV 1.3
                                    I46F1_9HS
                                    • johnboy1313
                                      • Nov 2012
                                      • 1959
                                      Do you still see 383V across the caps while the picture is off?
                                        I have the schematic
                                        Wait for it to fail. Then, check voltage across PCI801's secondary (UVLO.) If it goes high (>2V), then a short across PCI801 may disable UVLO completely. (The only real issue with this is that it might cause the backlight to flicker a little when it is unplugged while running. Hardly a real problem.)
                                        • Chrissygizmo
                                          by Chrissygizmo
                                          02-10-2025, 12:33 AM
                                        • Chrissygizmo
                                          samsung galaxy ao2s very temperamental after screen replaced
                                          by Chrissygizmo
                                          Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                          Ive eventually managed to get it on and working but it's very temperamental...
                                          The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                          05-26-2024, 12:05 AM
                                        • JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                          by JunkmanJimbo
                                          Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                          No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                          Please help. Thanks in advance!
                                          08-12-2025, 11:45 AM
                                        • Kiberge
                                          Samsung LH82QENELGC/EN Help needed - Static line on screen
                                          by Kiberge
                                          HI guys!
                                          I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                          I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                          the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                          This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                          04-22-2024, 11:28 AM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
