Vizio E550VL screen fades
  • jhardluck
    • Sep 2013
    • 19
    I'm having a issue with a Vizio E550VL. Wondering if I could get some advice? I'm trying to decide what needs to be replaced. I'm thinking the back light inverter or main board. When the TV is on the display is hard to see. It is dark especially towards the center. You can barely see the writing in the center. If I go to the menu and reset the TV to factory settings it displays perfect on the whole screen for a few minutes then, slowly starts to fade and darken. Any advice would be great. I am new to this sight and hope it is ok to to post on this thread. I have an old CRT in my house so, it would be great if I can get this TV working correctly. Thank you for any help. When I can I will open the back and take pictures.
  • jhardluck
    • Sep 2013
    • 19
    Re: Vizio E550VL screen fades
    This is a TC-P50S1. 7 blinking red lights, if I disconnect the SC board I get 6 blinking lights. If instead I disconnect the board on the opposite side(can't remember what it is called) I still get 7 blinking lights. I also tried disconnecting the upper and lower boards connected to the SC board but, this did not make a difference so, I believe the SC board is my problem. It has the glued on heat sinks so, I can't see if anything is blown. Everything visible looks fine. I can't seem to find a price under $130 for a board. Any suggestions where to get cheap parts?
    • truep
      • Aug 2010
      • 373
      Put them each in their own thread! the Vizio is an LCD, the other is a plasma. they are totally different.
      • Caleb
        Smokin IC's
        • Feb 2013
        • 645
        Your Vizio sounds like the main board, if it was trouble in the inverters the reset wouldn't do any good. Its too bad you are all the way on the other side of the country Ive been looking for a screen for an E550VL.
        Liberating magic smoke one part at a time
        • jhardluck
          • Sep 2013
          • 19
          Here are some photos of the boards.
          • jhardluck
            • Sep 2013
            • 19
            Caleb, when you say main board which one are you talking about. I put pictures of the boards in the visio above.
              The one in the first pictures in post 5, it has the audio/video/tuner functions on it.
              • Ltank
                • Jun 2013
                • 776
                The fact that the menu works fine then fades seems to prove the inverters and back lighting are working. I agree that it is the main board but without the schematic if front of me I am unable to tell you what to test on the main board itself.
                • Caleb
                  Smokin IC's
                  • Feb 2013
                  • 645
                  You could try freeze spray on different portions of the main board to see if you could get it to come back from the fade. It sounds as if it might be heat related as it gradually fades away. You can use canned air held upside down for freeze spray. Also have you tried all the inputs? and are they all the same?
                  • jhardluck
                    • Sep 2013
                    • 19
                    Tried multiple inputs with the same results. I will try some canned air and let you know.
                    • jettboat
                      • Nov 2012
                      • 63
                      I repaired one of these it was the main board, I started with reflow of the two ic under the large heat sinks. the tv was fine for 3-4 hrs then messed up again , turned it off then it would repeat, replaced it & it was good to go.
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
                      • Ryan.man
                        by Ryan.man
                        02-04-2025, 12:23 PM
                      • reformatt
                        by reformatt
                        07-31-2025, 08:37 PM
                      • smic717394
                        by smic717394
                        07-25-2024, 10:16 AM
                      • paqman
                        Vizio M60-C3 black screen
                        by paqman
                        So our beloved M60-C3 up and died the other day. I was not there, my wife mentioned that it came on, displayed the logo, then showed the right half of the screen white and fuzzy, with the left half of the screen ok. However when I got around to looking at it, the screen would not come on at all. The indicator LED will come on, then dim a bit. After a while, the LED might blink a bunch of times. I can't get it to be consistent to do that.
                        So I've got the back off and am checking voltages. The capacitors on the power supply board visually check out. No bulges or anything. They all show...
                        03-02-2024, 04:37 PM
