Sony KDL-46EX400 2 blink error code
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-46EX400 2 blink error code
    I will look at that when I'm home, but I won't have time to take measurements today.
    Thank you for helping me.
    I have just sold last night the same exact TV. I had two.
      Too bad you did not take the voltage reading on Inverter_errror (oR bl_Error), LD, FB, etc.
      According to the typical SONY signals training maual:
      FB = 200~400mVac RMS
      LD = 11~12vdc
      Inverter_Error = 0V
      If we can get the chassis number then I can look for the training manual.
      • tibimakai
        • Jan 2012
        • 3680
        I have opened it up so many times and I was swapping boards, that I got tired of it. I didn't want to mess up that one too.
          OK, this is how the board functions. I can explain in details as needed.
          • tibimakai
            • Jan 2012
            • 3680
            Thank you for now.
            I will look at it as soon as possible.
            Today I have to be at the kindergarten with my daughter. Parent teacher meeting.
            • tibimakai
              • Jan 2012
              • 3680
              Where do I find the chassy number on a Sony TV?
                It may be on the sticker where it shows the model number, I just want to make sure since we are not using the SCH of the EX400 but the EX402 that you have indicated it closely match your board. That way we are not looking at the wrong components and the connections if the EX402 SCH does not match your board.
                • tibimakai
                  • Jan 2012
                  • 3680
                  The PS board is a APS 260(CH).
                    Right now you can go by the notes I made in the SCH and start checking those test points I made.
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I had a couple of minutes and measured a couple of points.
                      Basically the power supply turns on and then off.
                      384V turns on and then off. LD goes to 12V and then toward 0V. I'm not getting anything at FD.
                      I don't see Inverter Error, only BL_Error, which is 3.2V and not 0V.
                      • tibimakai
                        • Jan 2012
                        • 3680
                        Since the LD goes to 0V(from the initial 12V) it means that it entered in protection mode? This error could shut down the PS?
                        Also the Inverter_Error is not 0V, it's 3,2V, which is not good, am I right?
                        I could have a tube issue?
                        Should I take the panel apart?
                        • tibimakai
                          • Jan 2012
                          • 3680
                          I haven't had time to do those measurements yet.
                          I'm thinking about this TV and something doesn't add up.
                          I have purchased two boards until now and both times when I installed them, they worked that afternoon.
                          Next day or at a later time(2 weeks) when I try to turn it on, it doesn't want to turn on and throws the 2x blink error code.
                          I have transferred these boards into the other same exact (good) Sony TV (which I had it for a while, I don't have it any more) and it showed the same exact 2x error code.
                          So, if in the good TV everything is good, then why it shows the 2x error code?
                          But if the board is bad, then why it works the first time when I install it?
                          Almost sounds as incompatible board, no? If I look up shopjimmy and use there info, then it seems like I'm buying the right board.
                          I also do a firmware update when I get them.
                          To me, it seems like the mainboard is the issue. Then, how come three mainboards (one which it was the original board) show the same exact symptom?
                            2x error is backlight? Too many errors may build up and need clearing due to B/L fault.
                            • tibimakai
                              • Jan 2012
                              • 3680
                              How would you clear it?
                              I have a feeling that a previous error is causing this.
                              It doesn't give me enough time to do a reset.
                              As I plug in the cord, it clicks on and then off and shows the blinks.
                                I guess any way to clear it would be described in the service manual or from an external Sony jig -- no idea myself.
                                • tibimakai
                                  • Jan 2012
                                  • 3680
                                  I can't reset anything, until the TV it's not running.
                                  In the manual, 2 blinks means power supply failure.
                                  I still don't know which chassy I have.
                                  There is this manual also:
                                    Per 46ex400 manual, 2 blinks is the power supply error, but it does not have the sch, the other sch I used as a ref does not seem to match your board. What is the P/N of your power supply board, then we can find out at shopjimmy to see what other models use the same board then we can try locating the service manual or training manual for it. I look at a bunch of SONY manual, 2-blink of one chassis does not apply to another chassis, in your case, it means power supply fault, other chassis means backlights problems.
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      Check out this at shopjimmy:
                                      http://www.shopjimmy.com/sony-1-474-...repair-kit.htm
                                      I will have to check those transistors. I may just get these and I will replace them.
                                      http://www.amazon.com/Sony-1-474-205.../dp/B00EPJBTZM
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        This board is available on Ebay:
                                        http://www.ebay.com/itm/Sony-1-474-2...item3cd516ecca
                                        Should I bother repairing the board, or just get this one? It's right here in my town too.
                                          According to SJ, 46hx701 uses the same power supply/inverter board, so here is the training manual for chassis AZ1L.
                                          It said something about 12V regulated power supply problem that can cause 2x error. The kit has MOSFETs and Diodes which looks like they are for the PFC section, not for the 12V section.
                                          SONY KDL-46EX405KDL-46EX400KDL-46EX500
                                          Kit Includes: IC (1) IC6501 | Resistor (1) R6514
                                          Transistors (2) Q6501 & Q6502 | Diodes (2) D6502 & D6503
                                          This is good info here: These chassis use the same power supply board 147420511
                                          http://elektrotanya.com/?q=hu/conten...assis-crossref
                                          KDL-46EX401 AZ1N_3a-2 181106111 LTY460HM01 S-LCD 185764311 LJ9702538A 185764411 LJ9403116E A1763564A BEN 147420511 GD2
                                          KDL-46EX402 AZ1N_3a-2 181106111 LTY460HM01 S-LCD 185764311 LJ9702538A 185764411 LJ9403116E A1763564A BEN 147420511 GD2
                                          KDL-46EX403 AZ1L_3a-2 181106111 LTY460HM01 S-LCD 185764311 LJ9702538A 185764411 LJ9403116E A1769676A BAL T2 147420511 GD2
                                          KDL-46EX500 AZ1L_3a-1 181105612 LTY460HJ01 S-LCD 185764311 LJ9702538A 185765011 LJ9403130H A1760331A BAL 147420511 GD2
                                          KDL-46EX500 AZ1L_3a-1 181105612 LTY460HJ01 S-LCD 185764311 LJ9702538A 185765011 LJ9403130H A1796761A BAL (hotel) 147420511 GD2
                                          KDL-46EX501 AZ1L_3a-1 181105612 LTY460HJ01 S-LCD 185764311 LJ9702538A 185765011 LJ9403130H A1760331A BAL 147420511 GD2
                                          KDL-46EX503 AZ1L_3a-1 181105612 LTY460HJ01 S-LCD 185764311 LJ9702538A 185765011 LJ9403130H A1768994A BAL T2 147420511 GD2
                                          KDL-46EX503 AZ1L_3a-1 181105612 LTY460HJ01 S-LCD 185764311 LJ9702538A 185765011 LJ9403130H A1796762A BAL(UK) hotel 147420511 GD2
                                          KDL-46EX505 AZ1L_3a-1 181105612 LTY460HJ01 S-LCD 185764311 LJ9702538A 185765011 LJ9403130H A1769581A BAL SAT 147420511
                                          • EazyBone
                                            Sony 85x90CK 4 red blink
                                            by EazyBone
                                            So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                            But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                            Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                            Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                            07-18-2025, 12:53 PM
                                          • cheeky2
                                            Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                            by cheeky2
                                            For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                            See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                            01-08-2024, 05:56 AM
                                          • Famo
                                            Sony KDL-52Z4500 6 Red LED Blink
                                            by Famo
                                            Hello badcaps forum.
                                            I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife ).
                                            06-09-2023, 10:21 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • EazyBone
                                            Sony XR-77A80J OLED 5 Blink
                                            by EazyBone
                                            Another eazybone post took on this OLED now.
                                            Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                            I'm thinking I have a power board issue though, which is one of the options
                                            Now to check pin voltages from PSU to main and PSU to tcon
                                            Pic 2
                                            1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                            2 bl err -- 0.16
                                            3 evdd on --0
                                            4. Ac off det 3.187
                                            5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                            6 stby...
                                            10-24-2023, 09:09 PM
