Sony KDL-46EX400 2 blink error code
  • tibimakai
    • Jan 2012
    • 3680
    I ha picked up another one of these. Last time it was keep clicking and it would not turn on.
    By replacing the main board, it fixed the TV.
    Now it's a bit different issue. When I plug it in, it would turn on(click only) and then off and would set a two blinking error code, which is the power supply board error.
    There is no backlight turning on.
    It seems that It has a BL_Error code, constant 3.3V while it is plugged in.
    It doesn't have any voltage at T_con on or T_con 12V.
    Here are the voltages that I'm getting:
    T_Con_on= 0V
    T_Con_Vcc12V= 0V
    Dimmer= 0.02V off and 2.95V on
    BL_On= 0.01V off and jumps to 0.43V then goes to 0V when on
    BL_Error= 3.333V on and off
    Reg 12V= 0 off and 12.72V on
    Audio 12V= 0V off and 12.73V on
    Pwr On= 0V off and 3.3V on
    AC_Off_Det= 2.78V off and 2.78V on
    STBY 3.3V= 3.3V both ways
    Inverter connector
    Vcc_12V= 12.67 on and 0V off
    FB= 0V on and off
    LO= 12.03V on and 0V off
    What is interesting, is that I have replaced the main board with the other TV's bad board and it has the same symptom, 2 blink error code. Now I'm thinking, that main board is not bad after all? Why it was constantly clicking and now with this TV doesn't do that?
    I have made some pictures with my phone, just to start this thread.
    I will make some proper ones tomorrow.
    Any help would be appreciated.
  • tibimakai
    • Jan 2012
    • 3680
    Re: Sony KDL-46EX400 2 blink error code
    I would like to test the inverter board's test points as in the Youtube video, but it seems like I'm not getting that 0.2V AC as him. Not getting almost anything.
    • kevinm34232
      • May 2012
      • 1884
      That trick didn't really work for me either trying to isolate the bulb. Check the single leg of the 3 leg diode to the right of the transformer, Im not positive, but I think if you get the 12V there that is indicating backlight problem. In my case I got backlight for a the 2 seconds.
      • tibimakai
        • Jan 2012
        • 3680
        I have a feeling that those test point should be checked with a scope and they should show a certain wave.
        I will give it a try later on, it is too hot to work in the garage for to long.
        • tibimakai
          • Jan 2012
          • 3680
          Not sure about the little transformers output winding location, but if they are the three pins at the left side, they all show 150 Ohms per side.
          *150*150* it shouldn't be around 1000 Ohm? Maybe 500 x2?
          BL_ERROR should indicate an inverter area problem, no?
          Transformer or ccfl tube.
          The 12V is there for a couple of seconds.
          T-con voltage is missing because of this error, am I right?
          • tibimakai
            • Jan 2012
            • 3680
            I know I haven't taken pictures yet, I was busy with other repairs.
            Nobody has any input?
            I have another one for sale, should I just begin swapping boards?
              Pictures are very useful in doing repairs have you done any further diagnosis than specified here?
              • tibimakai
                • Jan 2012
                • 3680
                Not yet, I'm just looking for some ideas, why the T-con would not get the 12V? Because of the protection mode that it is in?
                I have tested all the inverter transformers and they are all 150 Ohms.(*150*150*)
                I have tried testing the protection side of the transformers, but I can't measure those .2 AC/V as per the Youtube video.
                How could I test the CCFL tubes?
                  T-Con ON is 0V so T-con 12V should be missing.
                  • tibimakai
                    • Jan 2012
                    • 3680
                    That's correct. This is what I'm trying to figure out, why.
                    There is an inverter error too.
                      Where is INV ERR?
                      • tibimakai
                        • Jan 2012
                        • 3680
                        BL_ERROR is 3.33V when the TV is on.
                        • signup
                          • May 2013
                          • 189
                          Hi
                          In the service manual it says that 2 blinks is the psu fault and this is probably why changing the main board has not changed the diagnostic blink
                          Wouldnt the self check system get clarification that the psu is at fault before self checking the main/tcon/inverter/panel thus giving it a 2 blink code regardless of whatever other boards you change.
                          Have you booted the psu as a stand alone to see if your voltages come up
                          • tibimakai
                            • Jan 2012
                            • 3680
                            Without the main board?
                            • signup
                              • May 2013
                              • 189
                              Disconnect all the boards
                              • tibimakai
                                • Jan 2012
                                • 3680
                                It will start without the PS_ON signal from the main board?
                                Or should I use a resistor to start it up?
                                  It depends on the design of this power supply/inverter board, most newer one has pull-up resistor built-in so the main board will keep the PS_ON LO, when you remove the cable to the main board, the PS_ON will go HI when disconnected from main board. You have to look at the diagram to find out, most Samsung are done that way now.
                                    Not exact but similar schematic
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      It doesn't boot by itself.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I have downloaded the 46EX402 and it's much closer to what I have.
                                        It seems that Q6151 FET(TPC8119) doesn't output anything.
                                        There is a resistor like IE 7A fuse, before it and there is 12.71V, but nothing comes out before the error kicks in.
                                        • EazyBone
                                          Sony 85x90CK 4 red blink
                                          by EazyBone
                                          So I got this Sony and purchased it working.. got it home and it was 4 blinks red. Seller actually refunded me thankfully. Now it's massive to take apart and I know 4 blink can be the panel sometimes but not always..
                                          But I found a method through other ways with grounding out the bl error pin on the LD driver board. Now the tv turns on and works.
                                          Pin is number 27. It was either remove the resistor right next to the solder pad or solder the pad to ground. I soldered the pad.
                                          Now what is this going to do to the tv? Is it just going to die shortly down the road?...
                                          07-18-2025, 12:53 PM
                                        • cheeky2
                                          Sony RB2G Chassis KDL-55W815B MAIN BOARD 2 Blink Error issue resolved! Happy days :)
                                          by cheeky2
                                          For anyone interested just repaired this Sony Main board TV that had a 2 blink error code, the chassis is a RB2G which is common to quite a few different Sony models. The Ceramic 10uF 25V X7R 1206 capacitor C9114 was shorted which took the smd 2A 0603 fuse out F9101. This was powering the Buck converter TPS54332 which caused no 5V output from it.
                                          See the attached picture of the locations of both components. I also attach the best service manual I found for this board for anyone else in a similar position of trying to repair this main board. It's not specific to the TV model however it gives...
                                          01-08-2024, 05:56 AM
                                        • Famo
                                          Sony KDL-52Z4500 6 Red LED Blink
                                          by Famo
                                          Hello badcaps forum.
                                          I have a Sony KDL-52Z4500 TV that needs a little trouble shooting. History of the TV: I bought it about 14 years ago. One year ago, I took it off the wall to move to another house. During the past year it sat in its original packaging - even with the thin film plastic bag/cover that it gets shipped in, cardboard box and all. Last week I unpacked it to mount it in the garage for my wife's gym that she has setup. Turned it on, set up a chormecast on it for her, and all was good for a week running like always (brownie points for me from the wife ).
                                          06-09-2023, 10:21 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • EazyBone
                                          Sony XR-77A80J OLED 5 Blink
                                          by EazyBone
                                          Another eazybone post took on this OLED now.
                                          Symptoms. Hit power, white light shows briefly and then 5 blink red code. TCON issue per chart on first picture.
                                          I'm thinking I have a power board issue though, which is one of the options
                                          Now to check pin voltages from PSU to main and PSU to tcon
                                          Pic 2
                                          1 tcon on 12 -- 0v (when I hit power this goes to 3.1 stays for short time and back to zero)
                                          2 bl err -- 0.16
                                          3 evdd on --0
                                          4. Ac off det 3.187
                                          5 power on -- 3.362 BUT fluctuating randomly to 3.352
                                          6 stby...
                                          10-24-2023, 09:09 PM
