vizio E320-A1 not working
  • mhoward
    • Jun 2013
    • 11
    I plug the tv in white light blinks lower left then goes out
    I can push the power button and light will come on steady and stay on
    but nothing else happens
    I have tested the power at out put plug and they match the stated voltages next to plug
    I also have seen that they have problems with voltage regulators and to of them have an out put of 3.3 volts with a part number of 17-33
    and according to data sheet I found it should be 3.3 v
    one other slightly lager one part number 1234dg or 1084 has 3.2 volts out
    connected to another one 912T63 that has 3.3 volts in and 1.19 volts out
    is there anything else I can check or would it be easier to replace main board which I think is bad
    the video board is 715G5660-M0E-000-004K
    thanks for any help
  • retiredcaps
    • Apr 2010
    • 9271
    Re: vizio E320-A1 not working
    Assuming your multimeter is accurate, both the readings above are out of specification and could be causing your problem. See
    https://www.badcaps.net/forum/showthread.php?t=22231
    as to why.
    --- begin sig file ---
    --- end sig file ---
    • mhoward
      • Jun 2013
      • 11
      okay I have retested them
      1084
      1234DG
      pin 1 2.05 volts
      pin 2 3.3 volts
      pin 3 5.23 volts
      connected to the out put of first one is
      0283
      912T63
      pin 1 ground
      pin 2 1.19 volts
      pin 3 3.3 volts
      25D
      17-33
      pin 1 ground
      pin 2 3.29 volts
      pin 3 5.25 volts
      25D
      17-33
      pin 1 ground
      pin 2 3.29 volts
      pin 3 5.23 volts
      • retiredcaps
        • Apr 2010
        • 9271
        0283
        912T63
        pin 1 ground
        pin 2 1.19 volts
        pin 3 3.3 volts
        The above is correct. I was looking at the wrong datasheet. The correct one is
        https://cdn.badcaps-static.com/pdfs/...25e4855b99.pdf
        which specifies it is a fixed 1.2V regulator.
        25D
        17-33
        pin 1 ground
        pin 2 3.29 volts
        pin 3 5.25 volts
        25D
        17-33
        pin 1 ground
        pin 2 3.29 volts
        pin 3 5.23 volts
        The above two are good. When you reort just 3.2V it implies 3.200000V. Obviously, when you report 3.29, you can see what a difference it makes.
        • mhoward
          • Jun 2013
          • 11
          okay thanks
          but any ideas what else I could check as to why it will not turn on at this point
          • retiredcaps
            • Apr 2010
            • 9271
            On the connector from power board to the main board, measure the DC voltages and report them like this.
            pin 1 = legend says 12V, I get 11.99V
            pin 2 = etc
            • mhoward
              • Jun 2013
              • 11
              okay I have
              pin legend reading
              13 on/off 247.5 ohms to ground
              12 Dim 6.78 ohms to ground
              11 +12v 12.38v
              10 +12v 12.38v
              9 GND 0.0 ohms to ground
              8 GND 0.0 ohms to ground
              7 GND 0.0 ohms to ground
              6 +24v 24.75v
              5 +24v 24.75v
              4 ps_on 4.83v
              3 5.2v 5.25v
              2 5.2v 5.25v
              1 nc
              the pin 13 never seems to see any voltage not sure if it will at some point or not, same with the 12 pin for dim
              thanks
              • retiredcaps
                • Apr 2010
                • 9271
                Pin 13 is likely backlight on/off. If there is no voltage, the backlight will not come on. The main board controls this functionality.
                Hookup a source (like a DVD player) and see if you have picture and/or sound.
                  "13 on/off 247.5 ohms to ground
                  12 Dim 6.78 ohms to ground"
                  The readings are in Ohms instead of Volts, what are the voltage reading on these two pins?
                  • mhoward
                    • Jun 2013
                    • 11
                    there is no voltage on the pins 12 and 13
                    I also hooked up the TV to my cable box by way of the RCA audio and video plugs
                    and I have nothing no sound at all
                    • Cosmo66
                      • Nov 2012
                      • 87
                      Does the backlight come on?
                      • mhoward
                        • Jun 2013
                        • 11
                        no the back light does not come on
                          Those two signals:bl_on (or ON/OFF) and the backlights dimming control are generated by the main board, that is why there is no backlights even though you have 24V feeding the inverter board. The PS_ON signal from main board is working otherwise you will not get the 24VDC for the inverter board. You will have to work on the main board next, I am not sure if this VIZIO series is one of those with the bad EEPROM pronblem or not.
                          • ecking767
                            • Oct 2009
                            • 492
                            this Vizio 32" has LED back-lighting. you need to upload pictures of the power supply and LED driver board section.
                            • mhoward
                              • Jun 2013
                              • 11
                              here is some pics of the power supply and main board
                              • mhoward
                                • Jun 2013
                                • 11
                                does anybody have any other ideas?
                                • bmolke
                                  • Jul 2012
                                  • 21
                                  • usa
                                  mhoward did you ever figure this one out? I have the same issue
                                  • mhoward
                                    • Jun 2013
                                    • 11
                                    no I ended up just replacing the main board
                                    • Beester
                                      • Jul 2013
                                      I have the exact same issue and same TV. I wish there was a known solution to the problem.
                                      • mhoward
                                        • Jun 2013
                                        • 11
                                        the board was $69 on ebay and the guy gave me $20 back for giving him the old one
                                        • mrtek
                                          Vizio M65-C1
                                          by mrtek
                                          Hi.
                                          picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                                          When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                                          This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                                          Yesterday, 07:28 PM
                                        • MisterAIL
                                          PS5 digital / No Power / No Beep / Good power supply
                                          by MisterAIL
                                          Brought a non functionnal PS5. Apparently only a bad PSU...
                                          No beep, nothing.
                                          After some tests i found this :
                                          - PSU is fine (12 volts stable)
                                          - 12 volts line is shorted
                                          - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                          - By the way, nothing change. No signal, no power, no beep.
                                          Mesuring all rails with my workbench psu (12 volts input)
                                          - 0.00 amp drawing
                                          - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                          03-12-2024, 03:24 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • BTubbs200
                                          Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                          by BTubbs200
                                          Dell Latitude 5420 P137G
                                          Board: LA-K491P REV A01
                                          I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                          Board seems to have no shorts, all power rails are fine and show high resistance.
                                          When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                          01-24-2025, 08:15 PM
