vizio E320-A1 not working
+ More Options
Posts
  • phan1978
    • Sep 2016
    • 32
    Re: vizio E320-A1 not working
    Originally posted by budm
    Right when I touch each leg, the meter reads over 100 and then drops rapidly to 0
    • phan1978
      • Sep 2016
      • 32
      What should the dial be set to on the volt meter? V w/ wavy line or V with straight line and a dotted line?
        VDC = Straight Line
        AC = ~ Line
        So set to DC.
        • phan1978
          • Sep 2016
          • 32
          VDC = Straight Line
          AC = ~ Line
          So set to DC.
          I got a reading of 410
            410VDC? That cannot be true.
            Show the picture of your meter reading.
            • phan1978
              • Sep 2016
              • 32
              here ya go. I am sure i messed up some setting......
              • phan1978
                • Sep 2016
                • 32
                I do want to stop and thank you, for being patient and taking time to help me.
                  Try checking 9V battery or AA battery or something.
                  Are you sure the meter is OK?
                  BTW, when you measure those Voltages on the connector of the power supply that goes to the main board, you did have it set to DCV, right?
                  • phan1978
                    • Sep 2016
                    • 32
                    a new 9V battery read 9.5
                    • phan1978
                      • Sep 2016
                      • 32
                      "BTW, when you measure those Voltages on the connector of the power supply that goes to the main board, you did have it set to DCV, right?"
                      just let me know where to put the red and the black (which 2 pins of that 13 pin connector)
                      • phan1978
                        • Sep 2016
                        • 32
                        When I touch pin 11 & 12, I get a reading of over 11V
                          OK, so in the beginning you had the meter setting to AC that is why you were getting nothing on the connector.
                          https://www.badcaps.net/forum/attach...3&d=1472951354
                          So put the black probe on the metal chassis of the TV then use Red probe to measure DCV of each pin except pin 1 (N.C.) and GND pins 7, 8, 9.
                          Report the reading of each pin like this when TV is plugged in but the power switch is not activated, and when power switch is activated
                          Power switch is not activated:
                          Pin 2: 5.2V = XXXV
                          Pin 3: 5.2V = XXXV
                          Pin 4:PS_ON = XXXV
                          Power switch is activated:
                          Pin 2: 5.2V = XXXV
                          Pin 3: 5.2V = XXXV
                          Pin 4:PS_ON = XXXV
                          • phan1978
                            • Sep 2016
                            • 32
                            So put the black probe on the metal chassis of the TV then measure DCV of each pin except pin 1 (N.C.) and GND pins 7, 8, 9.
                            Pin 2: 5.2V = XXXV
                            Pin 3: 5.2V = XXXV
                            Pin 4:PS_ON = XXXV
                            Pin 2: 5.2V = 0.74
                            Pin 3: 5.2V = 0.50
                            Pin 4:PS_ON = 0.40
                            Pin 5:+24v= flips anywhere between 12 to 22v quickly
                            Pin 6:+24v= flipping anywhere between 2 to 22v quickly
                            7-9 GND =
                            10=+12v =flipping anywhere between 3 to 11v quickly
                            11=+12v =flipping anywhere between 3 to 11v quickly
                            12= dim =0.20v
                            13= on/off = 0.40v
                            NOTE: The TV does nothing when the power button is pressed. Like I said earlier, people with this same issue have reported that the main board was the culprit....I just want to make sure I am diagnosing the correct board
                              Right now you do not even have steady STANDBY 5.2V to run the main board.
                              Check the power supply board by itself without any other boards or other cables connected to it except the AC power cord and then check the DCV again.
                              Something is not making sense that you even has 410VDC on the main cap.
                              • lolaeng
                                • May 2017
                                • 23
                                I, too, have a Vizio E320-A1 that will not power on. So, rather than start a new thread, I thought I should continue here. A couple of days ago the light at the bottom left front would light up but the TV would no longer turn on. Now that little light also does not light up. To get the DCVs asked of the owners of problem TVs the only way I can guess the TV is "on" is by unplugging the TV, then plug it in and get the DCVs for "off", then hold the Power button long enough to hope it turned "on" the power and then I took the readings again of the DCVs.
                                Pin Off On
                                1
                                2 5.22 5.22
                                3 5.22 5.22
                                4 4.7 4.7
                                5 24.6 24.6
                                6 24.6 24.6
                                7 GND
                                8 GND
                                9 GND
                                10 12.37 12.3
                                11 12.36 12.3
                                12 96.3 47
                                13 57.7 30
                                From all that I've read I'm thinking my power card is working and the problem lies in my main board. Are there any DVs I can test on the main board to confirm it is the problem?
                                I have photos of the cards but I've no idea how to upload them.
                                  12 96.3 47
                                  13 57.7 30
                                  Retest pin 12 and 13, no way they can be that high (96V?, 57V?) without TV blowing up. Make sure to read the meter properly, may be mV instead of V?
                                  BTW, ALWAYS put down the pin names when report the readings, see post 53.
                                    Double posted, ignore this post.
                                    • attainteddragon
                                      • Apr 2013
                                      • 764
                                      • australia
                                      #58
                                      please tell me that your measurement for pin 13 is not 30v
                                      can you recheck that when you are powering it on.
                                      WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                                      • attainteddragon
                                        • Apr 2013
                                        • 764
                                        • australia
                                        #59
                                        you beat me to it bud!
                                        • lolaeng
                                          • May 2017
                                          • 23
                                          1 NC
                                          2 5.2v
                                          3 5.2v
                                          4 PS_ON
                                          5 +24.6
                                          6 +24.6
                                          7 GND
                                          8 GND
                                          9 GND
                                          10 +12v
                                          11 +12v
                                          12 DIM
                                          13 On/Off
                                          I unplugged the TV, waited, plugged it back in and rechecked the values. No change to any. I used exclusively DCV not touching my multimeter between start and finish. Then I secured the negative probe to ground and put the positive probe on pin 12 then I depressed the on button ON the side of the TV. It continued to read 96.3 and did not change at all while I held down the ON button. Apparently the ON feature is now no longer working. And the TV did not blow up.
                                          • MisterAIL
                                            PS5 digital / No Power / No Beep / Good power supply
                                            by MisterAIL
                                            Brought a non functionnal PS5. Apparently only a bad PSU...
                                            No beep, nothing.
                                            After some tests i found this :
                                            - PSU is fine (12 volts stable)
                                            - 12 volts line is shorted
                                            - DA9065 was fried, F7003 also => Replaced both of them, short is gone on 12 volts line, no dead short anywhere else.
                                            - By the way, nothing change. No signal, no power, no beep.
                                            Mesuring all rails with my workbench psu (12 volts input)
                                            - 0.00 amp drawing
                                            - 12 volts, 5 volts, 2 volts, 1,15 volts are presents (suppose new DA9065 do is...
                                            03-12-2024, 03:24 PM
                                          • howardc64
                                            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                            by howardc64
                                            Failure Symptom
                                            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                            Where is the short?
                                            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                            05-27-2025, 02:56 PM
                                          • BTubbs200
                                            Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                                            by BTubbs200
                                            Dell Latitude 5420 P137G
                                            Board: LA-K491P REV A01
                                            I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                                            Board seems to have no shorts, all power rails are fine and show high resistance.
                                            When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                                            01-24-2025, 08:15 PM
                                          • howardc64
                                            Vizio SmartCast TV software bug that looks like hardware
                                            by howardc64
                                            Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                                            It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                                            11-16-2024, 05:17 PM
