no picture on my samsung 50 inch plasma
    Re: no picture on my samsung 50 inch plasma
    Can you check with your black probe on the chassis of the TV, red probe on one end of fuse, then other, and record both readings for us?
    • jose6326
      • May 2013
      • 707
      Tom66 I was speaking with the electronics guy at my job
      He said I put the lead on the wrong ground
      That I should of put the negative lead on the ground of the connector not on chasis ground
      Is this correct?
        It may be correct for some systems but for TVs I've always used the chassis ground and that always works for me. You can wire it to the ground of the connector... but you're going to need a length of wire to do so.
        • jose6326
          • May 2013
          • 707
          Thats exactly what I did
          Negative probe on chasis ground and positive probe on one end of fuse with power on and I got 2.7v
          I will do it again when I get home and I will take a pic
            Check both ends.
            • jose6326
              • May 2013
              • 707
              Tom here is what I did
              First 2 pics
              Power on
              Positive probe on one end of fuse negative probe on chasis ground
              Fuse Reading: 4v
              Fuse reading: 3.92v
              • jose6326
                • May 2013
                • 707
                Here are pics with board disconnected
                Not sure if I tested it correctly on this one
                • jose6326
                  • May 2013
                  • 707
                  Tom im not sure if this will help
                  on pg 3 in the pdf it looks like it is saying to jumper the connector to the logic board or main board to get the test pattern
                  Am I wrong?
                    You tested correctly, on the first one. But can you please check the connector on the Y-main side too?
                    • jose6326
                      • May 2013
                      • 707
                      Tom I got 54v on the ymain board from the connector that goes to the E buffer
                      • jose6326
                        • May 2013
                        • 707
                        you think it is the E buffer or F buffer board?
                          If you connect Va to the buffer board, does the Va collapse? Measure the Y-main side.
                          (Don't connect it with power applied to the TV. Allow the TV 10 seconds to discharge before plugging it in.)
                          • jose6326
                            • May 2013
                            • 707
                            what do you mean by collapse?
                            right now the tv has been unplugged for a whole day or two
                            you want me to reconnect the connector to the E buffer board
                            then power on the tv
                            then test for VA at the connector on the y main board that goes to the E buffer
                            is this correct?
                              Collapse = drops to the 3~4V measured previously.
                              What you have said is correct.
                              • jose6326
                                • May 2013
                                • 707
                                do you want me to test Va as the tv is being powered on?
                                or it does not matter if it has been powered on then i place the probes at the connector?
                                  I want you to measure the Va on the Y-main board end with everything connected.
                                  • jose6326
                                    • May 2013
                                    • 707
                                    Tom I tested the va at the ymain as you instructed
                                    I could not take a pic of the reading because I needed both hands to probe the connector since I dont have alligator clips
                                    But I took a pic to show you how I tested it
                                    I got 53.8v for va
                                    I also retested the fuse at both ends with negative probe on chasis ground with powrt to tv and this time I got 53.8v on either end of the fuse
                                    The last time I tested it was 4v
                                    Do you know why it is doing this?
                                      You might have a dodgy multimeter lead or the fuse connectors may have been corroded. Since you now have good Va, the control board is a likely suspect, but it's hard to be certain.
                                      • jose6326
                                        • May 2013
                                        • 707
                                        So is there anything else to test?
                                        I keep forgetting to mention that the y main is buzzing and it tends to get a low buzz and then goes back to the same level buzzing as it started
                                        Is this normal?
                                          The scope tests were somewhat inconclusive about Y-main functionality, the waveform did not look quite right.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • Cooperr
                                            Samsung 59" plasma PN59D550C1F seeking advice on mystery power board issue
                                            by Cooperr
                                            I picked up this TV from Facebook Marketplace, original owner described it as "screen went black after a pop" and I hoped to see an obvious fuse or cap to replace. Doesn't seem to be the case, but my experience and electrical knowledge are kind of limited for this.
                                            The power board (BN44-00445A, see attached) turns on and Vs and Va seem to momentarily have power, then they steadily drain to zero over a minute or two as if they're only getting power from capacitors. I've been measuring Vs and Va from the test pads, with and without the other boards connected to the power board...
                                            10-21-2025, 01:11 PM
                                          • ohren
                                            by ohren
                                            09-08-2023, 05:24 PM
                                          • alltvrepairs
                                            Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                                            by alltvrepairs
                                            I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                                            I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                                            Any one met this problem in the past?...
                                            10-08-2025, 07:34 AM
