Vizio vw37l Amber light only will not power on
  • swwww
    • Feb 2013
    • 17
    • usa
    Re: Vizio vw37l Amber light only will not power on
    Thanks, you guys have been very helpful
    Do you have any clarification for your reference to u3 no input voltage tom?
    (as it receives essentially no input, it gives no output.) (u3)
    so are you are saying no input should not be expected for the conditions ( because of tv not being on) or are you just stating the obvious (no input no output)
    Its positioned above the 75ohm output section so i kind of guessed it would not be energized while tv was off??
    thanks
      When the amber light is on, TV is in standby. This means only supply is (usually) just 5V. The 5V feeds some parts of the main board which are active in standby mode.
      That regulator provides regulated power for probably the tuner, audio or video processor when the TV has powered on fully (white.)
      If there is a fault with a regulator, usually the TV won't even attempt to power up, so you'll see no voltages there.
        U3 is fed by the 12v power supply which is off when TV is in standby mode, when TV is turn on the main board will send the PS_ON to turn on the 12v/24v power supply,then you will get the 5V output of that 5V regulator IC
        • swwww
          • Feb 2013
          • 17
          • usa
          Thats what i was thinking. Thank you for taking the time to help and explain-- I feel I owe ya guys a pint
          I was trained to component level repair in the us navy about 20 yrs ago but most all of my field experience has been what the navy calls "organizational" level which is board/box/cable/connector with a bunch of signal flow. So its all a bit fuzzy/rusty at best
          Ill get u7 swapped and report back...might be a couple days
          thanks again
          • swwww
            • Feb 2013
            • 17
            • usa
            The voltage regulator came in and I put it in today U7. T.V. works 100%!!!!!!! Yay!!!!
            Just wanted to extend my thanks to budm, tom66, johnboy1313, Dgtech and retiredcaps for your help and guidance.
            You guys are all over this site helping people and I'm pretty sure no one is paying you to do it. Pretty great stuff. From this guy, many thanks!!!!
            • martyparish
              • Dec 2012
              • 313
              It's amazing how many of the Vizios have bad regulators! Good job on the fix!
              • retiredcaps
                • Apr 2010
                • 9271
                #27
                Hence the how to guide with Vizio specifically mentioned inside it. This allows people who search to find the document. Almost 13,000 views since the regulars wrote/contributed to that document.
                The days of fixing TVs due to obviously bad caps is probably 10% or less now.
                --- begin sig file ---
                --- end sig file ---
                • Shane711
                  • Dec 2014
                  • 493
                  I got this TV with the Amber light and it will not turn white. The voltage regulators were a little difficult to test this time so I had to refer to budm's post on how to test a voltage regulator "The voltage between the Adjust pin (left pin) and the center pin (Pin2, output) will always be 1.25V". So U2 is reading .88 VDC and U9 is reading 1.5 VDC. Not sure what it means if the voltage is higher but I am about to change these out with new ones.
                  The output voltage on U9 was reading 1.25 so I thought that was normal and the voltage on U2 was reading 2.25 and I thought that was normal.
                  So I changed them both out and now the TV is working
                  U9 is still reading 1.25 and U2 is reading 3.30 so looks like U2 was the only bad one. So back to the quote "The voltage between the Adjust pin (left pin) and the center pin (Pin2, output) will always be 1.25V" Why was the voltage for U9 1.5 VDC? Should it read "will always be 1.25V or higher"?
                    The reading is between ADJ pin 1 and the output pin 2 of the ADJUSTABLE regulator, it is not applied to FIXED output regulator since the pin 1 is GND for the FIXED output regulator.
                    The output Voltage of the ADJUSTABLE regulator = Voltage at ADJ PIN + 1.25v REF
                    • Shane711
                      • Dec 2014
                      • 493
                      Yes, both regulators are the adjustable 1117. Every regulator read 1.25V between Pin 1 & 2 except for U2 & U9 but U9 read 1.5V. U2 read 0.88V and so that was the bad regulator.
                      Why would U9 read 1.5V and I believe it was not bad but I changed it anyway.
                        The 1.25Vref is very accurate Voltage, The circuit may be able to handle 0.25V higher than expect that is why the circuit may be still operating, but the one with 0.88V, then the output Voltage may be too low to operate.
                        One IC has 0.88V between ADJ AND adjust, then you add that to the Voltage reading between adj and GND = OUTPUT ON PIN 2 = ???
                        Second IC has 1.50V between ADJ AND adjust, then you add that to the Voltage reading between adj and GND = OUTPUT ON PIN 2 = ???
                        • Shane711
                          • Dec 2014
                          • 493
                          TV is gone, returned to owner. Works perfect.
                          I though about adding heat sinks to the regulators to keep them from burning up, I will have to experiment with one later and see if they get hot while on.
                          • huzo
                            HP 470 G5 blinking amber light no power
                            by huzo
                            The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                            So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                            I've tried flashing the bios...
                            interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                            06-08-2023, 04:08 PM
                          • PantherDave
                            by PantherDave
                            Hi all!
                            05-29-2024, 02:01 PM
                          • lapfix
                            HP OMEN NO power no light
                            by lapfix
                            HP OMEN : DAG35DMBAD0
                            NO power ,no short ,no corrusion
                            Consumption : when charger plg in = 0.004 amp
                            Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                            when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                            No light at power button led
                            All coils resistances :
                            Pl 2001 =3v measured with kohm.
                            pl 2004 = 5v measured with kohm
                            pl 6001 = 49.7ohm
                            pl 4012 = vccsa = 24.4 ohm
                            pl 3001 =...
                            11-03-2025, 07:48 AM
                          • x_orange90_x
                            Vizio E550i-A0 no power, no standby light
                            by x_orange90_x
                            I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                            11-20-2023, 09:49 AM
                          • zwect
                            Dell Latitude 5420 / GDF40 LA-K491P REV 3.0 / Amber / Orange light when power button is pressed
                            by zwect
                            I have this Dell Latitude 5420 with ST: CMF62F3, board GDF40 LA-K491P REV 3.0 that does not power on, i already searched for some clues about this problem that happens on mine but no BIOS i downloaded and flashed did anything.
                            Only when the power brick is connected, when pressing the power button an amber light lights up at the front and slight decreases its brightness, the RAM and the CPU seem to heat up if the laptop is left connected but nothing else, other than USB devices getting powered.
                            Here is the original BIOS dump from the 25R256JVEN chip.
                            09-11-2024, 05:54 PM
