Bush LCD37TV016HD
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    #101
    Re: Bush LCD37TV016HD
    what diagram ?
    • selldoor
      Slow Learner
      • 7870
      #102
      Post97
      • LEEDASH
        • Dec 2012
        • 481
        • Bedfordshire
        #103
        yes get you now,does the blue/brown wire have to be plugged in to the pcb ? just use a paper clip to cross wire across plug ok.
        • LEEDASH
          • Dec 2012
          • 481
          • Bedfordshire
          #104
          'IF' i dont get any reading doing this what will this confirm ?
          • selldoor
            Slow Learner
            • 7870
            #105
            I have to go now - it will confirm that
            1 the switch doesnt work or
            2 the wiring at the switch is defective or
            3 the wiring at the kettle connector is defective ( You have said that from the kettle
            plug to the mains plug is ok)
            OR your meter has an intermittant fault - are the leads on it sound?
            • Radio Fox
              • Jan 2010
              • 281
              Don't plug the connector with the blue/brown leads on it to the PSU board, as you need to get access to the pins on the connector.
              Putting your meter probes on the 2 pins on this connector should give a reading of almost zero Ohms when the rocker switch is in 1 position, and open circuit when the rocker switch is in the other position.
              If you cannot find something to short out the pins on the mains plug, you could also try putting one probe on the Live pin of the mains plug, and the other probe on one of the pins on the connector that goes to the PSU. One of the pins (probably the one connected to the brown lead) should show zero Ohms when the rocker switch is in the ON position.
              Then put one probe on the Neutral pin on the mains plug and the other on one of the pins on the connector that goes to the PSU board. Again, one of the pins (probably the one connected to the blue lead) should show zero Ohms.
              It would be a little easier if you could show a picture of the actual path of the mains wiring inside the set from the kettle socket to the PSU board. The photos you posted earlier just showed pictures of the PCB's with the mains wiring underneath.
              ________________________________________________
              Invisible airwaves crackle with life
              Bright antennae bristle with the energy
              • LEEDASH
                • Dec 2012
                • 481
                • Bedfordshire
                #107
                Ok radio fox ! Blue wire showing nothing brown wire reading 00.8
                • LEEDASH
                  • Dec 2012
                  • 481
                  • Bedfordshire
                  #108
                  That's with the power switch on ! With it off you get no reading
                  • LEEDASH
                    • Dec 2012
                    • 481
                    • Bedfordshire
                    #109
                    • LEEDASH
                      • Dec 2012
                      • 481
                      • Bedfordshire
                      #110
                      • selldoor
                        Slow Learner
                        • 7870
                        #111
                        Pictures are getting better - can you show the other side of the switch in the last pic.
                        Is the rocker switch and the kettle socket together in the same unit?
                        • LEEDASH
                          • Dec 2012
                          • 481
                          • Bedfordshire
                          #112
                          You have the rocker switch then the fuse (glass) then the kettle lead
                          • LEEDASH
                            • Dec 2012
                            • 481
                            • Bedfordshire
                            #113
                            • LEEDASH
                              • Dec 2012
                              • 481
                              • Bedfordshire
                              #114
                              • selldoor
                                Slow Learner
                                • 7870
                                #115
                                ok - I see pic will be back in a min.
                                • LEEDASH
                                  • Dec 2012
                                  • 481
                                  • Bedfordshire
                                  #116
                                  • LEEDASH
                                    • Dec 2012
                                    • 481
                                    • Bedfordshire
                                    #117
                                    • selldoor
                                      Slow Learner
                                      • 7870
                                      #118
                                      Ok - Think I have got it now
                                      In the picture it looks like you can get to metal connectors at the base of each wire by pulling back the shrink a little.
                                      Working only on the switch - no kettle lead and not plugged into the board. Meter on ohms can you get at the metal under 1 and 2 on the pic test with switch one way then the other. This should bottom out if the neg side of the switch is working.
                                      EDIT should perhaps have said put one probe from the meter on 1 and the other on 2
                                      • LEEDASH
                                        • Dec 2012
                                        • 481
                                        • Bedfordshire
                                        #119
                                        Ok,if the switch is in the on position it is fluctuating between 0.12 0.14 when it is off nothing.
                                        • selldoor
                                          Slow Learner
                                          • 7870
                                          #120
                                          This really doesnt seem to be making much sense. It is almost the same test as in 106/107
                                          Put the switch in what you believe is the ON position and do the ohms test from the
                                          neg pin in the kettle socket to the first the blue position marked 1 then the blue position marked 2
                                          I am still wndering about your meter Hold the probes together (in one hand cross them and hold between thumb and forefinger)) and it should go almost to 0.00 then gently tug the probes and see if it goes to 1 on the left side or OL or whatever it shows when
                                          the probes are apart.
                                          • jdawg99
                                            Bush DLED32287HDCNTDFVP - Is this a screen fault or a Tcon Issue
                                            by jdawg99
                                            Trying to fix a bush TV. The Tcon is integrated onto the main board by the looks of it but before I buy a replacement does this look like a screen fault? The lines at the bottom are concerning me. I have check for shorts on the caps etc and can't see anything obvious. Nothing is overly hot and I've tried heating different boards and pressing down on the flex but no change in picture.
                                            Any advice welcome. Thanks in advance....
                                            09-18-2022, 05:30 AM
                                          • Rictech
                                            Panasonic SA-MAX770PU SMPSU board fault....
                                            by Rictech
                                            Hello everyone. 😀
                                            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
                                            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
                                            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
                                            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
                                            There are no devices that have exploded or otherwise show signs...
                                            08-26-2024, 01:05 AM
                                          • howardc64
                                            Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
                                            by howardc64
                                            • Prior owner tried a replacement main board. No difference.
                                            • Samsung 2x red blinking standby LED = panel fault
                                            • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
                                            • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
                                            • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
                                            07-19-2025, 10:54 PM
                                            ESR meter came to the rescue again today with a PLC I/O card fault
                                            by sam_sam_sam
                                            I have been having a fun time at work with two pieces of equipment that had shorted components or shorted component cables to machine frame
                                            I would check what my multi meter was telling me about how many ohms I getting with the multi meter was telling versus the ESR was telling me about weather or not it really was a short to machine ground or not
                                            One note at first we thought that it might be a bad I/O card or a malfunction PLC including me as well but I thought I would try and see if removing the I/O cables would make a difference or not and this time it did make a difference...
                                            12-18-2023, 08:17 PM
                                          • CDNBrewer
                                            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
                                            by CDNBrewer
                                            Hello Everyone,
                                            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
                                            Symptoms:
                                            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
                                            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
                                            • I swapped the Left and Right surround
                                            08-05-2025, 09:29 PM
