Bush LCD37TV016HD
    Bush LCD37TV016HD
    Hi i have been given one of these lcd sets,it has a fault it wont switch on ? any ideas for a start off.
    Re: Bush LCD37TV016HD
    Pictures will help us see what you have and what we are dealing with.
        Virtually unusable pictures, you will need to get better pictures. Common fault on this set is two bad caps.
          I will try and get some better pics,tom would these two caps you have said,stop this unit from switching on then.
            Normally it gets blue standby LED which will go dark but then back to blue, after some time it may power up.
              There is virtually no power at all,no standby nothing.
                Have you checked for 5V standby from the PSU?
                  no have not tested anything.
                    May I kindly suggest you do so?
                      Tom i found a post which you put up about this lcd did your have the same symtoms,it was way back in 2011 your post.
                        Mine had a standby LED and powered on after about 20 minutes of flashing. I will not engage further until you make some attempt at testing things.
                          If ive tested it right there is not voltage running through the 5v,the board is a MLT198H,Ive uploaded maybe some clearer pictures.
                            Test each pin on this block connector on main board (top of image):
                            https://www.badcaps.net/forum/attach...2&d=1362770893
                            Voltage should be measured from each pin to the chassis ground.
                              What should each pin be measuring
                                I have absolutely no idea. However, I can make some educated guesses. Post your results.
                                  cant get any reading,did check the fuse next to the where the power socket goes in,(clear fuse has small blob in middle of it ?
                                    Please post your readings. Use DC20V. Saying you have "no reading" doesn't tell me enough.
                                      Ok,multimeter working,power cable working,tested and still no reading,dont even jump.
                                        What is the meaning of NO READING? What exactly do you see on your meter?
