40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
Does it rise at all when it cuts out, or fixed <0.1V?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Is nearby bad OLP the same voltage?
What's VREF measure?Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
bad->"pad".
Noted there is VREF pad, so check that too.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Heres something interesting I found...
When I'm measure this pin, (PIN #19 i think) ill be 0.01V when the backlights go on.
And as it dims when it gets to the HDMI input. It'll raise up to 1.96V steady THEN the TV actually stays on and works!! But as soon as I remove my probe from the pin the TV turns off and starts cycling through the problem again?
I had a similar problem like this with that 32" dynex, where I just resoldered the ground pins and it fixed the problem (But only lasted 20 minutes til it fully died with a main board problem and I gave up on it)
What voltage do you have at the EXTERNAL DIM pin14 on the inverter board, measure it with DC and AC mode on the meter.Never stop learning
Just put the meter in AC volt position. I am trying to find out if this dimming control signal is Analog dimming control type (0~5v) OO if it is PWM AC signal (around 150~200Hz) type.Never stop learning
Pin 14 on the inverter connector, you can see the label by the connector. I remember troubleshooting the Inverter board for Philips Tv on the thread, we had the bl_on, the 24v, etc, but nothing on the PWMDIM, the lamps will flash on and then go out (2-second to black). Took us awhile to find out that the PWM has 0V reading (stuck low), when we disconnect the PWM pin, the backlights will stay fully on. So I am not sure if this inverter is using variable DC to control the dimming or PWM for controlling the dimmimg.Last edited by budm; 02-08-2013, 01:40 PM.Never stop learning
Originally posted by budm View PostPin 14 on the inverter connector, you can see the label by the connector. I remember troubleshooting the Inverter board for Philips Tv on the thread, we had the bl_on, the 24v, etc, but nothing on the PWMDIM, the lamps will flash on and then go out (2-second to black). Took us awhile to find out that the PWM has 0V reading (stuck low), when we disconnect the PWM pin, the backlights will stay fully on. So I am not sure if this inverter is using variable DC to control the dimming or PWM for controlling the dimmimg.Last edited by tieny; 02-08-2013, 01:45 PM.
What meter was used for that measurement? Try measuring AC with probes reversed - sounds odd, but some meters only look at the positive cycle of any AC.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Can your meter read frequency? The PWM for dimming is around 150~200Hz with variable pulse width, the amplitude is 0~5V typical, and since it is not sine wave the AC value reading will not make sense especially if it is not True R.M.S meter.Last edited by budm; 02-08-2013, 01:54 PM.Never stop learning
