40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    Re: 40" Sony LCD KDL-40EX500 Seconds to black (6 blinks)
    I would try disconnect that Dim control wire and see what happen.
    • tieny
      • Feb 2012
      • 478
      Hmm, cutting it worked. TV turns on perfectly, no dimming when it gets to the HDMI screen, its just full bright.
        Maybe the CCFL was sensitive to the dimming somehow, TV will no longer have dynamic backlight, but I always found that annoying anyway. Check hrs on backlight counter.
        • tieny
          • Feb 2012
          • 478
          How do I check the hours?
            From the service menu.
            DISPLAY -> 5 -> Vol+ -> Power.
              That means the main board is not sending PWM (AC) out, the same failure mode as the Philips TV.
              • tieny
                • Feb 2012
                • 478
                From post #129, when I'm probing at that pin on the main chip on the inverter it fixes the dimming problem. Wonder is there a way to simulate that?
                  But this is new inverter board (unless it is also bad) which receives the command signal from the main board to dim the backlights, so what ever that pin does it must cause the IC to turn on. How about putting the old board back in and see if the lamps will stay on with the DIM wire not connected.
                  • tieny
                    • Feb 2012
                    • 478
                    Putting back the old inverter board, its still works perfect without the dim connected
                      I would use it the way it is unless you want to dig deep into troubleshooting the main board PWM signal section somewhere on the board.
                      • tieny
                        • Feb 2012
                        • 478
                        So that problem is actually on the main board?
                        I'm going to leave it as it is, don't really use the backlight/brightness settings anyway.
                        Thanks for the help!
                        • kdh2012
                          • Dec 2012
                          • 17
                          • usa
                          #152
                          Hi guys,
                          I'm late to the party, but just got one of these in the shop and here is what I did.
                          It seems that when the duty cycle of the backlight control goes too low (around 10%), it causes an error and the inverter board shuts down.
                          I replaced R007 (was a 10k) with a diode (cathode,bar, facing towards C008). Then I added a 1 meg resistor in parallel with C008).
                          This stretches the pulse just long enough to keep the duty cycle high enough to not cause an error. The advantage of this "fix" is that the backlight control still works (verses totally disconnecting the dim control).
                          Hope this helps someone.
                          • klasterone
                            • Mar 2014
                            Thanks to you guys my tv now works. I had the same problem the very much.
                            • coofhair
                              • Apr 2014
                              • viet nam
                              #154
                              I have the same error LCD 32bx300 6 blinks but can't see the Pin off protect IC SSI091ASN
                              • amro eid
                                • Apr 2014
                                • 5
                                • egypt
                                #155
                                hello
                                this is backlight problem
                                open ur inverter u have SSI091ASN inside
                                the solution is
                                SSI091ASN No datasheets available...but probably
                                Pin 4 is grounded.
                                Pin 5 is error out.
                                Pin 6 may be Vcc. ( Check voltage on this pin.)
                                Pin 7 is VREF. (Probably 1.2V, 2.5V or 5V.) * jest 5,5V
                                Pin 13 is grounded.
                                ... pin 20 is OLP (Open lamp protect. Should normally be low.)
                                (PIN 19 ) ill be 0.01V when the backlights go on.
                                When It'll raise up to 1.96V steady THEN the TV actually stays on and works
                                Have 24 pins. Top of the chip left to right, 1 - 12 and bottom of the chip, right to left is
                                the tv will work ok and then u will see the bad lamp u can replace
                                and test with ur finger the hot of transformers
                                if one going so hot than other u have to replace this transformer
                                but i fix the same problem with the way above coz CCFL circut was sensitive
                                to bad lamp my tv was KLV-32BX35A.
                                hope success
                                • coofhair
                                  • Apr 2014
                                  • viet nam
                                  #156
                                  Originally posted by amro eid
                                  hello
                                  the solution is
                                  Pin 4 is grounded.
                                  Pin 5 is error out.
                                  Pin 13 is grounded.
                                  hope success
                                  Thankyou, i want to remove proctect Pin and don't replace bad lamp, what's happen of this transformer???
                                  • amro eid
                                    • Apr 2014
                                    • 5
                                    • egypt
                                    #157
                                    hello
                                    u want to remove proctect Pin
                                    connect pin pin 20 to ground directly
                                    the tv will work and u will see the real reason which made this problem
                                    bad lamp or bad contact to one lamp or bad transformer or something else like bad caps in pf and high voltage
                                    but please pay attention
                                    it is very important
                                    we remove protection to fix the real reason and after that we we connect
                                    it if u remove it and deliver it to your customer the tv will back to u
                                    u will find big problem burning,dead fet ,dead ic .etc and then u will need i/p board
                                    any way i think u have bad lamp inside this is common fault
                                    in sony and sharp
                                    hope this may help
                                    regards
                                    • coofhair
                                      • Apr 2014
                                      • viet nam
                                      #158
                                      @amro eid - Thank you very much your ardour, all that you share to userful for me, i've understood what's important of that proplem, Don't be fix it without Ovp
                                      You're Egyptian? your English is very good,and my is so bad i can't write here to more what i think by english hihi
                                      I don't understand really, can you help me, exlain to me more. If i remove protect pin 20, and my tv have bad lamp then turn on tv, transformer works, back light works. What is it to kills Fet, IC or burns transformer
                                      • amro eid
                                        • Apr 2014
                                        • 5
                                        • egypt
                                        #159
                                        hello coofhair
                                        bad transformer sure kills fet and also may kills driver ic
                                        about ccfl lamps u can test it out of tv with inverter of old scanner u have to see
                                        it.s light one by one u will find one or 2 lamp have dark area besides
                                        it.s contact with ht (about 1200v)
                                        and there is many tools exist online to test ccfl lamps and transformers
                                        resolding components besides fet and transformers coz overheating in this area also make sure carefully about
                                        bad caps which it.s value in pf and high voltage as i wrote before it.s connected to transformers
                                        finally
                                        about sony from my experience i guess u have bad lamp
                                        hope this will help
                                        regards
                                        • ger10101
                                          • Sep 2014
                                          which one is the dim control wire?
                                          • mauda
                                            Sony TV model KD-65XE7005 - only Sony logo for 3 seconds
                                            by mauda
                                            I'm currently working on repairing a malfunctioning Sony TV model KD-65XE7005 with the mainboard 1-981-926-21. I would appreciate your assistance with this issue.
                                            Upon powering on the TV, the Sony logo appears for approximately 3 seconds, after which the backlight remains lit, the screen remains black, and nothing else happens. The TV consumes around 55W initially and then drops to 35W. The indicator LED remains solid white. It doesn't respond to the remote control. When attempting to update the TV using a USB dongle, the dongle briefly flashes but nothing else happens.
                                            05-21-2023, 11:56 PM
                                          • tec3000
                                            Sony LED 65X9005A shuts down after few seconds - looking for help
                                            by tec3000
                                            Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                            I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                            03-20-2024, 07:29 AM
                                          • matwan
                                            Sony XR-55X90J 5 blinks
                                            by matwan
                                            I have problem with SONY 55X90J. After several check status is as below;
                                            1. Running power board as stand alone:
                                            TCON_12V =~ 12.6V
                                            EVDD V On Max 24V= 19V.
                                            2.
                                            Running power board with TCON as stand alone:
                                            Effect as below, attched.
                                            3. When bottom LVDS cable is disconnected no blinks, but of course no TCON 12V and EVDD.
                                            "I'm almost sure it's a defective panel, but maybe someone has encountered a similar issue on their screen.
                                            Best regards....
                                            09-28-2025, 04:26 AM
                                          • GoodCapDude
                                            Sony XBR-75X940E intermittent 6 blinks error code
                                            by GoodCapDude
                                            Hi everyone. First post on Badcaps!
                                            I am trying to fix a Sony 940E from 2017 that either starts normally (and works perfectly until turned off) or goes straight to the 6 blinks error code without showing anything on the screen. It is frustrating to know that it can still work perfectly but is barely usable because of the difficulty starting it up. I am willing to try to short the BL_ERR but I would like to avoid that if possible. Does anyone have a view on this? Thanks a lot....
                                            09-20-2025, 06:07 AM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
